[Alpha] Pre-release test builds available (both 380 and 382 branches)
Installed new alpha on both my AC3100 and my AC68U all working fine so far. I noticed right away that memory usage on the AC68U dropped by 4%. That's really great news.
@RMerlin is there a changelog about this maybe? Thanks
Check the hash tags in the filename, they match hashes on Github.
merlin@ubuntu-dev:~/am382$ git log 5038276..def3266 --oneline
def3266 webui: display HTTPS cert settings on the DDNS page at all time, warning user about DDNS being required for LE support
5f03d42 nvram: split OpenVPN Custom field into three nvrams on HND, increasing its max length from 170 to 510 characters
85255b3 shared: implement nvram_split_set()
07d0ad4 webui: fix validator regexp for IE11
290bd4f Revert "nvram: split dhcp_staticlist into 10 nvrams on HND platform to work around the 1000 chars limitation"
81e7658 httpd: enable Let's Encrypt support on the RT-AC68U
54188e1 Updated documentation
5934145 minidlna: remove scantag once done when doing a rescan rather than a rebuild
ca0637a Updated documentation
ff2a782 nano: updated to 2.9.1
3a5955c webui: validator: provide regexp to RegExp() as constructors instead of strings, otherwise the "-" character isn't properly escaped.
a1e0c98 webui: fix field names on DDNS page
786260e strongswan: compile with -O3 optimization
add64ce rom: fix zoneinfo directory location in Makefile (revert Asus change from 382_18991 which is broken)
hello, sorry if this is a known bug, but i have qos off, but when i put NAT Acceleration to auto it stays disabled. i tried searching this thread and i couldnt find anyone else with this issue. 68u here. other than that everything seems to be working great. i have 200meg internet service and speed tests i get 200, but on torrents i cant download faster than 100m , not sure related to NAT Acceleration or not. everything in my network is gig nics and i have plenty of peers(non public).
thanks
Am i correct there should be no need for a factory reset going from 382.2 A2 8276 to 382.2 A2 3266
That's correct. If you experience any weirdness do a factory reset.
Did you reboot after putting on Auto? With no Qos,try to put it on Auto, Apply and reboot. Work for me.
Can't have qos and ctf at the same time. Sorry.
Disable QOS then enable CTF if you want hardware acceleration.
I could not find why I still had this message in the wireless section after Factory reset * Reminder: The System time zone is different from your locale setting.* ... Until I notice this : Admin-system : DST time zone changes ends (1 month 2nd Sun Week & days 2 hours). Replacing month 1 by 10 or 11 fixed it.
*B/G protection cant be unticked.
*VPN page broken in french (IE,Firefox). Js Console error : (SyntaxError: missing ; before statement),(ReferenceError: initial is not defined)
Cheers :)
Factory reset done after flashing
382.2_alpha2-gdef3266
Where I can set HW acceleration on RT-AC86U? In which page/tab I mean
Under the LAN tab then choose Switch Control.
Hardware Acceleration is not used very often. It is often in conflict with your settings. If you have a lot of Lan Ethernet devices maybe you want to look at it but if not leave it off.
So the “One CPU at 100%” bug I’ve been having is due to the “process” below, found by using the “top” command in SSH. Make sense to anyone else? AC3100, latest 382 alpha, all AI protection on, absolution and transmission installed.
User:nobody
Stat:R
Command: usr/sbin/portmap
User:nobody
Stat:R
Do a factory reset or re-flash or both.
Is it possible that I don't have this in Switch control if I enable the Adaptive QOS?
Flashed RT-AC68U to 382.2_alpha2, my observation is internet seems very responsive, pages are snapping up.
One item I would like to report is that Media Server indicates is always 'scanning...', I do not believe is it scanning because CPU usage & memory usage does not seem to support activity of that nature. I have also streamed a movie while router was reporting scanning and my minidlna index file seems fine.
FYI, latest 382.2 alpha2-gdef3266 corrects the Media Server always indicating scanning, it is showing idle for me now.
