Beta Asus RT-AX89X_9.0.0.4_388_31185 Beta
Yes you are right.
I copy the versión of topic but the 31307 si the last posted un this topic.
But no new version since january??
I've had the 32039 firmware running for a 4 days now, and the memory issue is definitely better than in 22525 in that the RAM usage creeps up a lot more slowly. After install and an additional reboot, the RAM usage was at 57%, and now it's at 59%. Before, it would be in the mid-60s after a reboot and would be near 70% after a few days.
Not fix in 388 firmware. Мemory leak caused by asd daemon. Мemory leak issue caused by nt_center daemon. In progress.
Seemed to also be present in the latest 386 firmware. I woke up this morning to disconnection alerts from devices, power cycled my 89X only to find memory climbing steadily to 100% and effectively crashing within 10 minutes. Checked top in the SSH portal and noted asd appeared to be the culprit, no other changes occurred and I don't have much enabled. Found this thread and updated to 388_31307. Memory is stabilized at 51% for the past 15 minutes thus far.
