Release Asuswrt-Merlin 3004.388.6 is now available
Dirty update from beta - all work just fine, tnx!
Welcome to the forums @fka.
Importing an old saved backup config file negates the full reset you were doing.
As nobody can effectively comment on what state your router was in, it is hard to say what the issue is/was.
All that is known for sure is that the router was not in a good/known state. And the newest firmware highlighted that fact.
As I mentioned importing my saved config put it back in the same, failed, post update state.
I had 3 backups from the last month or so, most recent taken just before attempting the update to 3004.388.6. None off them worked.
Within the last 4 months the AX88U has been relegated from main router to AiMesh node and then changed again to an AP last month. Each time with a factory reset. The AP setup was very basic with a few default wifi settings changed.
If it wasn't in a good/known state I hadn't seen any evidence in the syslog or function.. Either way happy to chalk this down to bad luck!
Upgrade from the Beta - all OK so far.
What's the 'ethtool ' mentioned in the changelog.
Dirty upgrade from 3004.388.6_beta1 to the newest release 3004.388.6 on RT-AX56U.
Update itself took about 2 minutes, but everything seems to good.
  • Internet speeds are as they should be.
  • IPv6 working.
  • Wifi/IoT devices working.
  • SMB/FTP working.
  • Wireguard/OpenVPN servers working.
  • Wireguard clients auto connected and working.
  • Skynet, Diversion, DNSCrypt, ntpMerlin and Scribe working.
I will report back if issues come up.
Thank you! @RMerlin
Example output on a RT-AX86U Pro (3004.388.6) using ethtool to display eth0 settings.
RT-AX86U_Pro-xxxx:/tmp/home/root# ethtool eth0
Settings for eth0:
        Supported ports: [ TP ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Half 1000baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: Symmetric
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
        Link partner advertised pause frame use: No
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Port: Twisted Pair
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
        MDI-X: Unknown
        Link detected: yes
  • IPv6 working.
  • SMB/FTP working.
Thank you! @RMerlin
Spoke too soon and found out that Skynet isn't starting. Started SSH connection to router and went to AMTM and opened Skynet and this is what I saw. Tried manually to restart it, but nothing happened. What could I try to do? Any recommendations?
Edit: And now it just came up? Oh well... I should give these routers time to boot up before starting to make these posts. 😅
Did a power cycle & dirty flash from 3004.388.5 to 3004.388.6.
Also checked the downloaded file on MD5 & SHA256.
All runs good.
Thank you Eric.
I'm using an AX58U and after the upgrade DDNS stopped working. Unfortunately the solutions in this forum didn't work for me (turning DDNS Off-On and modifying the SSL Certificate mode on the WebUI.)
Result is always the same:
DDNS Registration ResultUnable to connect to the Internet
inadyn[25688]: In-a-dyn version 2.10.0 -- Dynamic DNS update client.
inadyn[25688]: Guessing DDNS plugin 'default@duckdns.org' from 'duckdns.org'
inadyn[25688]: Resolving hostname [redacted].duckdns.org => IP# [redacted]
inadyn[25688]: Get address for default@duckdns.org
inadyn[25688]: Checking for IP# change, connecting to wtfismyip.com([65.108.75.112]:443)
inadyn[25688]: Checking for IP# change, initiating HTTPS ...
inadyn[25688]: Certificate verification error:num=20:unable to get local issuer certificate:depth=2:/C=US/O=Google Trust Services LLC/CN=GTS Root R1
inadyn[25688]: OpenSSL error: 3069966896:error:1416F086:lib(20):func(367):reason(134):NA:0:
inadyn[25688]: Communication with checkip server wtfismyip.com failed, run again with 'inadyn -l debug' if problem persists
inadyn[25688]: Retrying with built-in 'default', api.ipify.org ...
inadyn[25688]: Checking for IP# change, connecting to api.ipify.org([64.185.227.156]:443)
inadyn[25688]: Certificate verification error:num=19:self signed certificate in certificate chain:depth=3:/C=GB/ST=Greater Manchester/L=Salford/O=Comodo CA Limited/CN=AAA Certificate Services
inadyn[25688]: Failed to get IP address for default@duckdns.org, giving up!
inadyn[25688]: Update forced for alias [redacted].duckdns.org, new IP# [redacted]
inadyn[25688]: Sending IP# update to DDNS server, connecting to www.duckdns.org([3.97.82.174]:443)
inadyn[25688]: Sending IP# update to DDNS server, initiating HTTPS ...
inadyn[25688]: Certificate verification error:num=20:unable to get local issuer certificate:depth=3:/C=US/ST=Arizona/L=Scottsdale/O=Starfield Technologies, Inc./CN=Starfield Services Root Certificate Authority - G2
inadyn[25688]: Will retry again, rc=33
inadyn[25688]: Error code 33: Failed connecting to DDNS server (HTTPS)
If using
ssl = false
in the inadyn.conf file it is working fine.
FYI @RMerlin
Super stable release
Updated RT-AX86U from 3004.388.5 to 3004.388.6.
I was prompted to manually reboot to complete update.
I also had to renew/export/install a new certificate as https no longer worked.
All good apart from that.
Read second NOTE on first post!
Update-notification
Missing firmvare version in log.
Jan 21 04:45:24 watchdog: New firmware version .._ is available.
Screenshot 2024-01-21 at 15-55-19 ASUS Wireless Router GT-AX6000 - Firmware Upgrade.png
@RMerlin
Upgraded from 3004.388.5 to 3004.388.6 on 4 x RT-AX86U - all good! THANKS!
