Asuswrt-Merlin 3006.102.4 Beta is now available. There are a number of significant things to note with this release:
1) BCM4912 models are now migrated to this 3006 code base. This includes the following device list:
2) New addition - the RT-BE92U is now supported. Note that the GPL used for this initial support suffers from some CPU-related issues, so support for this model at this time should be considered EXPERIMENTAL. If you lose the ability to access the router, then power cycle it, that usually solves it.
If I don't get a fix from Asus in time for the final 3006.102.4 release, then I will skip this device until Asus can provide a fix, and release the final build for the other models.
3) Beside the addition of new models, the focus of this release is the merge of GPL code (I currently need to manage three separate GPL versions for this release.....), updated components, and a number of fixes.
Changelog:
Make sure you do read the changelog, especially if migrating from 3004 to 3006. I documented the known recommendations from Asus' own changelog, but there might be further compatibility issues arising when upgrading from 3004. In particular, I would recommend disconnecting and reconnecting any AiMesh node. Also, double check Wireless settings.
For this beta release I need test feedback for:
Please keep discussions on this specific beta release.
Downloads are here.
Changelog is here.
- GT-AX6000
- zenWifi Pro XT12
- GT-AX11000 Pro
- GT-AXE16000
- RT-AX86U Pro
- RT-AX88U Pro
Changelog:
3006.102.x (xx-xxx-xxxx)
- NOTE: If migrating from a 3004 firmware, only the first Guest
Network will be migrated - any additionnal GN must be
manually reconfigured.
- NOTE: If migrating from a 3004 firmware, the Wireless Scheduler
will need to be manually reconfigured if you were using
it.
- NOTE: As a reminder, the ROG variant of the webui is not
supported in the 3006 firmware series, as maintaining
two separate interfaces is too much extra work.
- NEW: Moved RT-AX86U_PRO, RT-AX88U_PRO, ZenWifi Pro XT12,
GT-AX6000, GT-AXE16000 and GT-AX11000_PRO to the
3006 firmware series.
- NEW: Added RT-BE92U support, based on GPL 102_37435. This GPL
seems to have some stability issues, so consider support
for this model to remain Beta, until a fix is provided
for it.
- UPDATED: Merged GPL 3006.102_36521 for Wifi 6 models (Wifi 7
GPL codebase is unchanged from 3006.102.3).
- UPDATED: OpenVPN to 2.6.14.
- UPDATED: miniupnpd to 2.3.7 (20250207 snapshot)
- UPDATED: amtm to 5.2 (decoderman)
- UPDATED: dnsmasq to 2.91.
- UPDATED: dropbear to 2025.87.
- FIXED: Missing hostname on Wireless Log for MLO-capable Wifi 7
clients.
- FIXED: CVE-2024-9143 in OpenSSL (Debian backport by RSDNTWK)
- FIXED: CVE-2024-13176 in OpenSSL (Ubuntu backport by RSDNTWK)
- FIXED: Guest Networks on an isolated VLAN with DNSDirector set
to "Router" would fail to do any name resolution.
- FIXED: Wrong tab selected when clicking on "Profile" on the VLAN
page (dave14305)
- The models that were migrated from 3004
- General RT-BE92U performance (there is a known issue with a CPU core often getting stuck at 100%, that will need to be fixed by Asus)
- The Wireless Log page should be more accurate on Wifi 7 devices, the root problem of missing/incorrect hostnames having been resolved
Downloads are here.
Changelog is here.
