x3mRouting x3mRouting ~ Selective Routing for Asuswrt-Merlin Firmware (1-Nov-2020)
Thanks for taking the time to reply, as a matter of fact I have static routes enabled for all Google dns requests going through my unbound server and those 2 clients are using the DNS filter with the specified dns provided by the router. Also both TVs are samsung so they're using Tizen OS but one is newer and on my shield tv location settings as disabled. I think there's a check somewhere on those 2 devices so I might need to sniff out the the traffic
The ip rule command will show the RPDB rules for LAN clients.
Check the TV settings for a region setting. I've seen that mess things up before.
The first line is routing BBC to VPN client 1 and the second line is routing BBC_WEB to the WAN. Delete the entry that is not correct and reenter using the correct interface.
Ooh not sure how that happened. So 0x8000 is to WAN 0x1000 is to vpn client 1
I have them pointing at the right thing now but the dnsmasq rules still didn't seem to be getting used at all. But I just spotted your reply to obenz about the vpn dns configuration, mine was set to exclusive which I expect is what was stopping the dnsmasq method from working all along. I set it to strict and restarted the vpn and things seem to be working again. I left off the amazon rules but added back the netflix asn, netflix web, bbc asn, and bbc web rules and they seem to be working again now, and binance is no longer getting through. It looks like it was the amazon rules letting too much through so I have left those off as I don't really use amazon video anyway now. I will remove the asn rules and see if everything is still ok just using the dns masq method as I would prefer to use specific ip's instead of opening up half the internet by using asn's.
1. You can use the "ip rule" command to confirm the RPDB rules for LAN devices. Those devices assigned to use the WAN won't appear on the list as the WAN0 is the default interface.
2. In a nutshell, the ipset feature is integrated into dnsmasq. When a query on a domain containing the top level domain name is performed, dnsmasq will load the IPv4 entry in the IPSET list. You can view the contents of the list using the "ipset -L MYLIST" command, where MYLIST is the name of you ipset list. At 2AM, the list is backed up to /opt/tmp/MYLIST so it can be reloaded at boot. You can view the entreis in dnsmasq.log file as follows:
grep ipset /opt/var/log/dnsmasq.log
Nov 19 05:33:41 dnsmasq[15642]: ipset add NETFLIX-DNS 34.235.252.0 ds-uset1-ext-prod-a-1310415597.us-east-1.elb.amazonaws.com
Nov 19 05:33:41 dnsmasq[15642]: ipset add NETFLIX-DNS 52.45.65.128 ds-uset1-ext-prod-a-1310415597.us-east-1.elb.amazonaws.com
Nov 19 05:33:41 dnsmasq[15642]: ipset add NETFLIX-DNS 54.221.137.245 ds-uset1-ext-prod-a-1310415597.us-east-1.elb.amazonaws.com
Nov 19 05:43:57 dnsmasq[15642]: query[A] ipset.netfilter.org from 192.168.22.152
Nov 19 05:43:57 dnsmasq[15642]: forwarded ipset.netfilter.org to 127.0.0.1
Nov 19 05:43:58 dnsmasq[15642]: query[A] ipset.netfilter.org from 192.168.22.152
Nov 19 05:43:58 dnsmasq[15642]: forwarded ipset.netfilter.org to 127.0.0.1
Nov 19 05:43:58 dnsmasq[15642]: reply ipset.netfilter.org is <CNAME>
IPSET Man Page
3. The LAN Client Routing feature of x3mRouting and the ability to use the GUI to also create rules for LAN clients can coexist. The code first processes the entries in the GUI before appending the entries defined by using the LAN Client Routing feature. It does not check for duplicate entries. Use the "ip rule" command to view. Not sure if I answered the question though.
Hi Xentrk,
Are you able to tell me what the item in the middle of my dnsmasq.log is referring to?
rhodess@RT-AC3200-4200:/tmp/home/root# grep ipset /opt/var/log/dnsmasq.log
Nov 24 06:59:08 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.133 d.sni.global.fastly.net
Nov 24 07:11:06 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.110 f4.shared.global.fastly.net
Nov 24 08:11:32 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.133 d.sni.global.fastly.net
Nov 24 08:11:33 dnsmasq[25526]: ipset add BBC_WEB3 216.239.36.54 us-central1-adaptive-growth.cloudfunctions.net
Nov 24 08:11:34 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.110 f4.shared.global.fastly.net
Nov 24 20:22:20 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.133 na-eu.atlanticmedia.map.fastly.net
Nov 24 20:22:21 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.111 dualstack.guardian.map.fastly.net
Nov 24 20:22:21 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.62 domains.gannett.map.fastly.net
Nov 24 20:22:21 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.164 nytimes.map.fastly.net
Nov 24 20:22:21 dnsmasq[25526]: ipset add BBC_WEB3 151.101.124.239 condenast.map.fastly.net
Nov 24 20:22:42 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.52 vox-chorus.map.fastly.net
Nov 24 20:25:48 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.164 nytimes.map.fastly.net
Nov 24 20:25:48 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.62 domains.gannett.map.fastly.net
Nov 24 20:25:48 dnsmasq[25526]: ipset add BBC_WEB3 151.101.124.239 condenast.map.fastly.net
Nov 24 20:25:48 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.133 na-eu.atlanticmedia.map.fastly.net
Nov 24 20:25:48 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.52 vox-chorus.map.fastly.net
Nov 24 20:25:48 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.111 dualstack.guardian.map.fastly.net
Nov 24 20:27:28 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.62 domains.gannett.map.fastly.net
Nov 24 20:27:28 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.164 nytimes.map.fastly.net
Nov 24 20:27:28 dnsmasq[25526]: ipset add BBC_WEB3 151.101.124.239 condenast.map.fastly.net
Nov 24 20:27:28 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.133 na-eu.atlanticmedia.map.fastly.net
Nov 24 20:27:37 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.52 vox-chorus.map.fastly.net
Nov 24 20:27:37 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.111 dualstack.guardian.map.fastly.net
Nov 24 20:27:43 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.217 c3.shared.global.fastly.net
Nov 24 20:38:56 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.62 domains.gannett.map.fastly.net
Nov 24 20:38:56 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.164 nytimes.map.fastly.net
Nov 24 20:38:56 dnsmasq[25526]: ipset add BBC_WEB3 151.101.124.239 condenast.map.fastly.net
Nov 24 20:38:56 dnsmasq[25526]: ipset add BBC_WEB3 151.101.126.133 na-eu.atlanticmedia.map.fastly.net
Nov 24 20:38:56 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.52 vox-chorus.map.fastly.net
Nov 24 20:38:56 dnsmasq[25526]: ipset add BBC_WEB3 151.101.125.111 dualstack.guardian.map.fastly.net
Nov 24 22:37:40 dnsmasq[9806]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset no-auth DNSSEC no-ID loop-detect no-inotify no-dumpfile
Nov 24 23:28:45 dnsmasq[9806]: ipset add BBC_WEB3 151.101.126.62 domains.gannett.map.fastly.net
Nov 24 23:28:48 dnsmasq[9806]: ipset add BBC_WEB3 151.101.126.133 na-eu.atlanticmedia.map.fastly.net
Nov 24 23:28:50 dnsmasq[9806]: ipset add BBC_WEB3 151.101.125.111 dualstack.guardian.map.fastly.net
Nov 24 23:34:22 dnsmasq[9806]: ipset add BBC_WEB3 151.101.125.194 confiant-integrations.global.ssl.fastly.net
The iPlayer app may be querying other domains that I did not pick up when I surfed using Windows and Fire TV. Unfortunately, the iPlayer app is out of date on my iPad and it will take some effort to side load it again.
You'll need to perform additional analysis of the domains the iPlayer app uses. Set all of your traffic to use the VPN:
Force Internet traffic through tunnel=Yes
Then, access the iPlayer app and see if it works. If you still have issues, see if location services is turned on. If it is, turn if off and test again. If it's working, you can surf around the menu options to generate traffic. Then, run the autoscan.sh script and search for bbc. See if you pick up additional domains. Turn policy routing back on. Then, remove the prior BBC ipset list and create the new one adding the new domains to the list. If you still have issues, turn off policy rules and set it back to route all traffic to the VPN connected to UK. Then, run the getdomainnames.sh script and give it the IP address of your iPad. Surf around app and select as many options as you can. When done, press ctrl-c to view the list of domains the iPad queried while you surfed the app.
