Is there AI Mesh in these prereleases? I installed it on one of my AC68 but couldnt find it so figuring it isn't included.
If the thermostat is constantly dropping and scanning for connection then that might be the reason your nest is going to low batt, otherwise, the router has no influence. If it's not already, use the 2.4GHz band for the connection for a better stability, nest use single stream anyway even for the 5GHz band.Is there any chance that the new alpah builds are causing a draing on a nest thermostat? I'm asuming that is unlikely, but since installing the last alpha 2 (a day ago), it has gone into low battery mode. This can sometimes be caused by routers that don't deal well with low energy devices.
https://www.snbforums.com/threads/b...0-69-beta-is-now-available.42660/#post-363382Hey @RMerlin I just updated to 380.69_beta1 on my AC5300 and I noticed this bug. I have attached it. I don't think anyone else mentioned it so I figured I'd let you know! Again, thanks for your hard work and dedication!
Thanks! I'm clearly blind haha!
It's possible, however, my nest thermostat is just fine with 68P 382.2 alpha 2.Now that I'm back to the non-alpha firmware, all seems well. I think there is an issue with some firmware and low energy using devices (such as thermostats). At any rate, I'll wait until Merlin gets further along with this build (at least beta) before I try again.
Thanks. I actually rolled back to the last stable non alpha merlin version, and all seem seems to be well again. This is not definitive, because I'm in Mass, and its getting bloody cold, but I suspect that the version 2 of the alpha software (prior to the version that was just dropped last night, whcih is also alpha version 2) was causing issues with the next thermostat. I've never, ever, had an issue with the battery before, and diagnosis showed it was getting charge, but not fast enough to replace.
Does the latest build include this for the 88u?
Bug Fixed
- Fixed IPTV related issue
- Fixed IGMP snooping related issue.
Which version of alpha 2. There was an earlier and a more recent version (don't know why no increment in the number when that happens).
Both alpha 2's works with nest. Like what Merlin said, hash tags differ plus the dates.Which version of alpha 2. There was an earlier and a more recent version (don't know why no increment in the number when that happens).
Welcome To SNBForums
