Oh, what is wrong with AC87U?
Please tell me.
AC88U is way too expensive although i admit 8 LAN ports are useful option.
For many, there is nothing 'wrong' per se. But for others, the RT-AC87U has proven to be less than the ideal router they hoped it would be. The Quantenna (5GHz) chipset implemented in the router has many drawbacks for some folks, often insurmountable. Like I mentioned, you may not have an issue at all with the '87U. But, why take a chance?
You don't need to get an RT-AC88U either. The RT-AC3100 is also in the current 'excellent' range.
But the original RT-AC68U is a more stable router than the RT-AC87U ever was (overall). The latest incarnation of the '68U being the BestBuy RT-AC1900P (with 1.4GHz dual processors and updated RF design) is arguably 'above' the '87U and best of all? It is able to run the latest RMerlin firmware too (use the RT-AC68U trx file).
https://www.google.ca/?gfe_rd=cr&ei=WKkGVsjINIft8weLl7z4CA#q=RT-AC87U+problems
Hi, I am looking for a new router myself. I have basically nothing to upgrade from. I have worked on business network switches and routers. At home I am currently still stuck in the crappy router the provider gave me.
While I was looking into the "best router of 2016". I ran into this AC87U router in nearly every topic.
Now indeed, while I was looking for dd-wrt or merlin support for this router. I found a lot of complaints about the builds not working great, or even 5ghz no longer working, dropouts, ...
Which router would you suggest?
My price range can go as high as the current price for this router and a bit up +- 200 euro, 225$, 170£
The RT-AC3100 or the RT-AC1900P (a Best Buy exclusive right now) is the routers I am recommending to my customers for long term use.
Thread starter | Title | Forum | Replies | Date |
Unrelated but I wanted to share my project. | Asuswrt-Merlin | 3 |
Welcome To SNBForums
