SomeWhereOverTheRainBow
Part of the Furniture
We need a dedicated page for the @Martineau FAQ.Why not follow the instruction in post #1500![]()
Sadly no one reads FAQs anyway as evidenced by the frequently ignored sticky posts at the top of this forum, but are my (verbose) instructions not concisely clear? or are they too esoteric?We need a dedicated page for the @Martineau FAQ.
You shouldn't believe everything you read on the Internet
Once upon a time.... ha!
Of course you can use unbound with a permanently running VPN.
unbound will always use the WAN but be unencrypted (i.e. ISP snooping), and your LAN nominated Selective Routing devices can either use the VPN ISP's DNS (EXCLUSIVE) or unbound.
The only thing that is new is (optionally) unbound is also capable of sending it's requests though the VPN tunnel to prevent ISP snooping, but I doubt many have used the option within unbound_manager as it is experimental.
See post #1504 and reiterated here with additional precautions to be considered/added to handle an unsolicited reboot due to an unexpected power outage/crash etc.if i use vpn exclusive dns option ad blocking doesn't work. so this vpn solution is a good idea and i am using it. exactly what script do I need when disconnecting from vpn?
One question that currently occurred to my usage:So hopefully if you have the time, could you test my 'bloated mess!'of a script further?
[✔] unbound requests via VPN Client (10.8.0.8) tunnel ENABLED
As per post 1500# what do the first two diagnostic commands show?One question that currently occurred to my usage:
I used the command "vpn 1" to use DNS over VPN. Installation worked fine.
10.8.0.8 was also integrated into the config and everything went fine.Code:[✔] unbound requests via VPN Client (10.8.0.8) tunnel ENABLED
Today the IP of my VPN was changed. Current IP is 10.8.3.5. So no DNS resolution possible anymore. So everything working correct.
So I deactivated DNS over VPN by the command "vpn disable". Also working, I could resolve DNS again.
Then I typed the command "vpn 1" again in order to use DNS over VPN with the new IP (10.8.3.5).
But outbound seems to use the old IP for the outgoing interface:
Would it be possible that the new IP is integrated in the config? Or am I doing something wrong?Code:[✔] unbound requests via VPN Client (10.8.0.8) tunnel ENABLED
grep VPN /opt/var/lib/unbound/unbound.conf
outgoing-interface: 10.8.0.8 # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
ip route show | grep tun1
10.8.3.0/24 dev tun11 proto kernel scope link src 10.8.3.5
Code:grep VPN /opt/var/lib/unbound/unbound.conf outgoing-interface: 10.8.0.8 # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
Code:ip route show | grep tun1 10.8.3.0/24 dev tun11 proto kernel scope link src 10.8.3.5
So its still the IP from the first activation of "vpn 1".
"vpn disable" shows in the config, that ongoing interface is marked by "#".
"vpn 1" seems to eliminate the "#", but not actualizing the IP (10.8.0.8 -> 10.8.3.5)
sed '/^outgoing-interface:/ s/[^ ]*[^ ]/100.999.999.0/2' /opt/var/lib/unbound/unbound.conf | grep VPN
unbound_manager vpn=disable
sh -x /jffs/addons/unbound/unbound_manager.sh vpn=1
Unfortunately, I'm not brightest when it comes to this and I do apologize.Why not follow the instruction in post #1500![]()
See post above yours as I can't seem to recreate the issue, but you can try debugging - well at least the first command if you wishUnfortunately, I'm not brightest when it comes to this and I do apologize.
I'm following your instructions and now I'm getting the following message when typing "vpn 1" using advanced mode:
[1587308024] unbound-checkconf[27607:0] error: cannot parse ip address: 'xxx.xxx.xxx.xxx'
[1587308024] unbound-checkconf[27607:0] fatal error: cannot parse outgoing-interface specified as 'xxx.xxx.xxx.xxx'
***ERROR INVALID unbound configuration - use option 'vx' to correct 'unbound.conf' or 'rl' to load a valid configuration file
When I run pre-reqs status I see this:
Router Configuration recommended pre-reqs page status:
[✔] Swapfile=2097148 kB
[✔] DNS Filter=ON
[✔] DNS Filter=ROUTER
[✔] WAN: Use local caching DNS server as system resolver=NO
[✔] Enable local NTP server=YES
[✔] Enable DNS Rebind protection=NO
[✔] Enable DNSSEC support=NO
Options: Auto Reply='y' for User Selectable Options ('4') Performance Tweaks
[✔] unbound CPU/Memory Performance tweaks
[✔] unbound-control FAST response ENABLED
[✔] unbound requests via VPN Client (xxx.xxx.xxx.xxx) tunnel ENABLED
admin@RT-AX88U-xxxx:/tmp/home/root# unbound_manager vpn=disable
unbound requests via VPN Client tunnel DISABLED
unbound-checkconf: no errors in /opt/var/lib/unbound/unbound.conf
Shutting down unbound... done.
