spdMerlin spdMerlin - Automated speedtests with graphs
Hey @Jack Yaz, could you please add in a future update graphs retain view settings as in connmon? Thank you! :)
I have just installed this on my RT-AC86U router and I am getting the following error message. Looking at this tread I see others also get this but I could not see a fix. Any help is well appreciated
ERROR:root:code for hash md5 was not found.
Traceback (most recent call last):
File "/opt/lib/python2.7/hashlib.py", line 147, in <module>
File "/opt/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor
ValueError: unsupported hash type md5
ERROR:root:code for hash sha1 was not found.
ValueError: unsupported hash type sha1
ERROR:root:code for hash sha224 was not found.
ValueError: unsupported hash type sha224
ERROR:root:code for hash sha256 was not found.
ValueError: unsupported hash type sha256
ERROR:root:code for hash sha384 was not found.
ValueError: unsupported hash type sha384
ERROR:root:code for hash sha512 was not found.
ValueError: unsupported hash type sha512
File "/jffs/scripts/spdmerlin.d/spdcli.py", line 126, in <module>
from md5 import md5
File "/opt/lib/python2.7/md5.py", line 10, in <module>
ImportError: cannot import name md5
Error: near line 2: near ",": syntax error
from md5 import md5
Try
opkg update
opkg upgrade
and try again
@Jack Yaz, great work with the script.
I wonder if there's known compatibility issues with the AC87U running latest Merlin? For some reason I can't see charts from manual or automatic speed tests.
Thanks in advance for the advice.
v2.0.1
Updated 2019-09-29
This script uses a large amount of RAM/memory when the speedtest is running, and as such a swap file is required
The speedtest is scheduled to run at 12 past and 42 past the hour, every hour, by default
Regarding speeds not necessarily matching browser-based tests, please see https://github.com/sivel/speedtest-cli#inconsistency
Run automated speedtests for your Internet on your router with graphs available on the Tools page of the WebUI.
This script serves as a user-friendly installer for a personal project developed by @JGrana
Permission received from @JGrana to publish this!
spdMerlin is free to use under the GNU General Public License version 3 (GPL 3.0).
spdMerlin uses speedtest-cli
This project is hosted on GitHub
Love the script and want to support future development? Any and all donations gratefully received! PayPal donation
Supported Models
Models
All modes supported by Asuswrt-Merlin. Models confirmed to work are below:
  • RT-AC68U
  • RT-AC86U
  • RT-AC3100
Firmware versions
You must be running firmware no earlier than 384.XX Asuswrt-Merlin
Installation
Using your preferred SSH client/terminal, copy and paste the following command, then press Enter:
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/spdMerlin/master/spdmerlin.sh" -o "/jffs/scripts/spdmerlin" && chmod 0755 /jffs/scripts/spdmerlin && /jffs/scripts/spdmerlin install
Usage
To launch the spdMerlin menu after installation, use:
spdmerlin
If this does not work, you will need to use the full path:
Updating
Launch spdmerlin and select option u
Hello,
How do I configure spdmerlin to test against the vpn server I'm connected to, and NOT the local servers geographically nearest to me?
Thanks to all.
Hello, I'm playing with 2.0.1 and comparing results using same server with speedtest site. Download might have similar results (around 300 mbits/sg) but upload keeps getting below 40 mbits/sg. I'm getting the expected values at speedtest (around 300 mbits/sg)
any clue about the problem?
thanks
Hello - installed on 68u. Works fine from commandline but graphs are empty. Waited 24 hours but still no detain graphs under tools -> speediest page. Is there a log file of all the tests that tool ran in last 24 hours, that could be checked?
have you checked if the automated speed tests are enabled?
Here is what I see when i run spdMerlin script.
oggle automatic tests
Currently Enabled
and if i run speediest now.. it works and the data is shown below
Choose an option: 1
spdMerlin: Starting speedtest using auto-selected server in multi-connection mode
spdMerlin: Speedtest results - Download: 162.90 Mbit/s - Upload: 20.46 Mbit/s
Also the menu for auto test shown below
8. Configure schedule for automatic tests
No defined schedule - tests run every hour
Tests will run at 12 and 42 past the hour
check for any console errors on the page in your web browser (f12 tools etc.)
Here is what I see.
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (moment.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (hammerjs.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (chartjs-plugin-zoom.js, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (chartjs-plugin-annotation.js, line 0)
[Error] ReferenceError: Can't find variable: moment
Global Code (spdstatsdata.js:3)
Draw_Chart (AiMesh_Node_FirmwareUpgrade.asp:96)
RedrawAllCharts (AiMesh_Node_FirmwareUpgrade.asp:279)
initial (AiMesh_Node_FirmwareUpgrade.asp:303)
onload (AiMesh_Node_FirmwareUpgrade.asp:318)
Using safari
Here is what I see.
Using safari
Hm, looks like some of the required files are missing
which f/w version are you running?
