immi803
In the waiting list like youAc88? Noone?![]()
![Er... what? o_O o_O](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f635.png)
That "source code" is a firmware, not actual source code. Look at the size.
The latest g6368a955e8 alpha only shows OFDMA DL on my RT-AX56U. I reverted back to g38ed4a85db and now have the OFDMA DL + UL and AX MU-MIMO option again. Also my vacuum refuses to connect on 2.4G on the latest but reverting fixes the issue,
webui: hide OFDMA UL/MIMO settings for RT-AX88U and RT-AX56U
These require updated SDKs/GPLs, we currently only have the
one for the RT-AX58U.
Likely related to this blurb from 384.17 release notes, and now 384.18 is based on the newer GPL.only trouble is I rolled back to 384-17 rel and now cannot log in to router gives me wrong password or login name ,i've tried in4 browsers all the same . do i have to reset and start over ? or is there another easier way ?
thanks
384.17 (26-Apr-2020)
Updating some models (like the RT-AC88U) from stock firmware
3.0.0.4.384_81790 and newer will require a factory default reset
after flashing Asuswrt-Merlin, due to a change in how Asus
stores the admin password starting with 384_81790.
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind B4:E6:2D:C6:FE:DD, status: 0, reason: Michael failure (e)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(481): eth5: Disassoc B4:E6:2D:C6:FE:DD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 2C:3A:E8:2E:91:D2, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 5C:CF:7F:78:27:FD, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 5C:CF:7F:58:47:C9, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 2C:3A:E8:2E:8F:C5, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 34:CE:00:A2:5E:03, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 5C:CF:7F:66:C0:EB, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 78:11:DC:80:FC:F8, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 5C:CF:7F:92:D2:79, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 5C:CF:7F:92:30:A5, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:09+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind CC:50:E3:B6:63:98, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
<13>1 2020-05-30T19:15:10+02:00 AC86UG-7B53F3A-C wlceventd - - - wlceventd: WLCEVENTD wlceventd_proc_event(466): eth5: Deauth_ind 04:CF:8C:76:61:34, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Hopefully this GPL adds this support.
thanks
Welcome To SNBForums
