Vexira
Part of the Furniture
3.0.0.4.382.18991 for the 88uI don't know, which Asus GPL included these fixes?
thanks a lot was just wondering if the didn't make the merge that's all, I really appreciate it.Then they're included, this release is based on 382_18991.
Thanks for new test builds. IPSec VPN seems to work perfectly. Alexa skill seems not enabled for Canada and shows geographic restrictions. IFTTT also not registering for some reason. IFTTT and Alexa are probably going to need fix from Asus. Great to see at least VPN is working as it should.
Anyone know if the latest AC3100 alpha build will run on a AC68U?
Why will you use an AC3100 alpha build to an AC68U? AC68U has its own Alpha2 test firmware FYI.Anyone know if the latest AC3100 alpha build will run on a AC68U? The change log isn't really conclusive enough for me to make the decision yet. If it works I have a AC68U to test with.
Thank you I was dreaming I guess. Does anyone else find this firmware uses a serious amount of memory? RT-AC68U I'm at 66% with three scripts running QOS and AI-Protection.Why will you use an AC3100 alpha build to an AC68U? AC68U has its own Alpha2 test firmware FYI.
The memory usage for rt-ac68u will be high in 382 branch compared to 380 cause Broadcom allocated a reserve memory percentage for its usage if I'm not mistaken mentioned by Merlin. Do a search of Merlin's post it's around somewhere.Ok both the AC3100 and the AC68U are running stable on the new 382.2_alpha2-g5038276, however memory usage on the AC68U is quite high around 68% of the 256Meg it has.
The memory usage for rt-ac68u will be high in 382 branch compared to 380 cause Broadcom allocated a reserve memory percentage for its usage if I'm not mistaken mentioned by Merlin. Do a search of Merlin's post it's around somewhere.![]()
Cool! Like you said before "Whats the point of having the resources and not using them" I'll add especially for security.The new trendmicro engine adds around 50MB of extra usage. For devices like the AC68U there is enough spare resources where this isn't much of a concern, the AC86U on the otherhand is quite resource constraint.
With build 382.2_alpha2, I seem to have some issues with DDNS page not working correctly. I already had Asus DDNS setup and tried to add lets encrypt option but then get error indicating no changes were made and to click yes to apply but there is no yes button and pressing ok button does nothing. If I try to disable DDNS and hit apply then nothing seems to happen. Anyone else have this issue?
Welcome To SNBForums
