Your ram should always be maxed. It's the way Unix based systems work...With last AiMesh beta :
I stopped using the USB HDD a long time ago. It's slow as hell. The NAS server transfers faster.I only see this when I pull something from the HDD like a video or something usually a restart or unmounting the drives gets rid of it
It may be a service active on your router. I'm not using any service (AiProtection, Samba, FTP etc). Not even QoS yet, as I'm still in monitoring phase, and my memory usage is 38%.With last AiMesh beta :
I am seeing in the system log since the Firmware that was released is
NAT Tunnel: AAE Service is stopped
It repeats it over and over again I even googled AAE service have no clue what it is
Yes, it goes on and on every 30 seconds. I submitted feedback to Asus and they told me it's a known issue, with no functionalities impact, and a new release fixing this is expected to arrive shortly.
Because of many issues on the official stock firmware, i'm also using the aimesh beta's.
Last 18943 was running great for one month, Only issue PS4, Nat type still failing, so often disconnects with online games.
Beginning of the week switched to 19612, but lots of issues
So because of the many disconnects i wanted to switch back to 18943.
- Nat type still failing (same as before with PS4)
- Many disconnects with online games, but now also with Xbox and Pc
- Slower surfing, seems to have some sort of delay on every page
- Time scheduling issues
- Clients could not connect anymore
- Reset, soft and hard, not working properly anymore, ..
- Firmware update, also problematic.
But this was not easy.
First i thought well maybe the firmware was not correct installed, so i re-installed 19612 again.
You could see the gauge running, but no restart, nothing happened, router stayed online after the process was done. Very strange, this never happened before like this.
Ok lets try to do the initialize... Again nothing happens and after 20 sec a message popped 'applying settings' WTF? Again the gauge and after finishing, router was still online with all settings still there !
Ok, Hard reset ... yea right, i could press the reset forever but again nothing...
So after some reset and power cycles it eventually did a reset.
So initial screen pops up 'create network' or 'manual setup' you know.... so went for the manual setup and uploaded the stored settings file. After restart same issues like before.
So no go there, now I wanted to go back to 18943 build, but again, router refused to load this firmware...
So after some reset and power cycles i managed to get the 18943 running again. Uploaded the settings file and yea all seems to be running like before....
I have the feeling it works ok after power on, but after some runtime shirt breaks loose...
So has anybody else has more or less same experience with the latest 19612 build ?
Nope I play on PS4 been on this Firmware since release no NAT fails or errors connecting to games past weekend played 8+ hours of CoD no issues at all WiFi on both 5Ghz bands working greater than ever Gaming Ports 1 and 2 working great QoS wise WTF service working good RAM management working properly and been running 48 hours+ without a reboot vs the Official August Firmware I had to reboot daily and I am also behind a crappy ATT Fiber gateway in Passthrough mode with no NAT problems
Strange, did you upgarde from official firmware to 19612 or from other beta?
Have you done a reset prior to this update or just upgraded to 19612?
My configuration (european GT-AC5300)
Mmm at least good for u everything works great.
- Parental controls like times cheduling and web/apps filters
- Qos
- Fixed ip adresses
- Port forwarding
- Upnp
- Bonding (link aggregation)
- IpTv
My GT loses WAN connection with the mesh-beta from 12/16 after a while, like every 48hrs or so. It says it's connected, but it's blatantly lying [emoji16]
After a reboot it's ok again. [emoji58]
Sent from my SM-G955U1 using Tapatalk
This has been a problem on every firmware ive tried. Either incredibly slow open VPN or constant disconnectsHi,
I recently got my GT-AC5300 for openvpn, but it seems not working properly, drops every 5 min.
from log openvpn has old version 2.3.2 while 2.4.4 already available, I am on last beta,did not help
would appreciate any advise thanks
Welcome To SNBForums
