uiDivStats uiDivStats - WebUI for Diversion statistics
Default stats update time is 1 hours, how to change this value without script edit? If I open uidivstats menu it not contain this feature.
You would need to edit the script. What interval are you looking to set it to, out of interest?
Thanks, I understood it. But, maybe add time option then open script setup via amtm?
1 hour is too long time, I mean set it 15-30 minutes.
The process to generate stats is quite cpu intensive, i wouldn't recommend running it that frequently
ASUS RT-AX88U
WRTMerlin-Current Version : 384.13_0
I ran the command :
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/uiDivStats/master/uiDivStats.sh" -o "/jffs/scripts/uiDivStats" && chmod 0755 /jffs/scripts/uiDivStats && /jffs/scripts/uiDivStats install
Then I ran the commands:
uiDivStats
and ...
and then nothing happened ...
prickly@RT-AX88U-E390:/tmp/home/root# /usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/uiDiv
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 43648  100 43648    0     0  26976      0  0:00:01  0:00:01 --:--:-- 31883
uiDivStats: Welcome to uiDivStats v1.1.3, a script by JackYaz
uiDivStats: Checking your router meets the requirements for uiDivStats
uiDivStats: Diversion weekly stats not enabled!
uiDivStats: Open Diversion, use option c and then enable using 2,1,1
uiDivStats: Requirements for uiDivStats not met, please see above for the reason(s)
Press enter to continue...
prickly@RT-AX88U-E390:/tmp/home/root# uiDivStats
-sh: uiDivStats: not found
prickly@RT-AX88U-E390:/tmp/home/root# /jffs/scripts/uiDivStats
-sh: /jffs/scripts/uiDivStats: not found
EDIT: I also enabled Diversion weekly stats
ASUS RT-AX88U
I ran the command :
uiDivStats
and ...
The error is shown in your output:
Yeah, I did that but its still not working. Maybe I'll reboot the router
After rebooting the router it still fails:
ASUSWRT-Merlin RT-AX88U 384.13-0 Wed Jul 31 17:30:47 UTC 2019
You need open Diversion! And enter needed options.
As I wrote above, I have already done that, and it is still not working.
Just installed it, I have RT-AC1900P running on 380.68_4 and in the Tools menu when I select the Diversion Statistics tab it goes to /Advanced_MultiSubnet_Content.asp url which gives 404 Not Found.
Well no answer so I decided to uninstall for now as I don't want it to take ressources while I can't see stats. I read they were generated every hours? WOuld it be possible to add a button so they only generate when we click it then the page refresh after completed?
Anyway, this is what I get after uninstalling, normal?
Are you sure you want to uninstall uiDivStats? (y/n)
y
uiDivStats: Removing uiDivStats...
sed: /jffs/scripts/custom_menuTree.js: No such file or directory
uiDivStats: Uninstall completed
y
Script is 384.XX without re-writing how the WebUI bits are done. Sorry (#1 has been edited)