Starting unbound... done.
Checking status, please wait..... unbound OK
admin@RT-AX88U-xxxxx:/tmp/home/root# grep VPN /opt/var/lib/unbound/unbound.conf
#outgoing-interface: xxx.xxx.xxx.xxx # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
admin@RT-AX88U-F2E8:/tmp/home/root# sh -x /jffs/addons/unbound/unbound_manager.s
h vpn=1
+ export PATH=/sbin:/bin:/usr/sbin:/usr/bin:/opt/bin:/opt/sbin:/bin:/usr/bin:/sb in:/usr/sbin:/home/admin:/mmc/sbin:/mmc/bin:/mmc/usr/sbin:/mmc/usr/bin:/opt/sbin :/opt/bin:/opt/usr/sbin:/opt/usr/bin
+ basename /jffs/addons/unbound/unbound_manager.sh
+ [ -n vpn=1 ]
+ echo vpn=1
+ logger -t (unbound_manager.sh) 9712 Starting Script Execution (vpn=1)
+ VERSION=3.04
+ GIT_REPO=unbound-Asuswrt-Merlin
+ GITHUB_JACKYAZ=https://raw.githubusercontent.com/jackyaz/unbound-Asuswrt-Merli n/master
+ GITHUB_JUCHED=https://raw.githubusercontent.com/juched78/unbound-Asuswrt-Merli n/master
+ GITHUB_JUCHED_DEV=https://raw.githubusercontent.com/juched78/unbound-Asuswrt-M erlin/develop
+ GITHUB_MARTINEAU=https://raw.githubusercontent.com/MartineauUK/unbound-Asuswrt -Merlin/master
+ GITHUB_MARTINEAU_DEV=https://raw.githubusercontent.com/MartineauUK/unbound-Asu swrt-Merlin/dev
+ GITHUB_DIR=https://raw.githubusercontent.com/MartineauUK/unbound-Asuswrt-Merli n/master
+ CONFIG_DIR=/opt/var/lib/unbound/
+ UNBOUNCTRLCMD=unbound-control
+ ENTWARE_UNBOUND=unbound-checkconf unbound-control-setup unbound-control unboun d-anchor unbound-daemon
+ SILENT=s
+ ALLOWUPGRADE=Y
+ CHECK_GITHUB=1
+ MAX_OPTIONS=5
+ USER_OPTION_PROMPTS=?
+ CURRENT_AUTO_OPTIONS=
+ DIV_DIR=/opt/share/diversion/list/
+ KEEPACTIVECONFIG=N
+ USE_GITHUB_DEV=N
+ + awknvram BEGIN { FS = "." } {printf("%03d%02d",$1,$2)}
get buildno
+ echo 384.16
+ FIRMWARE=38416
+ Get_Router_Model
+ local HARDWARE_MODEL
+ nvram get odmpid
+ [ -z ]
+ nvram get productid
+ HARDWARE_MODEL=RT-AX88U
+ echo RT-AX88U
+ return 0
+ HTTP_TYPE=http
+ nvram get http_lanport
+ HTTP_PORT=80
+ nvram get http_enable
+ [ 2 == 1 ]
+ ANSIColours
+ cRESET=\e[0m
+ cBLA=\e[30m
+ cRED=\e[31m
+ cGRE=\e[32m
+ cYEL=\e[33m
+ cBLU=\e[34m
+ cMAG=\e[35m
+ cCYA=\e[36m
+ cGRA=\e[37m
+ cBGRA=\e[90m
+ cBRED=\e[91m
+ cBGRE=\e[92m
+ cBYEL=\e[93m
+ cBBLU=\e[94m
+ cBMAG=\e[95m
+ cBCYA=\e[96m
+ cBWHT=\e[97m
+ aBOLD=\e[1m
+ aDIM=\e[2m
+ aUNDER=\e[4m
+ aBLINK=\e[5m
+ aREVERSE=\e[7m
+ cWRED=\e[41m
+ cWGRE=\e[42m
+ cWYEL=\e[43m
+ cWBLU=\e[44m
+ cWMAG=\e[45m
+ cWCYA=\e[46m
+ cWGRA=\e[47m
+ source /usr/sbin/helper.sh
+ _am_settings_path=/jffs/addons/custom_settings.txt
+ [ vpn=1 == -h ]
+ [ vpn=1 == help ]
+ [ ! -L /opt/bin/unbound_manager ]
+ grep -oiw advanced
+ echo vpn=1
+ [ -n ]
+ EASYMENU=Y
+ [ -f /opt/var/lib/unbound/Read.me ]
+ echo vpn=1
+ grep -F config=
+ [ -n ]
+ [ -n ]
+ echo vpn=1
+ awk {print $1}
+ sed -n s/^.*vpn=//p
+ VPN_ID=1
+ nvram get vpn_client1_state
+ [ 2 == 2 ]
+ Use_VPN_Tunnel 1
+ local STATUS=0
+ grep -E ^[#|o].*utgoing-interface: /opt/var/lib/unbound/unbound.conf
+ [ -n # - Add 'outgoing-interface:' template
#outgoing-interface: xxx.xxx.xxx.xxx # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP ]
+ [ 1 != disable ]
+ local VPN_ID=1
+ Edit_config_options outgoing-interface: uncomment
+ local FN=/opt/var/lib/unbound/unbound.conf
+ local TO=
+ _quote outgoing-interface:
