So, for giggles and to confirm behavior. Switched back to WPA2/WPA3-Personal, all three SSID's but one at a time. And sure enough the problems we,
@ExtremeFiretop and I were having with WiFi devices connecting immediately happend, mostly impacting the devices trying to connect to the nodes, but had a couple that didn't connect to the router either, the same ones I had issues with before, that I need to setup again, but with all the smae settings.
Well, at least it's consistent in that respect. As soon as I changed everything back to WPA2-Personal, and waited a bit for things to settle, everything connected back up.
Might try a couple of other things, I just need to reconfigure things to use them ,maybe even the other Authentication Methods to see if those cause the issue as well.
But I still wonder, after I reverted the previous FW, I still had the same issue. I actually had to WPS reset and restore the Router and each node to get it working again when I rolled back. I did compare all the NVRAM settings and logs and didn't see anything different or out of place. I have to think this is at low level to affect that, something that can likey only be addressed by ASUS, more so as it has a greater impact (but not exclusively) on AiMesh which is closed source and completely invisible to
@RMerlin
For now with WPA2-Personal and everything connected on the Router and nodes, all on 388.9 - All good!
