uiDivStats uiDivStats - WebUI for Diversion statistics
Script is 384.XX without re-writing how the WebUI bits are done. Sorry (#1 has been edited)
Oh that explain why then... you may also want to edit the version number as 1.1.3 because that's what was installed.
What's missing in 380.x that can't make it works? I will eventually update, no worry.
Yup, worked now.
Thanks for another excellent addition [emoji106]
While using option 1 to generate new statistics I had this message
You star [emoji94] I ran the update and option 1 worked perfectly
Thank you
@Jack Yaz uiDivStats is phenomenal, a big thank you . Now I have a larger picture of what Diversion is blocking, and the Ui is excellent. May I ask for a potential feature, is it possible to add the option for Stats auto-update every x minutes after the first update? I do not know if this is possible, however, having such an option would be useful. Thanks again, :)
i imagine this would be consuming on your router, I don't know if you notice how much of an effort it takes your router to update stats every hour.
I see, that makes sense. Thank you.
So far new update is running great !
I only changed things for when LAN blocking IP is enabled in Diversion.
Everything else is the same as before this update, except that now new uiDivStats installations will not require the weekly stats enabled in Diversion.
This was an obsolete requirement from the early beta testing days of uiDivStats.
I just installed the new version also looks great.
Is there a way to exclude a client from being wrapped up into the stats? I have a client on my network that is super-chatty and it skews my statistics horribly.
EDIT: Is this how you do it (from inside of Diversion)?
EDIT2: Nevermind. Not sure if it's possible or not.
Think uiDivStats gets the stats from Diversion so guess you could exclude the client with DNSFilter
(You could use a Ad-block DNS server in DNSFilter for that client)
