RT-AC86U 1024MB RAM support.
Have a look at release/src-rt-5.02hnd/kernel/linux-4.1/arch/sh/mm/Kconfig:
Bash:
config MEMORY_SIZE
    hex "Physical memory size"
    default "0x04000000"
    help
      This sets the default memory size assumed by your SH kernel. It can
      be overridden as normal by the 'mem=' argument on the kernel command
      line. If unsure, consult your board specifications or just leave it
      as 0x04000000 which was the default value before this became
      configurable.
There may also be other places to look at in the code:
How can it be that the error pops up at exactly above 1GB? It just doesn't seem like an arbitrary location.
Dont know )
This code in CFE get error
out: XXX ERROR test_size=1G
C++:
    base_addr = (volatile uint32_t*)DRAM_BASE_NOCACHE;
    xprintf("XXX START TEST");
    for (test_size = 128*1024*1024; test_size < memsize ; test_size +=4) {
        test_addr = (volatile uint32_t*)((uintptr_t)base_addr + test_size);
        *test_addr = test_size;
        if(test_size%4096 == 0){
                xprintf("XXX test_size=%d\n\r", test_size);
    xprintf("XXX START TEST 0");
        if(*test_addr != test_size){
                xprintf("XXX ERROR test_size=%d\n\r", test_size);
                break;
Sorry, I must be looking at a different code base:
Diff:
Searching 268587 files for "DRAM_BASE_NOCACHE"
/Volumes/Files/asuswrt-merlin.ng/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl1_ddr_cinit.c:
  523
  524      memsize = memsize<<17;
  525:     base_addr = (uint32*)DRAM_BASE_NOCACHE;
  526
  527      for (test_size = 256; test_size < memsize ; test_size = test_size << 1) {
  969      {
  970          uint32_t val = 0, i;
  971:         uint32_t* addr = (uint32*)DRAM_BASE_NOCACHE, *temp;
  972
  973          for( temp = addr, i = 0; i < 1024; i++ )
/Volumes/Files/asuswrt-merlin.ng/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_cinit.c:
  280
  281      memsize = memsize<<17;
  282:     base_addr = (volatile uint32_t*)DRAM_BASE_NOCACHE;
  283
  284      for (test_size = 256; test_size < memsize ; test_size = test_size << 1) {
  310      uint32_t data;
  311
  312:     addr  = (volatile uint32_t*)DRAM_BASE_NOCACHE;
  313      for( temp = addr, i = 0; i < 1024; i++ )
  314         *temp++ = i;
 1052      params.edis_info = 1;
 1053      params.mem_test_size_bytes = SHMOO_TEST_SIZE;      // test size for SHMOO
 1054:     params.phys_mem_test_base = DRAM_BASE_NOCACHE; // test physical address base for SHMOO
 1055      params.phys_memc_reg_base = (MEMC_BASE);
 1056      params.phys_phy_reg_base = ((uint32_t)((uintptr_t)&MEMC->PhyControl));
/Volumes/Files/asuswrt-merlin.ng/release/src-rt-5.02hnd/cfe/cfe/arch/mips/board/bcm63xx_rom/src/bcm63xx_impl1_ddr_cinit.c:
  665      uint32_t options = 0;
  666      uint32_t* temp;
  667:     uint32_t* addr = (uint32_t*)DRAM_BASE_NOCACHE;
  668      int i;
  669
/Volumes/Files/asuswrt-merlin.ng/release/src-rt-5.02hnd/cfe/cfe/board/bcm63xx_rom/src/bcm63xx_main.c:
  174      int res = 0;
  175
  176:     mem_base = (uint32*)DRAM_BASE_NOCACHE;
  177
  178      *mem_base = 0;
/Volumes/Files/asuswrt-merlin.ng/release/src-rt-5.02hnd/shared/opensource/include/bcm963xx/bcm_hwdefs.h:
   73  */
   74  #define DRAM_BASE           PHYS_DRAM_BASE
   75: #define DRAM_BASE_NOCACHE   PHYS_DRAM_BASE
   76  #else
   77  #define DRAM_BASE           (0x80000000 | PHYS_DRAM_BASE)   /* cached DRAM */
   78: #define DRAM_BASE_NOCACHE   (0xA0000000 | PHYS_DRAM_BASE)   /* uncached DRAM */
   79  #endif
   80  /* Binary images are always built for a standard MIPS boot address */
