Skynet What are some good current block lists? - Skynet
I am using @Viktor Jaep URL but excluding one troublesome list within called firehol_level3.
customlisturl="https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.list"
excludelists="firehol_level3.netset"
Why is the level3 list causing you issues?
https://raw.githubusercontent.com/Jack-Sparr0w-2o4/Gatekeeper-1/refs/heads/main/Ip Blocklist I made This Blocklist but router wont take it as a full list just one by one? Any Idea what I did wrong?
I think you need to give it an actual filename, and get rid of that space... like:
https://raw.githubusercontent.com/Jack-Sparr0w-2o4/Gatekeeper-1/refs/heads/main/IpBlocklist.list
BTW, that's quite an impressive list of blocks... please remember, there are limitations. If I'm not mistaken, Skynet starts choking around the 500,000 IPs mark.
There had been a pattern of blocks with nothing to back them up on alienvault or other sites. I had heard that level3 had been intended for testing only. Now that I read the description, this is not the case. It has some basic malware protection. I will put it back to see how it goes.
List Manifest:
481282 IPs (+0) -- 51741 Ranges Banned (+0)
As opposed to @Viktor Jaep's list:
226603 IPs (+0) -- 20905 Ranges Banned (+0)
Hey now... quantity does not always necessary mean quality. :p
Here is the list for VPN, https://raw.githubusercontent.com/J...eper-VPN-Blocklist/refs/heads/main/Filterlist It still needs work and am slowly testing it. Version 1 I am hopping in the next few weeks to work out all the bugs. Testing with Nord VPN. Free to anyone to use and open to input on how to make changes to the list
So far so good with the VPN. It ran all night without going offline. That must of been the address that was giving me trouble with Nord VPN
Not if you give it a 'gentle tap' with a heavy 'lump hammer' !!!
:eek:;)
#                                 Router Firewall And Security Enhancements                                 #
#                             By Adamm -  https://github.com/Adamm00/IPSet_ASUS                             #
#  >>>>>>>>---- *23/01/2025* - v7.6.4+++  [maxelem == 2097152 == (65536 * 32)] [*My* Version] ----<<<<<<<<  #
Router Model; RT-AX86U_Pro
Skynet Version; v7.6.4 (23/01/2025) (9ba156562ae4aa4b5020e923a03459f8)
iptables v1.4.15 - (ppp0 @ XXX.XXX.XXX.XXX)
ipset v7.6, protocol version: 7
IP Address; (XXX.XXX.XXX.XXX)
FW Version; 388.8_4 (Nov 17 2024) (4.19.183)
Install Dir; /tmp/mnt/RT-AX86UPro/skynet (862.7G / 915.9G Space Available)
SWAP File; /tmp/mnt/RT-AX86UPro/myswap.swp (5.0G)
1082561 IPs (+0) -- 88320 Ranges Banned (+0) || 1 Inbound -- 7 Outbound Connections Blocked!
