cptnoblivious
If it was only one router, I'd think it's something goofy with the router, but I have both an AX58 and an AX68, configured identically for VPNMON. And they _both_ did the same thing. It's definitely goofyLOL that's absolutely whacky. The routers don't go into hybernation mode around 01:00, do they??There's got to be more to this!
As a workaround, if you continue seeing this, perhaps setting up a manual cron job that executes "vpnmon-r2 -reset" command at a specific time?
I'll keep an eye on it and post up. And keep looking in the logs to see if there is any info. Will setup a cron job if it keeps being an issue...