/Volumes/Files/asuswrt-merlin.ng/release/src-rt-6.x.4708/cfe/cfe/arch/mips/board/bcm96345/include/board.h:
   75  /*****************************************************************************/
   76  #define DRAM_BASE           (0x80000000 | PHYS_DRAM_BASE)   /* cached DRAM */
   77: #define DRAM_BASE_NOCACHE   (0xA0000000 | PHYS_DRAM_BASE)   /* uncached DRAM */
   78  #define FLASH_BASE          (0xA0000000 | PHYS_FLASH_BASE)  /* uncached Flash  */
   79
/Volumes/Files/asuswrt-merlin.ng/release/src-rt-6.x.4708/cfe/cfe/arch/mips/board/bcm9635x/include/board.h:
   46  /*****************************************************************************/
   47  #define DRAM_BASE           (0x80000000 | PHYS_DRAM_BASE)   /* cached DRAM */
   48: #define DRAM_BASE_NOCACHE   (0xA0000000 | PHYS_DRAM_BASE)   /* uncached DRAM */
   49  #define FLASH_BASE          (0xA0000000 | PHYS_FLASH_BASE)  /* uncached Flash  */
   50  #define BCM42xx_BASE        (0xA0000000 | PHYS_BCM42xx_BASE)
/Volumes/Files/asuswrt-merlin.ng/release/src-rt-7.x.main/src/cfe/cfe/arch/mips/board/bcm96345/include/board.h:
   79
/Volumes/Files/asuswrt-merlin.ng/release/src-rt-7.x.main/src/cfe/cfe/arch/mips/board/bcm9635x/include/board.h:
13 matches across 9 files
2GB will not work
CS1# has no contact
THE END
Compiled CFE with 2GB support
DDR test successfully but linux not started, without any error
modification
git diff ../../../cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_cinit.c
diff --git a/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_cinit.c b/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_cinit.c
index 4dcc9096d1..130b01ac18 100644
--- a/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_cinit.c
+++ b/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_cinit.c
@@ -641,7 +641,7 @@ static void init_memc_dram_profile(unsigned int* pMCB)
     memc_dram_profile.ddr_2T_mode  = (pMCB[MCB_2T_MODE_WORD] & MCB_2T_MODE_MASK) >> MCB_2T_MODE_SHIFT;
     memc_dram_profile.ddr_hdp_mode = (memc_dram_profile.total_width_bits == 16);
     memc_dram_profile.large_page   = 1;
-    memc_dram_profile.ddr_dual_rank = 0;
+    memc_dram_profile.ddr_dual_rank = (memc_dram_profile.total_size_Mbits == 16384) ? 1: 0;
     memc_dram_profile.timing_cfg.tRAS =  (pMCB[MCB_TIMING0_WORD] & MCB_TIMING0_tRAS_MASK) >> MCB_TIMING0_tRAS_SHIFT;
     memc_dram_profile.timing_cfg.tCwl =  (pMCB[MCB_TIMING1_WORD] & MCB_TIMING1_tCWL_MASK) >> MCB_TIMING1_tCWL_SHIFT;
git diff ../../../cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_mcb.c
diff --git a/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_mcb.c b/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_mcb.c
index 6115960910..2c518869a6 100644
--- a/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_mcb.c
+++ b/release/src-rt-5.02hnd/cfe/cfe/arch/arm/board/bcm63xx_rom/src/bcm63xx_impl2_ddr_mcb.c
@@ -125,6 +125,11 @@ mcbindex MCB[]  = {
         BP_DDR_SPEED_MASK | BP_DDR_TOTAL_SIZE_MASK | BP_DDR_DEVICE_WIDTH_MASK | BP_DDR_TOTAL_WIDTH_MASK | BP_DDR_SSC_CONFIG_MASK,
         mcb_4908A_800MHz_16b_dev8Gx16_DDR3_1600K_ssc_1per
+        BP_DDR_SPEED_800_11_11_11 | BP_DDR_TOTAL_SIZE_2048MB| BP_DDR_DEVICE_WIDTH_16 | BP_DDR_TOTAL_WIDTH_16BIT | BP_DDR_SSC_CONFIG_1,
+        BP_DDR_SPEED_MASK | BP_DDR_TOTAL_SIZE_MASK | BP_DDR_DEVICE_WIDTH_MASK | BP_DDR_TOTAL_WIDTH_MASK | BP_DDR_SSC_CONFIG_MASK,
+        mcb_4908A_800MHz_16b_dev8Gx16_DDR3_1600K_ssc_1per
         BP_DDR_SPEED_800_11_11_11 | BP_DDR_TOTAL_SIZE_1024MB| BP_DDR_DEVICE_WIDTH_16 | BP_DDR_TOTAL_WIDTH_32BIT | BP_DDR_SSC_CONFIG_1,
OUTPUT
BTRM
V1.6
CPU0
L1CD
MMUI
MMU7
DATA
ZBBS
MAIN
OTP?
