Pak Kriss
Check browser console for errors, perhaps I've missed something in the latest update still![]()
Thanks, i know where to look and I'll push a fix ASAP
Please can you try again after using option u?
aka lazy/greedy sed matchingIt's working now. Small things, big impact
https://github.com/jackyaz/spdMerlin/commit/1808947b28038635f097f69ec5885472a91f7bf9
Thank you!
Sent from my SM-T805 using Asus RT-AC86U & Merlin 384.13
Can anyone running the 384.15 alpha, this script, and Skynet only please try the develop branch and let me know if you experience any conflicts with WebUI tab mounting between spdMerlin and Skynet? I've pushed some changes to be compatible, but I'm not able to run alpha firmware on the only router in the house![]()
Make sure you're not using any of my other ui scripts for the time being (connmon, ntpmerlin, uiDivStats) etc.I just reinstalled spdMerlin and it took out the SkyNet tab from the GUI. Uninstalled spdMerlin and rebooted router. Now Skynet tab appears again.
Will try reinstalling spdMerlin again and see what happens.
Ok will unistall ntpMerlin and try again.
sh /jffs/scripts/firewall settings webui enable
I'm out til later tonight and I'll take a look at what is causing this. Maybe best to revert to master and use uf a couple of times
Try running dos2unix spdmerlin.sh first
You need to install entware and a swap file.It worked. But I get new errors:
spdMerlin: Checking your router meets the requirements for spdMerlin
spdMerlin: No Swap file detected!
spdMerlin: Entware not detected!
Thread starter | Title | Forum | Replies | Date |
vnStat Exclude spdMerlin from vnStat reports | Asuswrt-Merlin AddOns | 3 | |
Router Speed Test (spdMerlin) | Asuswrt-Merlin AddOns | 5 |
Welcome To SNBForums
