thelonelycoder
Part of the Furniture
See the screenshot in post #308...Is the logstats email function included in the v2.1?
I always do a backup of the jffs partition through the WebUI to be on the safe side. But never in the life of my Dev RT-AC66U have I had problems. That router is rock solid and so is Merlins work. 35 Firmware versions in and no loss of data. That is impressive on its own.Different question: Does the adblock survive the installation of a newer firmware?
Absolutely! Easy as pie...Is there any way to block a domain with this solution?
Example: we seem to have websites that has the first section as id of some kind:
b3245634.trackerdomain.com
b2317542.trackerdomain.com
What I would like to do is block:
*.trackerdomain.com
How do I do that?
trackerdomain.com
in the blacklist hostfile?
That is all AB-Solution does, block Domains. No IP addresses, no Telephone numbers, just Domain names.Is there any way to block a domain with this solution?
AFAIK AP mode does not allow the device to resolve it's own DNS.I'm using my AC66U in AP mode.
Can i still benefit from AB-Solution?
I tried making dnsmask resolve names, but only got timeouts.
I really wish there were more good stories like yours to read here.Got my brother in law updated today onto 2.0.1. All went smooth after some fiddling (more self inflicted).
You make a good point by saying AB-Solution should be smarter in it's decision making in a case like yours.You think we should add some small logic to do a check on start up to see what state ab is in before we make a "suggestion" of how the user should proceed? Or is the manual option of forced re-install already the answer? Of course, if you are halfway competent in terminal, then this will be no big deal. But I am thinking for future users who install ab-solution, but then issue factory resets and want to install it again. Maybe we can make the health check prior to install/upgrade/re-install a little more thorough, and THEN issue a suggested option to the user when they hit "i" to install it again, instead of suggestion of "upgrade".
Funny you mention that. A lot of the code that is in previous versions - and especially so in the upcoming v2.1 - are checks for pebcak errors.Only food for thought, and just suggestions to make life easier in the future to weed out static in the threads.
# write the /jffs/scripts/ files
## THE MOST COMPREHENSIVE CHECK JFFS-FILES HAVE EVER SEEN! ##
My mobile devices are all on an unlimited plan.P.S., I am already spoiled by ad blocking. The moment I leave the house and drop off the wifi and back onto 4G, the pain becomes real again
Only pixelserv-tls for me, but i like the idea of leaving the custom IP block to cater for possible alternate solutions. How will ab-solution handle the need to reserve an IP outside of the dhcp range for pixelserv to listen on?A question for 'custom block IP' (cb) users: What services are you using to direct it to?
Only pixelserve-tls, or are others used?
I'm planning on leaving the (cb) option in, even with PS coming in that version.
Some may still want to use their own PS installation or use another service.
Using the built in PS and the (cb) option are mutually exclusive, but you may use one at a time.
The IP addresses are separately stored for the two, so you can even switch back and forth between them.
You will set the reservation during the install in the WebUI when prompted. Instructions are provided.How will ab-solution handle the need to reserve an IP outside of the dhcp range for pixelserv to listen on?
I have no plan to do so, the 'ifconfig br0 pixelserv <pixelserv IP> up' in wan-start is used by AB-Solution. No other option is planned.The only reason I use a custom IP for pixelserv-tls is so that I can still have http access to the web ui for the router. I found the https access somewhat iffy.
Are you planning something different, or do you move the webui to https?
Installed with Entware? No problem.Sort of new to all this so I'm waiting for version 2.1 for ease of use. I currently have dnscrypt-proxy (https://github.com/jedisct1/dnscrypt-proxy) installed. Will AB-Solution overwrite this, or might there be any other compatibility issues?
Nope, just Entware. Thank you!Installed with Entware? No problem.
Are you using additional /jffs/scripts/* scripts apart from the entware installed ones? If so, post full script content so I can verify AB-Solution won't touch it.
Thread starter | Title | Forum | Replies | Date |
C | Is there any easy solution in Merlin for a VPN server that is hard to block/detect? | Asuswrt-Merlin | 15 | |
[SOLUTION] WAN_Connection: ISP's DHCP did not function properly | Asuswrt-Merlin | 6 |
Welcome To SNBForums
