Ripshod
RT-AX68U will not be getting the 3006. You are to use the much more mature 3004 releases.Why AX68 is not on the list?
The "list" in post #1 is for "models that are not included in this release". Therefore this release (3004.388.9) is available to download for your RT-AX68U. The 3006.102 firmware is for different routers.Your not realy helpful with this. Certainly, I have read it, but the AX68 version of this firmware is on the download list, but not on the 3006.102. So, I need explanation.
AAAAH! ThanksThe "list" in post #1 is for "models that are not included in this release". Therefore this release (3004.388.9) is available to download for your RT-AX68U. The 3006.102 firmware is for different routers.
Which list are you specifically referring to?Why AX68 is not on the list?
noticed that, my iPV6 capable clients show that now, the more info the better?Seeing that as well but also seeing the IPV6 addresses for some of the devices (all but two wired)
/opt/bin/entware-services stop
command. This is to make sure the next step will be successfull;halt
command to stop the router;I have exactly the same problem. Anyway to fix it?Seeing that as well but also seeing the IPV6 addresses for some of the devices (all but two wired)
Did you try a different browser? I don't have that effect on Firefox.
But on previouDid you try a different browser? I don't have that effect on Firefox.
It was the first thing I did. I saw more people in this thread reporting the same issue. And this only happens with long names for the network devicesTry to clear your browser cache and try again.
CTRL-F5
If you have any exotic characters in the name, try choosing a simpler word to try with.It was the first thing I did. I saw more people in this thread reporting the same issue. And this only happens with long names for the network devices
Welcome To SNBForums
