spdMerlin spdMerlin - Automated speedtests with graphs
Schedule customisation, what do people want?
  • Option to disable automatic tests
  • Configuration of test frequency
  • Configuration of allowed times for automatic tests
Starting minute within hour (to deconflict with other cron jobs)
So option 2. I'll probably implement cron control of minutes and hours. Will that be sufficient?
I guess I didn't pay too much attention to the first posts. :)
I really thought it would be all of those options.
Ideally?
An example: Run Download only tests between 2 AM to 8 AM every hour at 15 minutes past the hour. :)
But any additional configuration options you provide will be most welcome! :D
Can you try selecting a server in spdmerlin?
Also, what does memory usage look like during a test run?
For testing, should I just let the cron fire off?
Since it seems to affect you both manually and via cron, it shouldn't matter. I did check the code and running a test via the ui doed check for an existing running test before launching
The problem only happens when:
-the cron fires
-the webpage button is pressed
Using option 2 in the menu (preferred server) brings back normal tests as I expect.
Have you enabled preferred server for automatic tests? Option 5 i think
And automatic tests still 0 out with that enabled? It should be no different to a manual run with option 2 at that stage. I'm beginning to suspect the speedtest server is at fault here
I doubt the server is at fault since I've been able to run several successful tests manually without issue. The problem only happens when the speedtest is called by cron. Funnily enough, it was working fine before installing the connmon script, but I think an update came out for this one around the same time. I'm gonna go out on a limb here and say that the update broke something.
The one thing I have yet to attempt is a router reboot, though I don't think that will fix the underlying problem.
As I say, if you've enabled preferred servers for automatic tests, the command issued by cron is identical to the manual option. The next thing to check is your cron list, perhaps something is running at the same time.
 cru l
I have a good feeling it will help. :)
Make sure you do a GUI initiated reboot. ;)
 cru l
15 9 * * Mon service reboot #amtm_RebootScheduler#
*/5 * * * * /jffs/scripts/ntpmerlin generate #ntpMerlin#
00 2 * * Tue sh /opt/share/diversion/file/update-bf.div reset #Diversion_UpdateBF#
20 5 * * * sh /opt/share/diversion/file/rotate-logs.div #Diversion_RotateLogs#
20 17 * * * diversion count_ads count #Diversion_CountAds#
30 3 * * * /jffs/scripts/FreshJR_QOS -check #FreshJR_QOS#
25 3 * * * sh /jffs/scripts/firewall banmalware #Skynet_banmalware#
25 1 * * Mon sh /jffs/scripts/firewall update #Skynet_autoupdate#
0 * * * * sh /jffs/scripts/firewall save #Skynet_save#
*/5 * * * * /jffs/scripts/connmon generate #connmon#
12,42 * * * * /jffs/scripts/spdmerlin generate #spdMerlin#
Nothing amiss there. Can you run option u please, just to make sure the script is intact? It'll md5 check it against the source
