Entwares htop, install with:Nice image. How did you produce it?
opkg install htop
Thank you, both. A little over a year ago I was of the opinion I’d leave the router to get on with its stuff and not load it up with “extras”. Now I’m running Diversion, pixelserv-tls and Skynet (with AMTM, of course), along with Jack Yaz’s diversion stats and now htop. Reminds me of Harold Macmillan’s “You’ve never had it so good” slogan.Entwares htop, install with:
Code:opkg install htop
I recently added htop as an option in scmerlinThank you, both. A little over a year ago I was of the opinion I’d leave the router to get on with its stuff and not load it up with “extras”. Now I’m running Diversion, pixelserv-tls and Skynet (with AMTM, of course), along with Jack Yaz’s diversion stats and now htop. Reminds me of Harold Macmillan’s “You’ve never had it so good” slogan.
Do you install it if it isn't already installed?I recently added htop as an option in scmerlin![]()
Just updated and not getting the purty colorz anymore? Previous versions looked fine. Maybe a term setup on my side? Using Bitvise, tried xterm and xterm-256, both look same.
Correct. The color schemes have always been managed by Diversion, but the Diversion-less default has been changed to B/W because some people were having problems with the colors in certain terminals.No I don't use Diversion. So the old one had all the purty colors, and the screenies on page 1 look all purty, but now theres not purty colors unless you load Diversion?
The above update will bring back your purty colorz.Just updated and not getting the purty colorz anymore? Previous versions looked fine.
That code has not changed for several versions in both amtm and Diversion.entware installation is broken in latest amtm v2.3. Just upgraded to alpha 384.12 from 384.11_2 with a clean install and tried reinstalling all the scripts. Both amtm terminal as well as diversion is not able to install entware. Every time i try to install entware i get an error- "entware (aarch64) installation failed."
Its failing even on 384.11_2.
My router- RT86U
Edit: Both Skynet and Yazfi wifi are working.
yep, i guess entware servers are down because i tried installing entware via entware-setup.sh and the script is hanged.That code has not changed for several versions in both amtm and Diversion.
It'll show errors in the greyed out Entware installation output. Maybe Entware or its servers don't respond for you. I cannot test it at the moment.
If you can't access http://bin.entware.net/ then find out why. It's working fine here.yep, i guess entware servers are down because i tried installing entware via entware-setup.sh and the script is hanged.![]()
StrangeIf you can't access http://bin.entware.net/ then find out why. It's working fine here.
Welcome To SNBForums
