Unbound unbound_manager (Manager/Installer utility for unbound - Recursive DNS Server)
thanks!
is there a size limit to /opt/var/lib/unbound/unbound.log ?
No, - there is no housekeeping performed on 'opt/var/lib/unbound/unbound.log' hence in 'Easy' menu mode, during the install it states on the screen 'NO recommended' to prevent the log silently filling the disk.
However, if you enable 'scribe' (syslog-ng) logging, then you can manage the unbound log using 'logrotate'.
vpn starts correctly using my vpn client 2, with command "unbound_manager vpn=2"
but then when i do "?"
i see
[✔] unbound requests via VPN Client 1 (10.119.174.30) tunnel ENABLED
the IP is correctly set to the IP of my client2, but the message says client is "1"
is it because client array starts at position zero? so client 2 is ID=1?
The script usesthe command format, so if you isse the command what VPN ID is returned?
ip route | grep "10.119.174.30" |  awk '{print substr_($3,4,1) }'
EDIT: Remove the '_' character as the 'awk' command above is blocked :mad:
thanks!
cromo@RT-AX88U-8158:/tmp/home/root# ip route | grep "10.119.174.63"
10.119.174.0/23 dev tun12 proto kernel scope link src 10.119.174.63
cromo@RT-AX88U-8158:/tmp/home/root# ip route | grep "10.119.174.63"|awk '{print substr_($3,4,1) }'
1
this is for my vpnclient2 (which i'm using on unbound)
1
Doh… the index should be '5,1' :rolleyes::rolleyes::oops:
I'll eventually push a hotfix
could this be why my vpnclient2-route-up appears to have no effect?
(route-pre-down worked fine)
I don't think so as it's only the '?' command that always shows 'VPN 1 (xxx.xxx.xxx.xxx)'
i enabled scribe (via unbound_manager advanced), and have unbound logging enabled, but i don't see any entries in /opt/var/log/unbound.log
is there a delay?
my conf:
# integration LOG's
verbosity: 1
logfile: "/opt/var/lib/unbound/unbound.log"
log-time-ascii: yes
log-tag-queryreply: yes
log-queries: yes
log-replies: yes
use-syslog: yes
#log-local-actions: yes
log-servfail: yes
is there a delay?
my conf:
# integration LOG's
verbosity: 1
log-time-ascii: yes
log-queries: yes
log-replies: yes
use-syslog: yes
log-servfail: yes
There shouldn't be a delay..
A:Option ==> l
/opt/var/log/unbound.log (syslog-ng)        Press CTRL-C to stop
Apr 19 18:31:06 RT-AC68U unbound: [1013:0] query: 127.0.0.1 ipid.shat.net. A IN
Apr 19 18:31:06 RT-AC68U unbound: [1013:0] query: 127.0.0.1 lcprd1.samsungcloudsolution.net. A IN
Apr 19 18:31:06 RT-AC68U unbound: [1013:0] info: lcprd1.samsungcloudsolution.net. always_nxdomain 127.0.0.1@55039 lcprd1.samsungcloudsolution.net. A IN
I'd try another 'rs' command.
happened again:
1) cycled the vpn client and got new IP
2) now unbound outgoing-interface has outdated IP in unbound.conf
3) "vpn disable" comments out the outgoing-interface line in the conf file but leaves the ip number there
4) doing vpn =2 uncomments the outgoing-interface line in the conf file but leaves the old IP in place.
feels like starting vpn command, expects to find xxx.xxx.xxx.xxx in the conf file to work properly?
there were no error messages
Apr 20 16:43:13 RT-AC5300-0680 dnsmasq-script[5584]: [SEND_AMAS_NODE_EVENT:(4684)] ERROR connecting:No such file or directory.
Apr 20 16:43:13 RT-AC5300-0680 dnsmasq-script[5584]: connect error: No such file or directory
An observation
When Unbound is stopped by Option > x the syslog is flooded with the folowing:-
how to check that addresses are being retrieved via vpn? It shows me the ip address given by isp on the dnsleak test. this is normal?
The second question is how many queries the default (AC86U) cache stores and what is the optimal time to store it?
I've uploaded v3.05
Version=3.05
Github md5=c8c7c2b79e368bcc55577108ed7c5798
use 'u' to update when prompted on screen
Use of the 'i = Update unbound Installation' **Not required**
FIX:      'vpn x' doesn't always apply new VPN gateway IP, nor does it validate VPN Client instance/Gateway IP
CHANGE:   'vx' command will now ask to restart unbound if the config file was edited.
By design, no point in removing the previous IP - it's useful as an eye-catcher to prove the function was used previously.
Nope, the 2nd word can be any text string.
see post #1554 - hopefully I've fixed your issue.
thanks! will try it.
An observation
see [Release] Asuswrt-Merlin 384.15 (and 384.13_4) are now available
Obviously if you aren't using AiMesh…..:confused:
You can see the default cache size with
e  = Exit Script [?]
A:Option ==> ?
<snip>
 unbound Memory/Cache:
      'key-cache-size:' 8388608 (8.00m)
      'msg-cache-size:' 8388608 (8.00m)
      'rrset-cache-size:' 16777216 (16.00m)
and unfortunately my personal cache.*-TTL values have crept into the default 'unbound.conf'
grep cache-m /opt/var/lib/unbound/unbound.conf
# v1.08 Martineau - Change  'cache-max-ttl: 21600' and 'cache-min-ttl: 5 to 14400/1200'
cache-max-ttl: 14400                            # v1.08 Martineau
cache-min-ttl: 1200                             # v1.08 Martineau
However, the parameters proposed in this thread doubles the cache sizes and uses custom cache-*-ttl etc, and as the disclaimer says it may not work for non-HND models or even other HND models!
So without knowing individual environments, like all cache-profiling, it depends on how many clients are using it, and the resulting 'churn' rate.
The unbound stats don't show the usage/size of the three cache entities over time (perhaps another opportunity for @juched's Graphical charting skills? ;)
i.e. for the rrset-cache would it be useful to see how much of its 16M is actually in-use say by hour? ...similar to the 3rd graph down on this page
this is normal?
Think about it...
Q. Who is the DNS server when you are forwarding to an upstream DNS server?....if you are not forwarding DNS requests upstream, who can it possibly be? ;)
How to check that addresses are being retrieved via vpn?
Try this... I could be wrong!:)
Create the outbound DNS tracker rule
iptables -I OUTPUT -p udp -m udp --dport 53 -j LOG -m comment --comment "DNS request tracker"
Now wait a while and check for DNS hits (whilst redacting your real WAN IP if found)
EDIT: Changed 'IN=.*DPT=53' to '^.*DPT=53' to preserve timestamps
iptables  --line -t filter -nvL OUTPUT
WANIP=$(nvram get wan0_ipaddr);grep -o "^.*DPT=53" /tmp/syslog.log | sed -r 's/LEN.*PROTO=//' | sed -r 's/LEN.*PROTO=//' | sed -r "s/$WANIP/wan.isp.ip.addr/"
Now if you route unbound requests via the VPN, then wait a few minutes then check again....
Feel free to post the results....
Any difference?
@Martineau : Sounds that, for folks worried with privacy, and previously using DOT, unbound+vpn is a fair trade, is this a valid statement?
thanks
