A similar page exists on the stock firmware:
http://192.168.1.1/Main_AdmStatus_Content.asp
And it"s nvram get, NOT set.
Thanks Merlin - this is a very neat trick! I did not know that
So you can overclock the router even using ASUS stock firmware?
happy owners of AC68U, can you please check something for me?
I want to know what are the default CPU/memory clocks
And does anyone know what kind of memory AC68U is using?
the reason I am asking is that on AC56 (identical CPU), ASUS downclocked the memory from 800MHz to 533MHz (why would you cripple the performance??? there is no power or heat issues for memory to run at the rated speed!).
From personal experience I can confirm that going from 533 to 800 makes very noticeable difference...may be this is the reason that R7000 scores significantly faster on things like USB transfers...
command to run is nvram get clkfreq
Stock AC56U spits out 800,533
Stock R7000: 1000,800
Stock AC68U: ???
Stock AC68U: 800,533
Yes. On an RT-AC56U, WAN to LAN maxes out at around 240 Mbits without CTF. I expect the same results on the RT-AC68U since it's the same CPU.
Only the RT-N66U had one.
Damn it. Why would they include a cool surprise, get me used to it then stop.
Well that's great. I downloaded and installed 374.217 yesterday and am running Win7 64-bit. Do I need to downgrade to 374.205?Hmm I don't see this listed on the site anywhere. The latest I see is 205. I picked one up from best buy today and I'd like to get the latest firmware. Nevermind I found it--only listed under win 8 32 bit...weird.
new firmware is out!
ASUS RT-AC68U Firmware version 3.0.0.4.374.217
Added:
- 2.4GHz beamforming UI option.
- Roaming assistant: allow to set the minimum RSSI to disconnect clients and let clients reconnect to Ap with better signal.
- Enhanced the USB and NAT throughput.
Fixed:
- Fixed quick internet setup UI issues when setup the router by wireless client.
- Fixed WPS push button related issues.
- Fixed IPv6 related issues.
=( im so lost at the moment so which router to buy. I recently returned my all iand see how it stands up against a AC68U which I will get in the end of the month,n ubee modem back to timewarner and moved to a sb6141, but my old wrt54g can't handle the 50/5 speeds. Originally was set on buying an AC68 to just move up to newer tech, but i'm not sure if i should buy one or just go grab a n66u now. Also need it soon since my linksys can't handle it xD.
=( im so lost at the moment so which router to buy. I recently returned my all in ubee modem back to timewarner and moved to a sb6141, but my old wrt54g can't handle the 50/5 speeds. Originally was set on buying an AC68 to just move up to newer tech, but i'm not sure if i should buy one or just go grab a n66u now. Also need it soon since my linksys can't handle it xD.
They either pulled it, or it hasn't been fully propagated to all mirrors yet. Just give them some time.
There's a flood of second generation 820.11ac coming out these days. My advice is to wait a few weeks and see how things look like once the dust settle. By then you might also determine that you don't need 802.11ac support, or it won't fit your budget.
An RT-N66U would be more than enough to support your 50/5 connection if wireless isn't a priority. An RT-N16 would be too, but I'd recommend going with dual band if you can afford it.
I managed to nab it off a mirror and it fixed the weird issue I was seeing where my 5gz ssid was failing to connect after a while.
Hi All, if you don't mind I would like to get into this discussion to find out if the RT-AC68U is worth the upgrade from the RT-N66U.
I have the AC68U now and I am using it, upgrade from the N66U. I do notice an increased Wifi coverage by checking the signal with a mobile app versus the N66U. I have the router in the basement and just wanted better coverage if say I connect a device in on the first floor, in the yard or just close by the house. I guess I'm just trying to justify if I did the right thing in buying this upgrade...
Or should I return it and go for the Netgear R7000 based on another members review?
Oh and by the way the xxxxx.217 version for the AC68U breaks IPv6 connectivity as for what I have seen as I have down graded to xxxx.205 version and all is well again.
Welcome To SNBForums
