Skynet What are some good current block lists? - Skynet
Could tell me please, do I need all those additional lists if I am behind the NAT? (And Skynet at all)
Or Skynet is already doing a similar thing to Diverson (but differently), apart from its firewall duties?
No need for block countries when you have the IANA blocklist
Nord VPN IANA Gaming list. Works with VR Chat, COD BO6 https://raw.githubusercontent.com/Jack-Sparr0w-2o4/Gatekeeper-IANA-Gaming/refs/heads/main/Filterlist US, UK, Germany, Netherlands, and Ireland left out of list so games can work while using Nord VPN add MK XK (Balkans) to country block and all sanctions are close enough to complete. Here is some info about it https://orpa.princeton.edu/export-controls/sanctioned-countries Netherlands is needed for bo6 and Germany is for VR Chat. If you can find other services I will add them, thank you for your patience, good things are coming.
Official-IANA-IP-blocks I've integrated with a new list I made. Nord VPN works fine with it. This is version 1 of this list https://raw.githubusercontent.com/Jack-Sparr0w-2o4/Gatekeeper-IANA/refs/heads/main/Filterlist
Using this works but Netflix goes into buffering cycle every couple of minutes and thumbnails whilst rewinding an episode don't work removing it everything comes back to normal I'll try the gaming version see if that helps, thanks for these
Update: The gaming list does the same thing sadly
I'll try make one work with those services for now you will have to use this address https://raw.githubusercontent.com/J...eper-VPN-Blocklist/refs/heads/main/Filterlist It has no IANA but its still a really big list. IANA is still in developing phase, I just need a a week or 2 to make a streaming version. Also if you have a VPN, try whitelisting option. Older routers will suffer with list, So make sure you have a good router and a decent storage device.
Take the bottom address in list and import 1 at a time to see which list is giving the error using Skynet import option. This will narrow down the problem and I can edit it. Please send the address after finding the error. Sorry about the inconvenience. The code looked fine when I finished, sometimes it happens but its an easy fix.
@Jack-Sparr0w
First and foremost, thank you for your efforts.
With the numerous links you've shared in your last posts, I've lost track of which one I should use for Skynet.
Could you please recommend the most suitable link and also let me know which link remains constant?