+ echo outgoing-interface:
+ sed s/[]\/()$*.^|[]/\\&/g
+ local MATCH=outgoing-interface:
+ shift
+ local SEDACTION=-i
+ [ 1 -gt 0 ]
+ local ACTION=uncomment
+ shift
+ [ 0 -gt 0 ]
+ [ -z outgoing-interface: ]
+ grep -Enw [[:space:]]*server: /opt/var/lib/unbound/unbound.conf
+ head -n 1
+ cut -d: -f1
+ local POS=21
+ [ -z ]
+ sed -i 21,$ {/#[[:space:]]*outgoing-interface:/ s/#//1} /opt/var/lib/unbound/u nbound.conf
+ ip route
+ awk {print $NF}
+ grep dev tun11
+ local VPN_CLIENT_GW=10.16.10.10
+ [ -n 10.16.10.10 ]
+ sed -i /^outgoing-interface:/ s/[^ ]*[^ ]/10.16.10.10/2 /opt/var/lib/unbound/u nbound.conf
+ echo -e \e[96m\n\tunbound requests via VPN Client 1 tunnel \e[0mENABLED\e[90m
unbound requests via VPN Client 1 tunnel ENABLED
+ SayT unbound requests via VPN Client 1 (10.16.10.10) tunnel ENABLED
+ echo -e 9712 unbound requests via VPN Client 1 (10.16.10.10) tunnel ENABLED
+ [ 0 -eq 0 ]
+ Restart_unbound
+ local NOCACHE=
+ [ == nochk ]
+ Valid_unbound_config_Syntax /opt/var/lib/unbound/unbound.conf
+ local VALID=Y
+ local RC=0
+ local CHECKTHIS=/opt/var/lib/unbound/unbound.conf
+ [ -z /opt/var/lib/unbound/unbound.conf ]
+ [ ! -f /opt/var/lib/unbound/unbound.conf ]
+ local STATEMENTS=server:|access-control:|private-address:|domain-insecure:|for ward-addr:|include:|interface:|outgoing-interface|name:|zonefile:|rpz.*:|url:|ta gs:|access-control-tag:
+ sed+ /^[[:space:]]*#/d /opt/var/lib/unbound/unbound.confgrep
+ awk {print $1}
+ sort
+ uniq -cd
+ grep -vE server:|access-control:|private-address:|domain-insecure:|forward-add r:|include:|interface:|outgoing-interface|name:|zonefile:|rpz.*:|url:|tags:|acce ss-control-tag:
+ local DUPLICATES=
+ [ -z ]
+ unbound-checkconf /opt/var/lib/unbound/unbound.conf
+ local CHK_Config_Syntax=unbound-checkconf: no errors in /opt/var/lib/unbound/u nbound.conf
+ echo unbound-checkconf: no errors in /opt/var/lib/unbound/unbound.conf
+ grep -o no errors in
+ [ -z no errors in ]
+ [ == returndup ]
+ echo Y
+ return 0
+ [ Y == Y ]
+ [ != nochk ]
+ echo -e \e[92m
+ echo -e
+ pidof unbound
+ [ -n 9358 ]
+ [ != nocache ]
+ Manage_cache_stats save
+ unbound_Control dump
+ pidof unbound
+ [ -z 9358 ]
+ local RESET=_noreset
+ local RETVAL=
+ local ADDFILTER=
+ echo dump
+ wc -w
+ [ 1 -eq 2 ]
+ local FN=/opt/share/unbound/configs/cache.txt
+ unbound-control dump_cache
+ [ dump == save ]
+ Check_config_add_and_postconf
+ local CONFIG_ADD=/opt/share/unbound/configs/unbound.conf.add
+ [ -f /opt/share/unbound/configs/unbound.conf.add ]
+ local POSTCONF_SCRIPT=/opt/share/unbound/configs/unbound.postconf
+ [ -f /opt/share/unbound/configs/unbound.postconf ]
+ /opt/etc/init.d/S61unbound restart
+ [ -z ]
+ CHECK_GITHUB=1
+ echo -en \e[0m\e[96m\nChecking status, please wait..... \e[0m
Checking status, please wait..... + WAIT=3
+ INTERVAL=1
+ I=0
+ [ 0 -lt 2 ]
+ sleep 1
+ I=1
+ pidof unbound
+ [ -z 9866 ]
+ [ 1 -eq 2 ]
+ [ 1 -lt 2 ]
+ sleep 1
+ I=2
+ pidof unbound
+ [ -z 9866 ]
+ [ 2 -eq 2 ]
+ Manage_cache_stats restore
+ unbound_Control load
+ pidof unbound
+ [ -z 9866 ]
+ local RETVAL=
+ local ADDFILTER=
+ echo load
+ wc -w
+ [ 1 -eq 2 ]
+ [ -s /opt/share/unbound/configs/cache.txt ]
+ unbound-control load_cache
+ [ load == rest ]
+ rm /opt/share/unbound/configs/cache.txt
+ [ 2 -lt 2 ]