OTPP
USBT
NAND
IMG?
IMGL
UHD?
UHDP
RLO?
RLOP
UBI?
UBIP
PASS
HELO
1.23-1.0.38-161.122
CPU0
L1CD
MMUI
MMU8
CODE
ZBBS
MAIN
NVRAM memcfg 0x1627
MCB chksum 0xa8b35841, config 0x1627
MemsysInit lpf0_generic_aarch64 1.3.0.1 20150910
DDR3
90001328 80018000 8001A000 00000000 00000000 0060371A
MCB rev=0x00040301 Ref ID=0x0371A Sub Bld=0x006
Dram Timing 11-11-11
DDR3-1600 CL11 total 2048MB 1 16bits part[s] %1 SSC
Add/Ctl Alignment
no adjustment
ZQ Cal LP PHY
R in Ohm
P: Finger=0x2D0 Term=0x78 Drv=0x2A
N: Finger=0x2D0 Term=0x78 Drv=0x2A
PLL Ref(Hz)=0x02FAF080 UI STEPS=0x03A
DDR CLK(MHz)=0x31B WL CLK dly(ps)=0x0C8 bitT(ps)=0x274 VDLsize(fs)=0x2A4B CLK_VDL=0x01A
SHMOO 28nm
8001A000 80018800 00000000 00020000 00000000
Shmoo WL
One UI Steps : 0x45
auto-clk result = 00E (filter=0C steps)
initial CLK shift = 01A
final CLK shift   = 00E
   000000000011111111112222222222333333333344444444445555555555666666666
   012345678901234567890123456789012345678901234567890123456789012345678
00 S-----------X+++++++++++++++++++++++++++++++++++++++++++++++++++++++-
01 S------------------------X+++++++++++++++++++++++++++++++++++++++++++
Shmoo RD En
FORCED WR ODT = 0x18001800
DQSN DRIVE PAD CONTROL (from) (to)
B0 00031A31 00079A31
B1 00031A31 00079A31
B0 RISE UI=1 VDL=2B PICK UI=2 VDL=2B
B1 RISE UI=1 VDL=15 PICK UI=2 VDL=15
00 --S----------------------------------------X+++++++++++++++++++++++++
Shmoo RD DQ NP
DQS :
B0 VDL=3A ok
B1 VDL=3A ok
00 ---+++++++++++++++++++++++X++++++++++++++++++++++++------------------
Shmoo RD DQ P
00 --++++++++++++++++++++++++X+++++++++++++++++++++++++-----------------
01 ------+++++++++++++++++++++++X++++++++++++++++++++++++---------------
02 --++++++++++++++++++++++++X+++++++++++++++++++++++++-----------------
Shmoo RD DQ N
00 ---+++++++++++++++++++++++++X+++++++++++++++++++++++++---------------
01 ------+++++++++++++++++++++++++X++++++++++++++++++++++++++-----------
RD DQS adjustments :
BL0: Start: 0x3A Final: 0x3A
BL1: Start: 0x3A Final: 0x3A
Shmoo WR DQ
00 ---+++++++++++++++++++++++X+++++++++++++++++++++++-------------------
01 ------++++++++++++++++++++++++X++++++++++++++++++++++++--------------
Shmoo WR DM
WR DM
00 ------++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
01 --+++++++++++++++++++++++++++X+++++++++++++++++++++++++++------------
DDR test done successfully
FPS0
PAR0
J026
JFFS
BT26
0008
PAR1
J025
JFFS
BT25
0768
TRY0
NAN3
JFS2
RFS1
JFFS
JFS2
NAN5
Base: 1.2_3
CFE version 1.0.38-161.122 for BCM94908 (64bit,SP,LE)
Build Date: Thu 01 Apr 2021 12:25:07 PM EDT (evg@evgasus)
Copyright (C) 2000-2015 Broadcom Corporation.
Boot Strap Register:  0x6fc42
Chip ID: BCM4906_A0, Broadcom B53 Quad Core: 1800MHz
Total Memory: 2147483648 bytes (2048MB)
Status wait timeout: nandsts=0x50000000 mask=0x40000000, count=0
NAND ECC BCH-4, page size 0x800 bytes, spare size used 64 bytes
NAND flash device: , id 0xc2da block 128KB size 262144KB
pmc_init:PMC using DQM mode
pmc_init slow 95, fast 70
pmc_init:7 0 264047c 33a0337
nand_flash_read_buf(): Attempt to read bad nand block 1992
Skip Rescue Mode
Board IP address                  : 192.168.1.1:ffffff00
Host IP address                   : 192.168.1.100
Gateway IP address                :
Run from flash/host/tftp (f/h/c)  : f
Default host run file name        : vmlinux
Default host flash file name      : bcm963xx_fs_kernel
Boot delay (0-9 seconds)          : 1
Boot image (0=latest, 1=previous) : 0
Default host ramdisk file name    :
Default ramdisk store address     :
Default DTB file name             :
Board Id                          : 94906REF
Number of MAC Addresses (1-64)    : 10
Base MAC Address                  : 04:d4:c4:1b:1f:48
PSI Size (1-128) KBytes           : 128
Enable Backup PSI [0|1]           : 0
System Log Size (0-256) KBytes    : 0
Auxillary File System Size Percent: 0
flow memory allocation (MB)       : 14
buffer memory allocation (MB)     : 32
DHD 0 memory allocation (MB)      : 0
DHD 1 memory allocation (MB)      : 14
DHD 2 memory allocation (MB)      : 0
WLan Feature                      : 0x00
Partition 1 Size (MB)             : 8M
Partition 2 Size (MB)             : 48M
Partition 3 Size (MB)             : 0M
Partition 4 Size (MB) (Data)      : 8M
Initalizing switch low level hardware.
pmc_switch_power_up: Rgmii Tx clock zone1 enable 1 zone2 enable 1.
Software Resetting Switch ... Done.
Waiting MAC port Rx/Tx to be enabled by hardware ...Done
Disable Switch All MAC port Rx/Tx
*** Press any key to stop auto run (1 seconds) ***
Auto run second count down: 0
Booting from latest image (address 0x00100000, flash offset 0x00100000) ...
Decompression LZMA Image OK!
Entry at 0x0000000000080000
Starting program at 0x0000000000080000
/memory = 0x80000000
Hi, how do you build the CFE firmware ?
i just tried to build a custom rt-ac86u fw with some debug printf in cfe code. But i found out the cfe.bin in output was simply copied from a prebuilt folder ( "targets/cfe/sysdeps/RT-AC86U" )
Build CFE
rm -rf asuswrt-merlin.ng-build
cp -a asuswrt-merlin.ng/ asuswrt-merlin.ng-build
# fix symlinks for HND toolchain
rm -rf ~/asuswrt-merlin.ng-build/release/src-rt-5.02hnd/bcmdrivers/broadcom/net/wl/impl51/main/src/toolchains
ln -s ~/am-toolchains/brcm-arm-hnd ~/asuswrt-merlin.ng-build/release/src-rt-5.02hnd/bcmdrivers/broadcom/net/wl/impl51/main/src/toolchains
# fix symlinks for ARM toolchain
rm -rf ~/asuswrt-merlin.ng-build/release/src-rt-6.x.4708/toolchains
ln -s ~/am-toolchains/brcm-arm-sdk ~/asuswrt-merlin.ng-build/release/src-rt-6.x.4708/toolchains
export LD_LIBRARY_PATH=/opt/toolchains/crosstools-arm-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/lib
export TOOLCHAIN_BASE=/opt/toolchains
echo $PATH | grep -qF /opt/toolchains/crosstools-arm-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin || export PATH=$PATH:/opt/toolchains/crosstools-arm-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin
echo $PATH | grep -qF /opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin || export PATH=$PATH:/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin
cd ~/asuswrt-merlin.ng-build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom
export BRCM_CHIP=4908
export BRCM_VERSION="1"
export BRCM_RELEASE="2"
export BRCM_EXTRAVERSION="\"3\""
make BRCM_CHIP=4908 BLD_NAND=1
ls -la cfe4908rom.bin
ls -la ../bcm63xx_ram/cfe4908.bin
ls -la ../bcm63xx_ram/cfe4908ram.bin
Build CFE
Very Helpful, but i still meet some error.
After build success for full rom
Bash:
docker@6629d9866e60:/build/release/src-rt-5.02hnd/$ make rt-ac86u
i tried to build cfe rom.
