[ 3004.388.7 alpha 2 Build(s) ] Testing available build(s)
@Stonehym
Please add a signature with your router model and your setup. You should especially provide more information about your wlan settings settings. Some screenshots would be helpful.
Hi all, my printer already has a static local IP configured and show it on its screen as connected with that IP since it was first connected on the network (up and runnning).
No problem at all with the Guest network disabled. The Guest network messes up the stability of its connection. The printer itself doesn't complain, only the other devices connected on the same network (NOT the Guest network) either don't see it or their ping shows lost packages. It's like the Guest network is parasiting the Wifi connection to the printer. Yet, based on the feedback, I think the printer is to blame, not the router.
Static and Reservation are not the same!
For printers, reservation is better (on Any router)...
Hm, I'm not sure what that means... Can you point out the menu for me, please? :)
Thanks!
One sets manual IP reservations in the router GUI on the LAN > DHCP Server page. You enable the Manual Assignment option then add each manual reservation.
If you want to set a static IP address then one keys that in on the printer screen (if there is one) or in the printer configuration/setup software.
..... Beta firmware is out.
We can close this thread
@RMerlin
