[ 386.4 alpha Build(s) ] Testing available build(s)
Not sure if this is related to this build, or whether it exists in prior builds. But go into the AImesh section of the menu. After it loads, try moving the mouse across the menus and the submenus appear UNDER the AImesh picture / nodes. cleared browser, tried Firefox, Chrome, Edge - same issue...
Example:
Example:
Do you use scMerlin?
Example:
this is an scmerlin addon issue, not firmware related
Here is to hoping for a GT-AXE11000 build.
... if nothing more than to get rid of the god awful 1337 G@m3R UI.
Red all over and GRAY TEXT ON A GRAY BACKGROUND. Someone needs to be run over by a 2 year old in a dukes of hazard power wheel.
Aug 11 was last test build. Does this gap mean that Merlin is cooking up a meaty next test build (like a GPL source integrated)?
The suspense....
Don't mention upcoming releases. You're going to ruin the surprise! ;)
Nothing at all going on right now.
Ride that uptime baby!
Ax88u just noticed something, don't know if it a alpha problem or common problem.
My vpn client settings never seem to be remembered, its set to start vpn client on boot, but it never does, always have to activate it manually.
Weird thing is on a manual reboot it seems to work and reboot scheduler is enabled, it reboots earlier hours of morning, wondering if its related to that?
So here is some more VPN weirdness that resulted in Nord VPN shutdown when run from the router...
Aug 23 21:44:15 ovpn-client1[2751]: --cipher is not set. Previous OpenVPN version defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add '--data-ciphers-fallback BF-CBC' to your configuration and/or add BF-CBC to --data-ciphers.
Aug 23 21:44:15 ovpn-client1[2752]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Aug 23 21:44:15 ovpn-client1[2752]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1618', remote='link-mtu 1634'
Aug 23 21:44:15 ovpn-client1[2752]: WARNING: 'keysize' is used inconsistently, local='keysize 128', remote='keysize 256'
Aug 23 21:44:16 ovpn-client1[2752]: WARNING: You have specified redirect-gateway and redirect-private at the same time (or the same option multiple times). This is not well supported and may lead to unexpected results
Aug 23 21:44:19 ovpn-client1[2752]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Aug 23 22:44:15 ovpn-client1[2752]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1618', remote='link-mtu 1634'
Aug 23 22:44:15 ovpn-client1[2752]: WARNING: 'keysize' is used inconsistently, local='keysize 128', remote='keysize 256'
Aug 23 23:44:15 ovpn-client1[2752]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1618', remote='link-mtu 1634'
Aug 23 23:44:15 ovpn-client1[2752]: WARNING: 'keysize' is used inconsistently, local='keysize 128', remote='keysize 256'
MANY MORE ENTRIES LIKE THIS, THEN INTERNET ACCESS FAILED WITH THESE ENTRIES:
***d inconsistently, local='link-mtu 1618', remote='link-mtu 1634'
Aug 24 17:44:17 ovpn-client1[2752]: WARNING: 'keysize' is used inconsistently, local='keysize 128', remote='keysize 256'
Aug 24 17:48:20 dnsmasq[2799]: Maximum number of concurrent DNS queries reached (max: 150)
Aug 24 17:48:29 dnsmasq[2799]: Maximum number of concurrent DNS queries reached (max: 150)
Turned off the Nord VPN, and internet access restored?? Ideas?
All of these warnings are perfectly normal, or just logging quirks in OpenVPN itself related to their implementation of NCP.
IF you cannot route Internet traffic, then it means you probably did not configure your client to redirect Internet traffic.
...these warnings are perfectly normal, or just logging quirks in OpenVPN itself related to their implementation of NCP.
I do have all traffic routed through the VPN, but this is the thing that's new and I've never seen:
'Aug 24 17:48:29 dnsmasq[2799]: Maximum number of concurrent DNS queries reached (max: 150).'
When that item dropped into the log, that's when the internet traffic stopped?
My VPN Client settings that I think applicable are:
You have a dns-related issue, causing a backlog of queries to fill the limit of 150 concurrent queries.
What's the difference with this build and Merlin if any? Could not find the answer to this question...