Bash:
docker@6629d9866e60:/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom$ export
declare -x BRCM_CHIP="4908"
declare -x BRCM_EXTRAVERSION="3"
declare -x BRCM_RELEASE="2"
declare -x BRCM_VERSION="1"
declare -x LD_LIBRARY_PATH=":/opt/toolchains/crosstools-arm-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/lib"
declare -x PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/toolchains/crosstools-arm-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin:/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin"
declare -x TOOLCHAIN_BASE="/opt/toolchains"
this is the result
Bash:
docker@6629d9866e60:/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom$ make BRCM_CHIP=4908 BLD_NAND=1
echo "char *_binArrayStart = (char *) 0, *_binArrayEnd = (char *) 0;" > noflashimg.c;
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-gcc -I. -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/arch/arm/common/include -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/arch/arm/cpu/armv8/include -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/board/bcm63xx_rom/include -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/board/common/include -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/arch/arm/board/bcm63xx_rom/include -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/arch/arm/board/bcm63xx_shared/include -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/include -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/pci -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/net -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/board/bcm63xx_ram/include -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../../shared/opensource/include/bcm963xx -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../../shared/broadcom/include/bcm963xx -I../../../cfe/sha256 -I../../../cfe/aes128 -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../../shared/opensource/include/bcm963xx/../pmc -I/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../../shared/opensource/include/bcm963xx/../rdp -D_CFE_ -DCFE_VER_MAJ=1 -DCFE_VER_MIN=0 -DCFE_VER_ECO=38 -DCFG_BOARDNAME=\""BCM94908"\" -DBRCM_VERSION="\"1\"" -DBRCM_RELEASE="\"2\"" -DBRCM_EXTRAVERSION="\"3\"" -DCFE_VER_MAJ_STR="\"1\"" -DCFE_VER_MIN_STR="\"0\"" -DCFE_VER_ECO_STR="\"38\"" -DCFE_MAJOR_STR="\"161\"" -DCFE_MINOR_STR="\"122\"" -fdata-sections -ffunction-sections -DCFE_ABORT_KEY=1 -DINC_BTRM_BOOT=0 -DINC_BTRM_BUILD=0 -DINC_CFI_FLASH_DRIVER=0 -DINC_SPI_FLASH_DRIVER=0 -DINC_NAND_FLASH_DRIVER=1 -DINC_SPI_PROG_NAND=0 -DINC_SPI_NAND_DRIVER=1 -DINC_PMC_DRIVER=1 -DCFG_COPY_PSRAM=0         -DCFG_BOOT_PSRAM=0         -DCFG_ROM_PRINTF=1 -DBOOT_PRE_CFE=0 -DCONFIG_ARM64 -DCFG_ARMV8_AARCH64 -march=armv8-a -mtune=cortex-a53 -mstrict-align -D__ARMEL__ -DCFG_ZLIB=1 -DMY_ZCALLOC -DNO_MEMCPY -gdwarf-2 -c -fno-builtin -ffreestanding -Wall -Werror -Wstrict-prototypes -fno-stack-protector -fno-delete-null-pointer-checks -Wframe-larger-than=2560 -Os -mabi=lp64 -D__long64 -DCFG_BOOTRAM=0 -D_BCM94908_ -o noflashimg.o noflashimg.c
make -C ../bcm63xx_ram
make[1]: Entering directory '/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_ram'
make -C ../../../../hostTools build_cmplzma
make[2]: Entering directory '/build/release/src-rt-5.02hnd/hostTools'
if [ ! -e lzma457/lzma.txt ]; then \
echo Untarring lzma 4.57 source...; \
(tar xkfj lzma457.tar.bz2 2> /dev/null || true); \
fi
building lzma host tool ...
make -C /build/release/src-rt-5.02hnd/hostTools/lzma457/CPP/7zip/Compress/LZMA_Alone -f makefile.gcc
make[3]: Entering directory '/build/release/src-rt-5.02hnd/hostTools/lzma457/CPP/7zip/Compress/LZMA_Alone'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/build/release/src-rt-5.02hnd/hostTools/lzma457/CPP/7zip/Compress/LZMA_Alone'
cp -f /build/release/src-rt-5.02hnd/hostTools/lzma457/CPP/7zip/Compress/LZMA_Alone/lzma lzmacmd
g++   -O2 -DGNU -I/bcm963xx -I/bcm963xx -I.  -c cmplzma.cpp
cmplzma.cpp: In function ‘int main(int, char**)’:
cmplzma.cpp:452:27: warning: ‘%s’ directive writing between 3 and 4 bytes into a region of size between 0 and 255 [-Wformat-overflow=]
  452 |     sprintf(lzmaFile, "%s.%s", inputBinFile,lz4 ? "lz4":"lzma");
In file included from /usr/include/stdio.h:867,
                 from cmplzma.cpp:74:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:36:34: note: ‘__builtin___sprintf_chk’ output between 5 and 261 bytes into a destination of size 256
   36 |   return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1,
   37 |       __bos (__s), __fmt, __va_arg_pack ());
g++  -o cmplzma cmplzma.o -lm
make[2]: Leaving directory '/build/release/src-rt-5.02hnd/hostTools'
find ../../../../shared -name "*.o" -exec rm -f "{}" ";"
find ../../../../shared/opensource/boardparms/bcm963xx -name "*.o" -exec rm -f "{}" ";"
make cfe4908
make[2]: Entering directory '/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_ram'
make[2]: *** No rule to make target 'bcm63xx_devs.o', needed by 'cfe4908'.  Stop.