If you are still having issues, you can try adding the ASN method:
x3mRouting ALL 3 BBC_ASN asn=AS2818,AS31459
Interesting...Looks like Content Delivery Network is in play (Fastly).
asn bbc.co.uk
| ASN lookup for bbc.co.uk |
- Resolving "bbc.co.uk"... 8 IP addresses found:
     151.101.64.81 +PTR -
                   +ASN 54113 (FASTLY, US)
                   +ORG Fastly
                   +NET 151.101.64.0/22 (SKYCA-3)
                   +ABU abuse@fastly.com
                   +GEO San Francisco, California (US)
    151.101.128.81 +PTR -
                   +ORG Fastly
                   +NET 151.101.128.0/22 (SKYCA-3)
<snip>
I have another list of IPv4 address I generated from all of the domains I mined a few years back. If you still have issues, I can upload the list for you to try.
If you use the LAN client routing feature, it first processes clients in the GUI followed by clients listed in the nvram files located in /jffs/addons/x3mRouting/ovpnc3.nvram which was created per x3mRouting_client_rules file for VPN Client 3. It does not check for duplicate entries. Check the OpenVPN Client Screen for the 10.0.1.60 entry.
Can you post the other list also so I can compare? It works most of the time, occasionally however I have to use scmerlin and restart ovpn3 and the dhcp to restart the dnsmasq
Hi Xentrk,
This line?
The line appears when dnsmasq is restarted. Here is a snip:
Nov 25 11:57:49 dnsmasq[27859]: exiting on receipt of SIGTERM
Nov 25 11:57:50 dnsmasq[20569]: started, version 2.82-34-gb309cca cache disabled
Nov 25 11:57:50 dnsmasq[20569]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset no-auth DNSSEC no-ID loop-detect no-inotify no-dumpfile
Nov 25 11:57:50 dnsmasq[20569]: warning: interface pptp* does not currently exist
<snip>
dnsmasq -v command will display the information too.
How is BBC routing working so far?
This line?
<snip>
So far all is working well, occasionally it still blocks, hence my question about the above message in the dnsmasq, showing that I had to restart the dns server and ovpn3. It seems that all works fine until a show ends, at that point it tries to autoload the next episode, which usually works. occasionally though I get the black screen with the prohibited icon on the play timeline. Exiting to the main iplayer screen and re-selecting the episode usually works, but on some occassions I have to fully restart. Next time I will try just restarting the ovpn to see if it is just related to the vpn, then try restarting the dns server and not the vpn.
I'll make another pass to see if there are more domains. I only selected a few shows to make sure they played before I stopped mining domains.
Can you also include the ASN for BBC to see if that helps. Looks like I also have it in my nat-start file.
sh /jffs/scripts/x3mRouting/x3mRouting.sh ipset_name=BBC asnum=AS2818,AS31459
The issue with fastly.net is it may also cast too wide of a net since it is a CDN (content delivery network). I want to experiment to see if I can get it to only capture the domain names that are used by bbc and not other sites.
@Sean Rhodes
I stripped it down slightly and removed the fastly.net reference. Tested on Fire TV, Firefox Win 10 and iOS
backup /jffs/scripts/nat-start
cp /jffs/scripts/nat-start /jffs/scripts/nat-start.bkup_26nov
Remove the prior entry but retain physical backup file
 x3mRouting ipset_name=BBC_WEB3 del
(x3mRouting): 2946 Starting Script Execution ipset_name=BBC_WEB3 del
Done.
(x3mRouting): 2946 IPSET BBC_WEB3 deleted!
DANGER ZONE!
Delete the backup file in /opt/tmp/BBC_WEB3
[1]  --> Yes
[2]  --> No
[1-2]: 2
(x3mRouting): 2946 Completed Script Execution
Create version 4 of BBC_WEB
sh /jffs/scripts/x3mRouting/x3mRouting.sh ALL 3 BBC_WEB4 dnsmasq=2cnt.net,bbc.com,bbcverticals.com,co.uk,llnwi.net,net.uk
@Sean Rhodes
Done.
DANGER ZONE!
