uiDivStats uiDivStats - WebUI for Diversion statistics
@Jack Yaz I just updated 5 routers to the latest uiDivStats (and the silent ntpRmerlin update too) and there was no issue with any at all (2x 'RT-AC68U's, 2x RT-AC86U's, 1x RT-AC3100). :)
After the third or fourth router I updated, I thought of a couple of suggestions to ask for.
Could the Diversion Statistics and/or the pixelserv-tls report(s) be at the top?
And, where it says Diversion Statistics Report (click to expand/collapse), could it say something like:
Diversions Statistics Report for 'Sun May 12 04:00:32 2019' (click to expand/collapse)? Without the quotes around the date/time? :)
It would make the graphs much more informative, right away and also, I'm just being really lazy and wanting to save a click before needing to CTRL F5 if needed! :) :)
Thank you for even considering this request!
I also rebooted each model router and verified that after 10 minutes the graphs showed up as expected for all your scripts. :)
@WuTang LAN is right; this is really release-worthy as-is. :)
u ;-)
Where do you view the graph? I have it install on the AC5300.
Look under "tools " on the left hand side menu then find the corresponding script name on the right side tabs.
Wooho. Seem to be working but I have this issue with pixelserv. Do I need to install it form the entware?
It is installed along with Diversion. Where do I create the empty file at? I might to read the rest of the forum thread. I could missing some clue
OK. I guess we need to be patient for the all the services to come up on the router. It's working and thanks very much.
I just installed this on a AC5300, but I get no graphs. I waited for 30mins none of th graph shows up. But the Diversion and Pixelserver Statistic Report shows up.
I installed it via AMTM
What do the stats in the generated Diversion report look like?
 Router Stats Wed May 15 22:00:05 2019
 Compiled by Diversion 4.0.9
 Ad-Blocking stats:
 1,030,120   domains in total are blocked
 1,030,120   blocked by blocking list
 0           blocked by blacklist
 0           blocked by wildcard blacklist
 88,436      ads in total blocked
 24,467      ads this week, since last Friday
 10          new ads, since May 15 21:46
 The top 15 requested domains were:
 The top 15 blocked ad domains were:
 8388   graph.accountkit.com                      blocked
 2546   statsfe2.ws.microsoft.com                 blocked
 2039   watson.telemetry.microsoft.com            blocked
 1619   onesignal.com                             blocked
 1399   www.googleadservices.com                  blocked
 948    s.youtube.com                             blocked
 930    settings-win.data.microsoft.com           blocked
 838    app-measurement.com                       blocked
 828    e.crashlytics.com                         blocked
 520    v10.events.data.microsoft.com             blocked
 496    settings.crashlytics.com                  blocked
 394    api.mixpanel.com                          blocked
 302    tracker.trackerfix.com                    blocked
 302    googleads.g.doubleclick.net               blocked
 253    reports.crashlytics.com                   blocked
 The top 10 noisiest name clients:
 count for IP, client name: count for domain - percentage
 Top 15 domains for top 10 clients:
 192.168.69.3, Name-N/A:
 192.168.69.116, Name-N/A:
 192.168.69.110, Name-N/A:
 192.168.69.123, Name-N/A:
 192.168.69.102, Name-N/A:
 192.168.69.119, Name-N/A:
 192.168.69.191, Name-N/A:
 192.168.69.104, Name-N/A:
 192.168.69.100, Name-N/A:
 192.168.69.105, Name-N/A:
 End of stats report
 Ad-Blocking stats:
 End of stats report
Did you blank out the client stats? If not, then that's the problem. Any console errors in your browser?
no I didn't blank out the client's stats. no errors in the browser, just blank... but when I do "1. Generate Diversion Statistics now"
I get bunch of these...
/opt/bin/grep: /tmp/uidivstats/div-hostleases: No such file or directory
awkNR: /tmp/uidivstats/div-bwl: No such file or directory
/opt/bin/grep: /tmp/uidivstats/div-iphostleases: No such file or directory
awkNR: /tmp/uidivstats/div-noisy: No such file or directory
awkNR: /tmp/uidivstats/div-toptop: No such file or directory
Maybe i broke something when testing for no clients, I'll put something on the develop branch later for you to try