make[2]: Leaving directory '/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_ram'
make[1]: *** [Makefile:304: ALL] Error 2
make[1]: Leaving directory '/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_ram'
make: *** [Makefile:258: cfe4908] Error 2
on 384.19 work
on new dosnt work
bcm63xx_devs.c - this file dosnt exist at all )))
After checkout to Tag "384.19-mainline". Still failed when trying to build CFE binary
For error
Bash:
So, I modified "src-rt-5.02hnd/cfe/cfe/board/bcm63xx_ram/src/Makefile", remove the line "bcm63xx_devs.o \"
Makefile:
BSPOBJS +=              \
    dev_bcm63xx_flash.o \
    flash_api.o         \
    flash_common.o      \
    bcm63xx_devs.o      \
    bcm63xx_board.o     \
    bcm63xx_cmd.o       \
Then another error comes up.
Bash:
/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_ram/../../../cfe/board/bcm63xx_ram/src/bcm63xx_main.c:579: undefined reference to 'board_console_init'
/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_ram/../../../cfe/board/bcm63xx_ram/src/bcm63xx_main.c:631: undefined reference to 'board_device_init'
/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_ram/../../../cfe/board/bcm63xx_ram/src/bcm63xx_main.c:637: undefined reference to 'board_final_init'
bcm63xx_httpd.o: In function `cfe_web_fg_process':
/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_ram/../../../cfe/board/bcm63xx_ram/src/bcm63xx_httpd.c:221: undefined reference to 'softReset'
./libcfe.a(exchandler.o): In function 'cfe_exception':
/build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_ram/../../../cfe/arch/arm/common/src/exchandler.c:142: undefined reference to 'softReset'
make[2]: *** [Makefile:339: cfe4908] Error 1
It seems relation to bcm63xx_devs.c, but there is no bcm63xx_devs.c as you said.
After searches in github, I found bcm63xx_devs.c in this repo blackfuel/asuswrt-rt-ac86u
So, i simply copied bcm63xx_devs.c to "cfe/cfe/board/bcm63xx_ram/src" and revert the change "src-rt-5.02hnd/cfe/cfe/board/bcm63xx_ram/src/Makefile"
And build again.
Dala ~~~~, seems succeed. But I haven't build a full rom with this CFE binary.
I' try to do that later.
Bash:
make cfe4908
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-gcc -gdwarf-2 -c -fno-builtin -ffreestanding -Wall -Werror -Wstrict-prototypes -fno-stack-protector -fno-delete-null-pointer-checks -Wframe-larger-than=2560 -O0 -mabi=lp64 -D__long64 -DCFG_RAMAPP=1 -I. -I../../../cfe/arch/arm/common/include -I../../../cfe/arch/arm/cpu/armv8/include -I../../../cfe/board/bcm63xx_ram/include -I../../../cfe/board/common/include -I../../../cfe/board/bcm63xx_rom/include -I../../../cfe/arch/arm/board/bcm63xx_ram/include -I../../../cfe/arch/arm/board/bcm63xx_shared/include -I../../../cfe/include -I../../../cfe/pci -I../../../cfe/net -I../../../cfe/fdt -I../../../../shared/opensource/include/bcm963xx -I../../../../shared/broadcom/include/bcm963xx -I../../../../shared/opensource/include/bcm963xx/../pmc -I../../../cfe/sha256 -I../../../cfe/aes128 -I../../../cfe/otp -D_CFE_ -DCFE_VER_MAJ=1 -DCFE_VER_MIN=0 -DCFE_VER_ECO=38 -DCFG_BOARDNAME=\""BCM94908"\" -DCONFIG_MIPS_BRCM -DINC_CFI_FLASH_DRIVER=0 -DINC_SPI_FLASH_DRIVER=0 -DINC_NAND_FLASH_DRIVER=1 -DINC_SPI_PROG_NAND=0 -DINC_SPI_NAND_DRIVER=1 -DINC_BTRM_BOOT=0 -DINC_PMC_DRIVER=1 -DCFG_COPY_PSRAM=0         -DINC_KERMIT=0 -DCFG_BOOT_PSRAM=0         -DNONETWORK=0 -DSKIP_FLASH=0           -DBPCM_CFE_CMD=0     -DCFG_DT -DCFG_TCP -DCFG_WEB_SERVER=1 -fdata-sections -ffunction-sections  -DCONFIG_ARM64 -DCFG_ARMV8_AARCH64 -march=armv8-a -mtune=cortex-a53 -mstrict-align -D__ARMEL__ -D_BCM94908_ -D_BUILDDATE_="\"Tue Nov 16 17:32:04 UTC 2021\"" -D_BUILDUSER_="\"docker@6629d9866e60\"" -DBRCM_VERSION=1 -DBRCM_RELEASE=2 -DBRCM_EXTRAVERSION="\"3\"" -DCFG_DTB_IMAGE="\"94908.dtb\""  -o bcm63xx_devs.o ../../../cfe/board/bcm63xx_ram/src/bcm63xx_devs.c
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-ld -o cfe4908 -Map cfe4908.map -g --script ../../../cfe/arch/arm/common/src/cfe_aarch64.lds -Ttext 0x01000000 --gc-sections init_arm_aarch64.o exception_aarch64.o bcm63xx_ipc.o dev_bcm63xx_uart.o bcmSpiRes.o bcmLegSpi.o bcm_pinmux_impl1.o bcm_misc_hw_init_impl6.o bcm_gpio_impl1.o bcm_led_impl1.o bcm_otp_impl1.o pmc_drv.o dev_bcm63xx_eth.o bcm_ethsw_impl1.o pmc_switch.o     dev_bcm63xx_flash.o flash_api.o flash_common.o bcm63xx_devs.o bcm63xx_board.o bcm63xx_cmd.o bcm63xx_blparms.o boardparms.o bp_funcs.o boardparms_voice.o shared_utils.o bcm63xx_util.o bcm63xx_ldr_raw.o bcm63xx_ldr_elf.o bcm63xx_main.o bcm63xx_env_subr.o bcm63xx_httpd.o bcm63xx_nvram.o bcm63xx_net_icmp.o bcm_ubi.o bcmHsSpi.o         nandflash.o spinandflash.o ul.o ulinfo.o bcm63xx_dtb.o bcm63xx_impl2_common.o bcm63xx_impl2_otp.o bcm63xx_impl2_smp.o bcm63xx_rsa.o bcm63xx_sha.o bcm63xx_auth_if.o bcm63xx_sotp_if.o bcm63xx_potp_sotp_cmd.o  -L. -lcfe -L /am-toolchains/brcm-arm-hnd/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/../lib/gcc/aarch64-buildroot-linux-gnu/5.3.0 -lgcc
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-objdump -d cfe4908 > cfe4908.dis
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-objcopy --output-target=binary cfe4908 cfe4908.bin
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-objcopy --output-target=srec --srec-forceS3 -R .reginfo -R .note -R .comment -R .mdebug -S cfe4908 cfe4908.srec
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-objdump -x cfe4908 | ../../../../hostTools/mkCfeHeader  cferamhdr.bin
format='elf64-littleaarch64'
start 1000000
load 1000000
sz 58c10
cat cferamhdr.bin cfe4908.bin > cfe4908ram.bin
rm cferamhdr.bin
../../../../hostTools/cmplzma -c -2 -lzma cfe4908 cfe4908.bin ../bcm63xx_rom/flashimg.S
using LZMA compression
Code text starts: textAddr=0x01000000  Program entry point: 0x01000000,
../../../../hostTools/lzmacmd e cfe4908.bin cfe4908.bin.lzma -d22 -lp2 -lc1
LZMA 4.57  Copyright (c) 1999-2007 Igor Pavlov  2007-12-06
Before compression: 350146  After compression (level=2): 87144
Percent Compression = 75.11
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-ld -o cfe4908rom -Map cfe4908rom.map --gc-sections -g --script /build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/arch/arm/common/src/cfe_aarch64.lds -Ttext 0x90000000 init_arm_aarch64.o exception_aarch64.o bcm63xx_ipc.o nandflash.o bcm_ubi.o bcmSpiRes.o bcmHsSpi.o spinandflash.o bcm_otp_impl1.o bcm63xx_main.o  bcm63xx_impl2_rom_boot.o bcm63xx_impl2_ddr_cinit.o bcm63xx_impl2_ddr_mcb.o bcm63xx_impl2_common.o bcm63xx_impl2_otp.o bcm63xx_impl2_smp.o bcm63xx_aes.o bcm63xx_encr_if.o LzmaDecode.o dcapi.o bcm63xx_rsa.o bcm63xx_sha.o bcm63xx_auth_if.o noflashimg.o -L. -lcfe -L /build/release/src-rt-5.02hnd/cfe/build/broadcom/bcm63xx_rom/../../../cfe/arch/arm/board/bcm63xx_rom/src -lmemsysinitlib_impl2 -L /am-toolchains/brcm-arm-hnd/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/../lib/gcc/aarch64-buildroot-linux-gnu/5.3.0 -lgcc