[1]  --> Yes
[2]  --> No
[1-2]: 2
Mine is slightly different than yours, maybe due to running the 384.18 firmware version, but here is my output:
rhodess@RT-AC3200-4200:/tmp/home/root# cp /jffs/scripts/nat-start /jffs/scripts/nat-start.bkup_25nov
rhodess@RT-AC3200-4200:/tmp/home/root# x3mRouting ipset_name=BBC_WEB3 del
(x3mRouting): 25462 Starting Script Execution ipset_name=BBC_WEB3 del
(x3mRouting): 25462 IPSET BBC_WEB3 deleted from /jffs/configs/dnsmasq.conf.add
Done.
(x3mRouting): 25462 Script entry for BBC_WEB3 deleted from /jffs/scripts/nat-start
/jffs/scripts/nat-start has 1 shebang entry and 0 empty lines.
Would you like to remove ?
[1]  --> Yes
[2]  --> No
[1-2]: 2
(x3mRouting): 25462 ipset BBC_WEB3 entry deleted from /jffs/scripts/x3mRouting/vpnclient3-route-up
/jffs/scripts/x3mRouting/vpnclient3-route-up has 1 shebang entry and 0 empty lines.
[1]  --> Yes
[2]  --> No
[1-2]: 2
(x3mRouting): 25462 ipset BBC_WEB3 entry deleted from /jffs/scripts/x3mRouting/vpnclient3-route-pre-down
/jffs/scripts/x3mRouting/vpnclient3-route-pre-down has 1 shebang entry and 0 empty lines.
[1]  --> Yes
[2]  --> No
[1-2]: n
[*] n Isn't An Option!
0 2 * * * ipset save BBC_WEB3 > /opt/tmp/BBC_WEB3 #BBC_WEB3#
(x3mRouting): 25462 CRON schedule deleted: #BBC_WEB3# '0 2 * * * ipset save BBC_WEB3'
(x3mRouting): 25462 IPSET BBC_WEB3 deleted!
(x3mRouting): 25462 Completed Script Execution
rhodess@RT-AC3200-4200:/tmp/home/root# sh /jffs/scripts/x3mRouting/x3mRouting.sh ALL 3 BBC_WEB4 dnsmasq=2cnt.net,bbc.com,b
(x3mRouting.sh): 30770 Starting Script Execution ALL 3 BBC_WEB4 dnsmasq=2cnt.net,bbc.com,bbcverticals.com,co.uk,llnwi.net,net.uk
(x3mRouting.sh): 30770 ipset=/2cnt.net/bbc.com/bbcverticals.com/co.uk/llnwi.net/net.uk/BBC_WEB4 added to /jffs/configs/dnsmasq.conf.add
Done.
(x3mRouting.sh): 30770 IPSET created: BBC_WEB4 hash:net family inet hashsize 1024 maxelem 65536
(x3mRouting.sh): 30770 CRON schedule created: #BBC_WEB4# '0 2 * * * ipset save BBC_WEB4'
(x3mRouting.sh): 30770 Selective Routing Rule via VPN Client 3 created for BBC_WEB4 fwmark 0x4000/0x4000
(x3mRouting.sh): 30770 iptables -t mangle -D PREROUTING -i br0 -m set --match-set BBC_WEB4 dst -j MARK --set-mark 0x4000/0x4000 2>/dev/null added to /jffs/scripts/x3mRouting/vpnclient3-route-up
(x3mRouting.sh): 30770 iptables -t mangle -A PREROUTING -i br0 -m set --match-set BBC_WEB4 dst -j MARK --set-mark 0x4000/0x4000 added to /jffs/scripts/x3mRouting/vpnclient3-route-up
(x3mRouting.sh): 30770 iptables -t mangle -D PREROUTING -i br0 -m set --match-set BBC_WEB4 dst -j MARK --set-mark 0x4000/0x4000 2>/dev/null added to /jffs/scripts/x3mRouting/vpnclient3-route-pre-down
(x3mRouting.sh): 30770 sh /jffs/scripts/x3mRouting/x3mRouting.sh ALL 3 BBC_WEB4 dnsmasq=2cnt.net,bbc.com,bbcverticals.com,co.uk,llnwi.net,net.uk added to /jffs/scripts/nat-start
(x3mRouting.sh): 30770 Completed Script Execution
Done.
