Asuswrt-Merlin 3.0.0.4.270.24 BETA 4 is out
Nothing found in syslog that would indicate a dialin-process with .24
In the syslog of .23 I found the following lines:
A similar entry in syslog of .24 is missing, syslog ends with
syslog of .24 has only 140 lines up to that entry, in the syslog of .24 I can find 375 lines...
I could send you the two logfiles per PM if you want...
The timeout on PADO seems to indicate that the router sees the modem, sends the discovery packet to your ISP, but the ISP never answered back.
Could you try leaving build 24 on for 5-10 mins just to see if it does eventually connect, in case it's just a timing issue?
In the mean time if you could email me the logs, that could also be useful (Email them instead of a PM, not sure how PM handles attached files).
Also send me the output of this command, through telnet/ssh, from both FW versions:
cat /proc/bus/usb/devices
That will show me if the modem is indeed properly detected.
email is on the way...
Code cat /proc/bus/usb/devices:
There is a difference between the two versions:
in version 266_23b I get
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
and in version 266_24 Beta you can find
I:* If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
No driver implemented in version 266_24 Beta?
Ciao
Gerald
ipv6 is working on mine
openvpn server is running
I have a 500gb usb drive hooked to router and it's functional
There is some problem with netfilter modules loading in this firmware.
I'm using IPV tunnel with SixXS ipv6 broker.
That's was I see after reboot:
PID USER       VSZ STAT COMMAND
    1 admin     2008 S    /sbin/init
    2 admin        0 SW<  [kthreadd]
    3 admin        0 SWN  [ksoftirqd/0]
    4 admin        0 SW<  [events/0]
    5 admin        0 SW<  [khelper]
   19 admin        0 SW<  [kblockd/0]
   50 admin        0 SW   [pdflush]
   51 admin        0 SW   [pdflush]
   52 admin        0 SW<  [kswapd0]
   53 admin        0 SW<  [aio/0]
   97 admin        0 SW<  [mtdblockd]
  120 admin        0 SW<  [kmmcd]
  323 admin      568 S    hotplug2 --persistent --no-coldplug
  364 admin     1996 S    console
  365 admin     1220 S    /bin/sh
  370 admin        0 SWN  [jffs2_gcd_mtd5]
  376 admin     1212 S    syslogd -m 0 -S -O /tmp/syslog.log -s 256 -l 7
  379 admin        0 SW<  [khubd]
  391 admin     1212 S    /sbin/klogd
  451 admin     2004 S    usbled
  491 admin        0 SW<  [scsi_eh_0]
  492 admin        0 SW<  [usb-storage]
  510 admin     2004 S    /sbin/wanduck
  511 admin     1228 S    udhcpc -i eth0 -p /var/run/udhcpc0.pid -s /tmp/udhcpc -H xxxxx -O33 -O249
  520 admin     1212 S    telnetd
  523 admin     1016 S    dropbear -p 22
  525 admin     2012 S    /tmp/udhcpc bound
  529 admin      968 S    /bin/eapd
  558 admin     1404 S    nas
  559 admin     2004 S    wpsaide
  562 admin     1084 R    dropbear -p 22
  608 admin     1020 S    /usr/sbin/acsd
  616 nobody     904 S    dnsmasq --log-async
  617 admin     3468 S    httpd
  618 admin     3524 S    httpd -s -p 443
  626 admin     1224 S    crond
  627 admin      936 S    /usr/sbin/infosvr br0
  628 admin      944 S    networkmap
  637 admin     1140 S    rstats
  640 admin     2004 S    watchdog
  641 admin     2004 S    ots
  669 admin      972 S    lld2d br0
  671 admin     1224 S    -sh
  675 admin      712 S    miniupnpd -f /etc/upnp/config
  707 admin     4976 S    minidlna -f /etc/minidlna.conf
  736 admin     4976 S    minidlna -f /etc/minidlna.conf
  737 admin     4976 S N  minidlna -f /etc/minidlna.conf
  760 admin     9416 S    lighttpd-monitor
  774 admin     1960 S    u2ec
  776 admin     1028 S    lpd
  782 admin     1960 S    u2ec
  783 admin     1960 S    u2ec
  795 admin      724 S    radvd -u admin -d 5
  797 admin      688 S    dhcp6s -c /etc/dhcp6s.conf br0 -D
  798 admin      724 S    radvd -u admin -d 5
 1063 admin     1020 S    inotify
 1064 admin     5308 S    asuswebstorage
 1065 admin     1020 S    inotify
 1066 admin     1020 S    inotify
 1067 admin     1020 S    inotify
 1069 admin     5308 S    asuswebstorage
 1078 admin     5308 S    asuswebstorage
 1103 admin     1220 D    modprobe -r xt_length
 1247 admin     2084 S    mt-daapd -m
 1248 admin     2084 S    mt-daapd -m
 1250 admin      864 S    mDNSResponder 10.10.1.254 thehost Asus66U _daap._tcp. 3689
 1251 admin     2300 S    nmbd -D -s /etc/smb.conf
 1252 admin     2084 S    mt-daapd -m
 1253 admin     3176 S N  smbd -D -s /etc/smb.conf
 1259 admin     2084 S    mt-daapd -m
 1261 admin     5308 S    asuswebstorage
 1262 admin     5308 S    asuswebstorage
 1264 admin     5308 S    asuswebstorage
 1270 admin     9884 S    lighttpd-arpping -f br0
 1279 admin     1216 R    ps
The "modprobe -r xt_length" never ends.