+ pidof unbound
+ [ -n 9866 ]
+ echo -e \e[0m\e[92munbound OK
unbound OK
+ [ == rsnouser ]
+ echo -e \e[0m
+ exit_message
+ local CODE=0
+ [ -n ]
+ rm -rf /tmp/unbound.lock
+ [ -n ]
+ echo -e \e[0m
+ exit 0
admin@RT-AX88U-xxxx:/tmp/home/root# grep VPN /opt/var/lib/unbound/unbound.conf
outgoing-interface: 10.16.10.10 # v1.08 Martineau Use VPN tunnel to hide ...
Thanks for the assistance. Runnin the command gives the following
It seems the previous post troubleshooting steps helped!!! All seems to be running correctly! Thanks @Martineau
Well actually.... since nothing has changed, the only thing you have done is seemingly possibly slowed down the execution of the statements?Thanks for the assistance. Runnin the command gives the following
Please try the debugging in post #1529i see the same behavior jus tnow:
1) have vpnclient up with IP1, and unbound vpn tunnel up too.
2) turn off vpn tunnel in unbound
3) turn off vpn client
4) turn on vn client (get new IP2)
5) enable unbound vpn again
6) line in unbound.conf gets uncommented but IP is not updated
Yes, if you have ENABLED logging and you haven't enabled 'scribe', in which case view '/opt/var/log/unbound.log'is /opt/var/lib/unbound/unbound.log the place to see the client queries? i have logging enabled and don't see any new entries there. thanks
Would you mind assisting further by debugging?.....
First issue a non-destructive command to manually test the 'sed' expression used within the script
you can try the above command a couple of times changing '100.999.999.0' to a different string each time.Code:sed '/^outgoing-interface:/ s/[^ ]*[^ ]/100.999.999.0/2' /opt/var/lib/unbound/unbound.conf | grep VPN
Hopefully the second word always changes to whatever string you have provided.
Now debug the script from a known VPN DISABLED state
Check the current VPN configuration; it should be DISABLED i.e. commented outCode:unbound_manager vpn=disable
then run 'unbound_manager' in debug trace mode (NOTE: Rather than use the 'vpn 1' menu command, there will be significantly less debug output when using the commandline)Code:grep VPN /opt/var/lib/unbound/unbound.conf
and post the output (preferably in a SPOILER+CODE tag box!)Code:sh -x /jffs/addons/unbound/unbound_manager.sh vpn=1 grep VPN /opt/var/lib/unbound/unbound.conf
Administrator@RT-AC86U-6A50:/tmp/home/root# sed '/^outgoing-interface:/ s/[^ ]*[^ ]/100.999.999.0/2' /opt/var/lib/unbound/unbound.conf | grep VPN
#outgoing-interface: 10.8.0.8 # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
outgoing-interface: 100.999.999.0 # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
Administrator@RT-AC86U-6A50:/tmp/home/root# sed '/^outgoing-interface:/ s/[^ ]*[^ ]/100.999.998.0/2' /opt/var/lib/unbound/unbound.conf | grep VPN
outgoing-interface: 100.999.998.0 # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
Administrator@RT-AC86U-6A50:/tmp/home/root# grep VPN /opt/var/lib/unbound/unbound.conf
outgoing-interface: 10.8.3.5 # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
#outgoing-interface: 10.8.3.5 # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
thanks!Yes, if you have ENABLED logging and you haven't enabled 'scribe', in which case view '/opt/var/log/unbound.log'
Welcome To SNBForums