[1]  --> Yes
[2]  --> No
[1-2]: 2
[1]  --> Yes
[2]  --> No
[1-2]: 2
[1]  --> Yes
[2]  --> No
[1-2]: n
Done.
Excellent! I did some more surfing of iPlayer on Fire TV and now have up to 125 IPv4 addresses collected so far. It is working without using the ASN for BBC.
So far I haven't seen what's disrupting mine, it seems no matter what I do, every 3rd show I have to restart my dnsmasq and ovpn. Usually, that works, but lately, I had to exit and re-enter iPlayer to get it to play
I recommend doing some analysis using the scripts available in option 4. I would start by routing all traffic to the VPN client you use for BBC and make sure iPlayer works okay that way. Then, use the autoscan.sh script and search for "uk" or "bbc" terms. The getdomainnames.sh script will give you a big picture view of what is being queried.
I will do. Ideally I would like to shutdown everything except the one machine I’m using and on that have nothing except iplayer running and then log the files. It will have to be an early morning chore though otherwise I get too many wife and son complaints when I shut things down. Ideally I should grab another router and setup a different network and test on that I think.
How does one install an older version of x3m? Can I just use the curl command and replace the master with desired version?
So for version 2.3, replace this:
sh -c "$(curl -sL https://raw.githubusercontent.com/Xentrk/x3mRouting/master/Install_x3mRouting.sh)"
With this?
sh -c "$(curl -sL https://raw.githubusercontent.com/Xentrk/x3mRouting/x3mRouting-2.3.0/Install_x3mRouting.sh)"
Thanks!
Want to stick with Merlin 384.18 for now since this configuration was working great.
With this?
Go to thread 14, there’s a direct link, you can also go to the x3mRouting fit page and select the branch for 384.18
Thanks!
What's thread 14 and fit page?
With this?
Thanks!
I saved the compatible version in a branch:
Installation
sh -c "$(curl -sL https://raw.githubusercontent.com/Xentrk/x3mRouting/x3mRouting-384.18/Install_x3mRouting.sh)"
Will work with 384.13 to 384.18 firmware versions.
Dear Xentrk,
for a few days, I have problems with populating my amazon prime video rules. In my natstart the following entries are there:
sh /jffs/scripts/x3mRouting/x3mRouting.sh 1 0 AMAZON-EU aws_region=EU
sh /jffs/scripts/x3mRouting/x3mRouting.sh 1 0 AMAZON-US aws_region=US
sh /jffs/scripts/x3mRouting/x3mRouting.sh 1 0 AMAZON-CA aws_region=CA
sh /jffs/scripts/x3mRouting/x3mRouting.sh 1 0 AMAZON-AP aws_region=AP
sh /jffs/scripts/x3mRouting/x3mRouting.sh 1 0 AMAZON-CN aws_region=CN
sh /jffs/scripts/x3mRouting/x3mRouting.sh 1 0 AMAZON-GLOBAL aws_region=GLOBAL
sh /jffs/scripts/x3mRouting/x3mRouting.sh 1 0 AMAZON-SA aws_region=SA
My router reboots everyday as a cron job. As I recognized , that prime video has sometimes problems, I checked the liststats.
I found out, that sometimes the lists are populating very differently. Sometimes only the EU List is populated (532 entries), sometimes Global (108) and EU and sometimes other regions are populated as well. I rebootet the router a lot of times and I am getting different population. Do you have an idea, why that is occuring ? Could my DNS Server sometimes filter, so that not all lists are populated ?
Forward local domain queries to upstream DNS --> No , using quad9 as dns servers.
Netflix is working normally.
Is there a command for forcing a new population of the iprules (so that I don´t have to reboot everytime the router for testing)? Is it possible to add a cron job that the router is trying to repopulate after e.g. 5 Minutes of rebooting again and add the missing entries ?
Thanks a lot for your support.
Hugo
PS: The best "population" I recieved after reboot was (and that was working perfectly):
AMAZON-AP - 579
AMAZON-CA - 61
AMAZON-CN - 93
AMAZON-EU - 532
AMAZON-GLOBAL - 108
AMAZON-SA - 75
AMAZON-US - 963
Installation
Installed this, only first option gets installed the other 3 throws out an error, as in expected package size is different