The parent process for modprobe is "525 /tmp/udhcpc bound"
As the result, the rc script cannot do normal initialization, and ntp server is never asked for time. Also, udhcpc does not renegotiate the lease (my provider expires it in 300 seconds) and Internet connection stops very soon.
When I disable IPv6 tunnel, it works just fine.
.24 Sysinfo Ethernet Ports works on Chrome not on IE 9
I installed .24 and the ethernet ports are listed on the Sysinfo tab using Chrome. None are not listed (line is blank) using IE 9.
IE9
Network
HW acceleration Enabled
Connections 1153 / 16384 - 186 active
Ethernet Ports
Wireless clients (2.4 GHz) Associated: 1 - Authorized: 1 - Authenticated: 1
Wireless clients (5 GHz) Associated: 0 - Authorized: 0 - Authenticated: 0
Chrome
Network
Connections 1095 / 16384 - 193 active
Ethernet Ports
Port Link State Last Device Seen
WAN 1000 Full Duplex 00:01:5c:31:e4:41
LAN 1 Down <none>
LAN 2 1000 Full Duplex JANOFSKY7
LAN 3 Down <none>
LAN 4 1000 Full Duplex undefined
IE9
Network
Ethernet Ports
Chrome
Network
Ethernet Ports
LAN 1 Down <none>
LAN 3 Down <none>
Yep, this is a known problem...see:
http://forums.smallnetbuilder.com/showpost.php?p=58816&postcount=37
and go back to the image that came with the orginal post referenced in the above post.
Thanks everyone. I'm sorting through the feedback received.
Some of the reported issues (especially around the Ethernet Port status) have been fixed. Changes so far since the first Beta release:
   - CHANGED: Temperatures on Sysinfo page will now update every 3 seconds.
   - CHANGED: Connections page now uses Ajax for slightly better rendering
   - FIXED: 1-3 seconds delay loading the Sysinfo page due to Ethernet ports query.
   - FIXED: Temperature on Performance Tuning page would fail to update if a radio was disabled.
   - FIXED: Ethernet port status would not display under IE.
   - FIXED: Display of Connections under IE
State of the other issues:
  • 3G modem not being properly configured by the firmware: I'm going to send the reporter some test builds to help isolate the cause, since I have no way to reproduce it myself, and at a first glance I can't think of any change that might be causing it (there has been no change related to USB drivers). In the mean time, I'm interested to hear about anyone else using a 3G modem, and whether it's working for you or not.
  • >2TB HDD support. I'm going to order a 3 TB HDD this week so I'll be able to do some more thorough testings.
  • IPv6 tunnel. I got mixed reports so far. Going to test it myself using my 6in4 tunnel with HE.
The other reported issues should be looked into during the week. In the mean time, please continue reporting your results, both positive and negative.
I cannot reproduce your problem here with my IPv6 HE tunnel. Do you have any custom script or firewall rules that would use the xt_length module and prevent it from being unloaded by the firmware?
