almost nothing to do with that release- except there have been many posts in this thread about firmware versions that update cfe's. i reposted it elsewhere.Wrong thread, this has nothing to do with the 376.49 release.
There is this whole thread on this, which is referenced several time in this thread.
http://forums.smallnetbuilder.com/showthread.php?t=19521
That requires you to enable telnet, and to use a telnet client. If you aren't familiar with it, I recommend against doing that. Instead, either press the reset button for 5 seconds while the router is on, or turn it on with the WPS button pressed, wait 10 secs, then release it. EIther procedure should also clear nvram.
Thank you, but unfortunately I am complete noob and I can't follow what's being talked about in that thread. I am not even sure how would I start erasing nvram, and hoping someone would have step by step tutorial, but wrong... I guess I'd be better off with regular ASUS firmware installed as much as I'd hate to go back. Merlin's firmware seems so much more stable.
To erase nvram is easy. Simply turn the router off wait about 10 seconds then power the router back on while holding down the WPS button continue to hold the WPS button for about 15 seconds then release and let the router boot up, nvram will be cleared and the router will be back to factory default.
...either press the reset button for 5 seconds while the router is on, or turn it on with the WPS button pressed, wait 10 secs, then release it. EIther procedure should also clear nvram.
mtd-erase2 nvram
Thanks for your help!
Two more questions:
1. If I perform factory reset, after the firmware update, can I load my configuration file I made with previous firmware to avoid setting everything from scratch, or is there something drastically different in this new firmware vs the old one?
2. How does one do nvram erase? I guess I'd have to use putty or some terminal, but I am not sure I am savvy enough for this task![]()
Using a saved config file defeats the purpose of the factory reset. Use John's nvram save & restore utility available in this forum.
You could use putty but the easiest method is to power off the router, press and hold the WPS button for 5 seconds, power up the router and continue to hold the WPS button for 7-10 seconds. The power LED should pulsate rapidly indicating the nvram is being erased.
I'll have to take a closer look at the John's restore utility that everyone is praising here. I believe it's great, I was just afraid to dig deeper into this, just to avoid screwing something terribly
I will do manual nvram erase then, but now when I tried Putty and successfully logged into my router, I got kind of interested as to why my attempt to erase nvram using mtd-erase2 nvram command, did not give me any results. After pressing ENTER key, cursor simply jumped down one prompt line.
You dont need to putty in the router. The above WPS method gives the same result and is much easier. If you do use Putty you also have to enable telnet or ssh in the routers UI.
Anything new with ipv6 on .49? Tried _5. Didn't think it would change anything and it didn't. Still not obtaining an ipv6 address on Comcast. .48 works.
Is it safe to update to your RT-AC68U_3.0.0.4_376.49_6_cfeupd this way then (I'm still on RT-AC68U_3.0.0.4_376.49_5)?
1.) While my router is still on, I press and hold reset button for 5 seconds (in order to erase nvram),
2.) update the normal way to RT-AC68U_3.0.0.4_376.49_6_cfeupd
3.) load my old settings from CFG file I made on RT-AC68U_3.0.0.4_376.49_5 (or that's not safe to do this time?)
"...ip6tables ensures that you cannot override them, by rejecting connection to other DNS servers."
No, it's the other way around.
The reason why you want to do a factory default reset is because you want all those factory defaults to be those of the *new* firmware. So, it has to be done after you flashed the new firmware, and you can't reload your old settings or otherwise you will just reapply the exact same old settings you were trying to change.
Strange... I'm on TWC here in metro Dallas - on their fastest 100 Mb service, with latest Motorola DOCSIS3 modem, and I get nothing when I enable IPv6. Have it set to "Native" like you, and DNS set to automatic, and get absolutely nothing at all.Pleased to see ipv6 work perfectly and immediately with "Time Warner Cable" in Cincinnati, Ohio USA. With _49 firmware, using the "native" connection type on the ipV6 configuration page of Merlin menus. Happening to be using the Google Public DNS server addresses of 8.8.8.8 and 8.8.4.4 set on the WAN page.
Interesting that ipV6 came to a halt when I tried changing the ipv6 DNS from automatic to manual, with the Google Public DNS ipv6 addresses set to 2001:4860:4860::8888 etc. Am sure that is related to the behavior RMerlin described in the changelog as
Anyway with the ipV6 DNS left on the default of "automatic" everything was great.
Oh, OK. Much clearer now. So, basically I should proceed with updating firmware from my current one RT-AC68U_3.0.0.4_376.49_5 to this new one called RT-AC68U_3.0.0.4_376.49_6_cfeupd.
Once the update process is done, I should erase nvram and after that, proceed with manual configuration of my settings (all those entries for my DHCP server), port forwarding I had set up etc.
Welcome To SNBForums
