uiDivStats uiDivStats - WebUI for Diversion statistics
o_O Not "3" ... as per your notably humorous post in another thread - with reference to the Holy Grail ??? :D
You're the first to get/report the clue :)
@thelonelycoder is @Jack Yaz working with you to get this script working? Or, have you inherited it and will be supporting it in the future? :)
The stats code required some modifcation for the next Diversion release. Since I know the code best I did it and cleaned up the output you see at the top of uiDivStats.
Hi guys
Is there any code to clear statistics?
If you search the forums, there was a post or two that showed how.
If you can be patient, I think it may be coming in a future release. :)
Just a heads up.
Update to the original v0.5.3 version (no version change). 'u' will update as needed. :)
I will be patient as I`we searched a lot and did not found the solution, is not something urgent but nice to have :)
Is it possible to make the script update automatically the stats every hour for example or do we have to log in SSH, generate graph , log into router and so forth.... ?
The script updates every half hour for me. :)
Which router are you using? What firmware? What version of uiDivStats?
Note that there was a silent update about half an hour ago (see my post above).
I have RT-AC86U , I am newbie :) I didn't know it was updating every half an hour... thats great... I will install it again... I thought It was updating weekly or manually .
It's hourly now (or should be)
Jack, I can confirm that uiDivStats runs hourly now. NTP Daemon and Uptime Monitoring tabs are still every 5 minutes. :)
@Delusion, simply CTRL F5 (force update) your browser for the latest stats. :)
Great, checked now and the stats were updated automatically exactly after an hour
The Stats automatically up date on the hour every hour - take a look at your System Log tab.
Make sure you have the latest version.
BIG thank you from me - working perfectly now on both DSL-AC68U and my RT-AC5300. :D
Good to know. Diversion will follow with its stats function as soon as I'm ready for the next release.