The following command should tell you if it's used:
lsmod | grep xt_length
Did you have the same issue with previous versions of the firmware, or just with 24 beta 1?
EDIT: I noticed that there is indeed a dead modprobe process on my router as well now, I just didn't experience any WAN issue probably because my lease hasn't expired yet. It's odd since running modprobe -r from the shell immediately returns with a proper error message. Could be a compatibility issue introduced with the new busybox.
Why are these Temp results from telnet
ASUSWRT RT-N66U_3.0.0.4 Thu Jan 24 05:24:25 UTC 2013
admin@RT-N66U:/tmp/home/root# wl -i eth1 phy_tempsense
61 (0x3d)
admin@RT-N66U:/tmp/home/root# wl -i eth2 phy_tempsense
67 (0x43)
have a different temp results from Tools?
61 (0x3d)
67 (0x43)
They're raw values returned by the thermistor. To convert them into the actual temperature, you have to divide them by two, and add 20 to them.
[*] IPv6 tunnel. I got mixed reports so far. Going to test it myself using my 6in4 tunnel with HE.
My NTP clock doesn't automatically set itself either... though that's easy to sort out by logging into an TELNET/SSH session
ntpclient -h ntp.pool.org -s
I also have an ipv6 tunnel with HE. The ipv6 tunnel connects ok but when it's connected I get repeated comments from miniupnpd (shown below) I think it did this before but didn't complain in the log?
Jan 27 09:51:40 miniupnpd[599]: Failed to get ip address for interface
Jan 27 09:52:32 miniupnpd[599]: Failed to get ip address for interface
Jan 27 09:53:14 miniupnpd[599]: Failed to get ip address for interface
Jan 27 09:53:49 miniupnpd[599]: Failed to get ip address for interface
Also when running the example firewall rules ip6tables complains about not being able to find the chain... I don't know that much about ip6tables so perhaps it's me.
admin@RT-N66U:/tmp/home/root#  ip6tables -A INPUT -j DROP
ip6tables: No chain/target/match by that name
admin@RT-N66U:/tmp/home/root# ip6tables -I FORWARD 2 -m state --state RELATED,ESTABLISHED -j ACCEPT
admin@RT-N66U:/tmp/home/root# ip6tables -A FORWARD -i v6in4 -o br0 -p all -j DROP
admin@RT-N66U:/tmp/home/root# ip6tables -A FORWARD -i br0 -o any -p all -j ACCEPT
admin@RT-N66U:/tmp/home/root# ip6tables -A FORWARD -i br0 -o v6in4 -p all -j ACCEPT
admin@RT-N66U:/tmp/home/root# ip6tables -A FORWARD -i any -o br0 -p all -j ACCEPT
admin@RT-N66U:/tmp/home/root# ip6tables -A FORWARD -j DROP
Apart from these things for me it's working well.
Thanks.
Time for Beta 2? :D
Yes, I looked at my router log this morning at about 10AM, and the time showing there was 2AM. I checked the timezone to be sure that I'd changed it, and the timezone is correct. It isn't exactly 8 hours off, etiher, so it isn't just displaying GMT. This has always worked, so I was surprised to see that.
ntp.pool.org is not too reliable to get the time with in my experience. I've since changed it to the closest ntp server in my area and so far time is not problematic anymore.
In IE9, both Traffic monitor and Performance tuning show half screen.
See the screen shots attached
Looks fine here in both IE 9 and 10. You might try dumping your browser cache, cookies, and then exit and re-invoke your browser.
Works fine for me as well under IE10.
Try a different browser just to see if the issue is limited to your IE setup. You can also try opening the error console (Press F12, then go to the Console tab) to see if there is any specific error. Note that there will be many warnings, some of the webui isn't very IE-friendly.
I also had problems initially with traffic monitor and was getting an error in the logs showing a file problem. I reset the data files and advanced data files and it seemed to do the trick for me.
I did not watch specifically for stuck kernel modules, but for sure I never lost WAN in 5 minutes after reboot with v23.
OK. So further investigation from my side it not needed then?
I have also a problem with IPv6 in v23: ip6 packets lost or not routed between LAN and 6in4. This problem may exist in legacy firmware as well. I did not investigate it deeper yet.
By the way, is there any IPv6 capable tcpdump exist for this firmware? The one I've installed with optware cannot decode this protocol properly.