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-objdump -d cfe4908rom > cfe4908.dis
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-objcopy --output-target=binary cfe4908rom cfe4908rom.bin
/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin/aarch64-buildroot-linux-gnu-objcopy --output-target=srec -R .reginfo -R .note -R .comment -R .mdebug -S cfe4908rom cfe4908.srec
rm noflashimg.*
done
good
git checkout 384.19
work for me
find . -name bcm63xx_devs.c
./asuswrt-merlin.ng/release/src-rt-5.02hnd/cfe/cfe/board/bcm63xx_ram/src/bcm63xx_devs.c
good
git checkout 384.19
work for me
oops, our source code maybe different .....
This is what i got. when checkout to Tag @ 384.19
Bash:
hpo14 @ ~/.../ac86/docker/asuswrt-merlin.ng (build-cfe) $ git tag -l | grep 384.19
384.19
384.19-ax
384.19-beta1
384.19-beta1-ax
384.19-beta1-mainline
384.19-beta2
384.19-beta2-ax
384.19-beta2-mainline
384.19-mainline
hpo14 @ ~/.../ac86/docker/asuswrt-merlin.ng (build-cfe) $ git checkout 384.19
Checking out files: 100% (101458/101458), done.
Note: checking out '384.19'.
HEAD is now at 8c72854f4d bump revision to 384.19 final
hpo14 @ ~/.../ac86/docker/asuswrt-merlin.ng ((384.19)) $ find . -iname "bcm63xx_devs.*"
its realy bcm63xx_devs.c dosnt exist ))
but on may old source
evg@evgasus:~/asuswrt-merlin.ng$ git status
HEAD detached at 384.19
nothing to commit, working tree clean
evg@evgasus:~/asuswrt-merlin.ng$ find . -name bcm63xx_devs.c
./release/src-rt-5.02hnd/cfe/cfe/board/bcm63xx_ram/src/bcm63xx_devs.c
commit b93cd5bb222db1733668e9d89cfca0153880c0d7 (HEAD, tag: 384.19)
Author: Eric Sauvageau <merlin@asuswrt-merlin.net>
Date:   Fri Aug 14 15:09:54 2020 -0400
new source
commit 8c72854f4d1037a5fbab468135143560fee7d80e (HEAD, tag: 384.19)
how is this possible
did the copyright holders delete the source?
new source
Maybe ~
Its magic that the "commit b93cd5bb222db1733668e9d89cfca0153880c0d7 (HEAD, tag: 384.19)" only exist on github's source code but not in the code I downloaded.
Bash:
$ git log --all | grep -B5 "384.19 final"
the old one: asuswrt-merlin.ng/commits/b93cd5b...
the new one: asuswrt-merlin.ng/commits/384.19
in this source bcm63xx_devs.c exist ))
https://github.com/RMerl/asuswrt-merlin.ng/tree/b93cd5bb222db1733668e9d89cfca0153880c0d7
And build again.
I copied the self build CFE binary (cfe4908.bin, cfe4908ram.bin, cfe4908rom.bin) to "targets/cfe/sysdeps/RT-AC86U" to replace the default files.
and make a full build make rt-ac86u with success.
Then flash the custom firmware (RT-AC86U_<version>_cferom_ubi.w) to my RT-AC86U.
With a reboot after a success flash.
My router stuck on LZMA: Prossible old LZMA format, trying to decompress..
BL0: Start: 0x51 Final: 0x53
BL1: Start: 0x51 Final: 0x51
Shmoo WR DQ
Shmoo WR DM
WR DM
I had to do a ton of history rewrites a few months ago to remove files that shouldn't have been there, for licensing reasons.
