Can I ask why so many of you are using VPN?
??? is ok?
When I use a Merlin build,...
- The parental control don't work.
- I can't print on my printer (I need to restart the router)
When I use the Asus build, the parental control don't work, but my printer works good.
I am still on 372.31 with my N66u. Should i upgrade to this version or the experimental sdk5 version?
That depends.
I need the better range from sdk5.
sdk5 doesn't give me any connection issues with the WiFi devices my family uses.
YMMV
Flashed last night my AC56U to 374.35.2 and here are my observations:
- after upgrading the FW (from 34.2), the UI told me to power cycle the router to reboot\
- after power cycle, it seemed to be fine, but nevertheless I cleared NVRAM and re-entered all the settings
- and then I tried to setup VPN... the new UI definitely has some quirks as it took me few attempts to set it up
- once you upload .opn file, there is NO indication in the UI that the file has uploaded correctly
- In short, even though I managed to get VPN to show as connected in the UI, I lost my internet access, and I was not able to restore it. Turning off the VPN helped to restore internet connection.
So OpenVPN client is not working for me... the simplification of UI did not work
- WiFi 2.4 GHz - just as bad as before, if not worse. With 34.2 I got to the point that when the laptop is one meter away from the router, it can hold 300Mbps connection. With 35.2, it fluctuates wildly - and this is after I "forgot" the network and re-established connection.
To summarize - with my very limited testing, for AC56U, .34.2 seems much better firmware. The only beef I have with 34.2 - I need to reboot it periodically as the internet seems to slow down over the time (could be crappy VDSL modem)
This is an RT-AC66U (skyrealm) running 374.34_2, with one wall between the router and the client:
http://www.lostrealm.ca/temp/rssi_34_2.png
This is the same router, running 374.35_2:
http://www.lostrealm.ca/temp/rssi_35_2.png
Skyrealm68 is the RT-AC68U which was in the same room as the test laptop.
The only thing outside of the wireless driver that can affect it is the initialization code, which configures its power levels and timings. This code hasn't been changed either.
Yeah, everybody's going connection issues, and yet I have none.
upgraded to 374.35_2 and cleared nvram. Setup into AP-mode manually and enabled stealth mode.
Still have the issue, that after enabling stealth mode all LEDs are disabled, but after rebooting and waiting for ~5-7 secs the USB 2.0 LED will be enabled again (only happens after everytime I do a reboot and stays active until I reenable stealth mode or use the back on the back to disable all LEDs.
Welcome To SNBForums
