Aug 26 19:33:34 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link UP at 1000 mbps full duplex
Aug 26 19:33:35 wlceventd: wlceventd_proc_event(685): eth7: Auth A8:51:AB:0F:A6:78, status: Successful (0), rssi:0
Aug 26 19:33:35 wlceventd: wlceventd_proc_event(722): eth7: Assoc A8:51:AB:0F:A6:78, status: Successful (0), rssi:-66
Aug 26 19:33:36 wlceventd: wlceventd_proc_event(662): eth7: Disassoc A8:51:AB:0F:A6:78, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 26 19:33:40 wlceventd: wlceventd_proc_event(662): eth7: Disassoc 22:CE:A4:A1:A8:72, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 26 19:33:41 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link DOWN.
Aug 26 19:33:43 wlceventd: wlceventd_proc_event(685): eth7: Auth 22:CE:A4:A1:A8:72, status: Successful (0), rssi:0
Aug 26 19:33:43 wlceventd: wlceventd_proc_event(722): eth7: Assoc 22:CE:A4:A1:A8:72, status: Successful (0), rssi:-67
Aug 26 19:33:45 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 3C:7C:3F:55:B5:39, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-45
Aug 26 19:33:46 wlceventd: wlceventd_proc_event(662): eth6: Disassoc 3C:7C:3F:55:B5:39, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 26 19:33:46 kernel: wfd_unregisterdevice Successfully unregistered ifidx 1 wfd_idx 0
Aug 26 19:33:49 wlceventd: wlceventd_proc_event(645): eth8: Deauth_ind 3C:7C:3F:55:B5:3C, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-52
Aug 26 19:33:50 wlceventd: wlceventd_proc_event(662): eth8: Disassoc 3C:7C:3F:55:B5:3C, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 26 19:33:50 kernel: wfd_unregisterdevice Successfully unregistered ifidx 1 wfd_idx 2
Aug 26 19:33:55 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) (phyId: b) Link UP at 1000 mbps full duplex
Aug 26 19:34:07 lld2d[1272]: get_icon_image: reading iconfile /usr/sbin/icon.ico FAILED : No such file or directory
Aug 26 19:34:08 lld2d[1272]: get_icon_image: reading iconfile /usr/sbin/icon.ico FAILED : No such file or directory
Aug 26 19:34:09 wlceventd: wlceventd_proc_event(685): eth6: Auth 3C:7C:3F:55:B5:39, status: Successful (0), rssi:0
Aug 26 19:34:09 wlceventd: wlceventd_proc_event(722): eth6: Assoc 3C:7C:3F:55:B5:39, status: Successful (0), rssi:-46
Aug 26 19:34:10 wlceventd: wlceventd_proc_event(662): eth6: Disassoc 3C:7C:3F:55:B5:39, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 26 19:34:13 lld2d[1272]: get_icon_image: reading iconfile /usr/sbin/icon.ico FAILED : No such file or directory
Aug 26 19:34:14 lld2d[1272]: get_icon_image: reading iconfile /usr/sbin/icon.ico FAILED : No such file or directory
Aug 26 19:34:36 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind 64:BC:58:B9:30:C0, status: 0, reason: Unspecified reason (1), rssi:0
Aug 26 19:37:34 wlceventd: wlceventd_proc_event(662): eth7: Disassoc F8:B1
D:4A:61:B4, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 26 19:37:36 wlceventd: wlceventd_proc_event(662): eth7: Disassoc 2A:5D:F0:2C:C9:71, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 26 19:37:36 roamast: [EXAP]Deauth old sta in 1 0: 2A:5D:F0:2C:C9:71
Aug 26 19:37:36 roamast: eth7: disconnect weak signal strength station [2a:5d:f0:2c:c9:71]
Aug 26 19:37:36 roamast: eth7: remove client [2a:5d:f0:2c:c9:71] from monitor list
May 5 07:05:06 kernel: klogd started: BusyBox v1.25.1 (2023-08-21 15:35:27 EDT)
May 5 07:05:06 kernel: Linux version 4.1.51 (merlin@ubuntu-dev) (gcc version 5.5.0 (Buildroot 2017.11.1) ) #4 SMP PREEMPT Mon Aug 21 16:27:45 EDT 2023
May 5 07:05:06 kernel: CPU: AArch64 Processor [420f1000] revision 0
May 5 07:05:06 kernel: Kernel command line: coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait
