Stubby-Installer-Asuswrt-Merlin
I don't see it.
See below(put a pic incase this formats funny)
 amtm 3.0                  by thelonelycoder
 RT-AC68U (armv7l) FW-384.13 @ 192.168.2.1
 The SNBForum Asuswrt-Merlin Terminal Menu
 1  open     Diversion                 v4.1.6
 2  open     Skynet                    v6.9.2
 3  install  FreshJR - Adaptive QOS
 4  install  YazFi - enhanced guest WiFi
 5  install  scribe - syslog-ng and logrotate
 6  open     x3mRouting                v1.0.4
 j1 install  connmon - Internet uptime monitor
 j2 install  ntpMerlin - NTP Daemon
 j3 install  scMerlin - Quick access control
 j4 install  spdMerlin - Automatic speedtest
 j5 open     uiDivStats                v1.2.3
 j6 install  uiScribe - WebUI for scribe logs
 di install  dnscrypt installer
 ep manage   Entware packages
 ps use      pixelserv-tls CA for WebUI
 dc manage   Disk check script   dcl show log
 fd run      Format disk         fdl show log
 rs enable   Reboot scheduler
 sw manage   Swap file /mnt/usbdrive 2.0G
 i  hide     inactive scripts or tools
 u  check    for script updates
    amtm options
 e  exit      t  theme   r  remove   a  about
_____________________________________________
 Enter option
I don't see it.
    amtm options
 Enter option
Why would you use it when it is built into Merlin 384.13 already?
Question, im using 2 custom DNS servers for geolocked media streaing (netflix, hulu, etc)
Can I use stubby and also those 2 servers?
If I use the stubby script, do I need to have DoT enabled on the router end?
Stubby is part of the firmware and yes enable DoT and choose a server from the list.
Is anyone here having trouble using DoT with cloudflare? My AC86U accepts every predefined DoT serves except fot 1.1.1.1 and 1.0.0.1. I'm using built in DoT functionality on merlin 384.16.
Thanks in advance.
Thanks in advance.
Some older modems use 1.1.1.1 internally, so won't work with cloudflare if they haven't had their firmware updated. You can probably check for a list on the web.
I tried to uninstall stubby using the script and it seems something still remains there.
When Diversion restarts the dnsmasq due to an Unbound update I am getting the following message under the system log.
Apr 20 18:23:18 Diversion: restarted Dnsmasq to apply settings
Apr 20 18:23:18 JUANDOASUS (dnsmasq.postconf): Updating /etc/dnsmasq.conf for unbound.....
Apr 20 18:23:18 JUANDOASUS stubby[402]: Read config from file /etc/stubby/stubby.yml
But stubby shouldn't be there because it was removed. And there router was restarted after it was uninstalled.
Do you know how to completely removed it?
I am running rt-ax88u with the latest Merlin firmware (384.16)
Stubby is built into the Merlin firmware. Only the Entware packages from this script can be uninstalled. The firmware stubby cannot. Are you using DNS Privacy in Merlin? That uses the firmware stubby, which may be why you see the stubby messages still.
Yes, I am using DNS-over-TLS with the Cloudfare servers enabled.
I uninstalled stubby when I saw this is inside of the Melin firmware. And I thought that something went wrong when I removed the script.
Thank you @dave14305.
