spdMerlin spdMerlin - Automated speedtests with graphs
Third option seems to be best, especially we almost never know fastest server in area of selected vpn server (for example i live in Poland and use Washington and Dallas server for vpn Clients).
Once again - third option is best for me and makes The work much easier.
P.s. I am looking forward to official update of spdmerlin[emoji3]
Feedback wanted! With v3, you can now configure multiple interfaces, e.g. WAN and VPN Client 1. Preferred Server feature was designed when a single interface existed, so in v3 the same server will be used for all tests. While this might be fine for local VPN Servers, a US VPN Server testing against a UK Speedtest site will be slower.
Choice are:
1) Do nothing, the behaviour of a single preferred server for all interfaces is fine
2) Implement a preferred server for each interface
3) Use preferred server only for WAN, VPN interfaces will use an auto-selected server
Please let me know your preference!
Option 2
I may adopt option 3 for the initial release of v3, so that I can actually release it.
I've realised the same scenario applies to the "choose a server" option, and I suspect people might also like to choose select which interface is tested for manual tests
Would be nice to get 3.0 version asap.[emoji1]
With current version i can’t even measure third of my bandwith (1 gbps)
Have huge expectations regarding to newest script!
Not sure how close to 1gbps you'll get with the Ookla binary - have you tried the develop branch?
Choice are:
Option two but happy to go with what works best for you and other users
I am seeing a missing file error on the v3.0 develop branch on RT-AC86U:
Choose an option:    1
cp: can't stat '/jffs/scripts/spdmerlin.d/ookla/speedtest-cli.json': No such file or directory
spdMerlin: Starting speedtest using auto-selected server for WAN interface
   Speedtest by Ookla
     Server: Spectrum - Syracuse, NY (id = 16978)
        ISP: Spectrum
    Latency:    12.67 ms   (0.23 ms jitter)
   Download:   480.76 Mbps (data used: 850.5 MB)
     Upload:    23.15 Mbps (data used: 11.6 MB)
Packet Loss: Not available.
 Result URL: https://www.speedtest.net/result/c/xxxxxxxxxx
spdMerlin: Speedtest results - Download: 480.76 Mbps (data used: 850.5 MB) - Upload: 23.15 Mbps (data used: 11.6 MB)
Press enter to continue...
Any thoughts or suggestions?
Choose an option:    1
   Speedtest by Ookla
        ISP: Spectrum
Hm, that file should have been saved on accepting the speedtest license...found the bug and fixed, good find
Fixed. I reverted to "master", and then reinstalled "develop" after you patched.
ok, I managed it. As mentioned before my net is 1000/60
before update:
spdMerlin: Speedtest results - Download: 267.55 Mbit/s - Upload: 47.86 Mbit/s
after update
spdMerlin: Speedtest results - Download: 246.50 Mbps (data used: 231.0 MB) - Upload: 49.96 Mbps (data used: 64.0 MB)
the same server chosen to perform the test.
asus rt-ax88
Equally it would have worked with the very last commit on develop - it'll check for the license in an old directory and move it, as well as me fixing the logic check of the file to load
before update:
after update
asus rt-ax88
Strange that you see lower perf on an AX88U than I do on an 86U. What happens if you let auto-select work on the new version?
same low results, i think there is some influence of installed scripts(i have owned almost all available scripts on amtm, 2 clients and one open vpn server running) that i have on my router and results obtained via spd merlin.
EDIT:
may it be USB disk speed issue?
EDIT:
Fire up htop while it is running, is CPU or Memory maxxing out? I think this might be a limitation of the current binary as noted by @ColinTaylor
WAN and VPN Speedtest are accurate to within 5 MBs and the WAN and VPN click to expand/collapse graphs under tools puts the cherry on top
Thank you very much [emoji3060]
