Could be a UI glitch, since FA is not available on the RT-AC68U. Only the RT-AC68P, RT-AC87, and RT-AC3200.
had an interesting situation re NAT acceleration.
So, I'm really wondering what allowed it to work after that factory reset...![]()
Doe sthis firmware works at the RT-Ac3200?
I don't see how you are determining that WPS is enabled - Wifi Analyzer does not mention anything related to WPS with either my RT-AC87U, or any of my neighbours. Can you provide a screenshot?
Any Eta to merlin builds become to 3200 one?
Thanks again
@RMerlin Did you see my questions about the IPTV GUI? Or did I ask for something that has been asked before or did I ask for it in the wrong place?
this is how it looks on my Wifi Analyzer:
Thanks again
I don't get any WPS report on my own RT-AC87U when I checked with my Nexus 9.
Are you using a VPN tunnel? If yes, that might be obfuscating all your traffic from the router's DPI engine.
Otherwise, I don't know. Both the DPI engine and the components that interact with it are closed source, and I have never experienced that issue here.
Not yet, no. It's under development, and I don't have any ETA. However, it shouldn't be more than 1-2 weeks for a public alpha build, as progress went faster than expected (faster than with the previous new models I had to add).
Merlin said in post #1 : Once the dust has settled on this release .50 (meaning after any minor update releases if necessary), I will begin work on adding support for the RT-AC3200. Complete support for that device will probably take a few weeks, as it involves merging in a new SDK into the code repository
Be patient![]()
No, both SSID are broadcasted.Do you have hidden SSIDs? After flash and factory reset I didn't touch the WPS tab at all as it stated disabled, yet broadcasted as capable...
Have you actually tried to connect using WPS ? Does it connect ? That would confirm if that function is working and a possible issue.
$ iperf -c 192.168.9.35 -t 20 -i 1
Client connecting to 192.168.9.35, TCP port 5001
TCP window size: 1.06 MByte (default)
[ 3] local 192.168.9.191 port 41785 connected with 192.168.9.35 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0- 1.0 sec 768 KBytes 6.29 Mbits/sec
[ 3] 1.0- 2.0 sec 512 KBytes 4.19 Mbits/sec
[ 3] 2.0- 3.0 sec 512 KBytes 4.19 Mbits/sec
[ 3] 3.0- 4.0 sec 512 KBytes 4.19 Mbits/sec
[ 3] 4.0- 5.0 sec 512 KBytes 4.19 Mbits/sec
[ 3] 5.0- 6.0 sec 384 KBytes 3.15 Mbits/sec
[ 3] 6.0- 7.0 sec 128 KBytes 1.05 Mbits/sec
[ 3] 7.0- 8.0 sec 640 KBytes 5.24 Mbits/sec
[ 3] 8.0- 9.0 sec 512 KBytes 4.19 Mbits/sec
[ 3] 9.0-10.0 sec 640 KBytes 5.24 Mbits/sec
[ 3] 10.0-11.0 sec 640 KBytes 5.24 Mbits/sec
[ 3] 11.0-12.0 sec 512 KBytes 4.19 Mbits/sec
[ 3] 12.0-13.0 sec 128 KBytes 1.05 Mbits/sec
[ 3] 13.0-14.0 sec 256 KBytes 2.10 Mbits/sec
[ 3] 14.0-15.0 sec 384 KBytes 3.15 Mbits/sec
[ 3] 15.0-16.0 sec 768 KBytes 6.29 Mbits/sec
[ 3] 16.0-17.0 sec 128 KBytes 1.05 Mbits/sec
[ 3] 17.0-18.0 sec 384 KBytes 3.15 Mbits/sec
[ 3] 18.0-19.0 sec 256 KBytes 2.10 Mbits/sec
[ 3] 19.0-20.0 sec 512 KBytes 4.19 Mbits/sec
[ 3] 0.0-20.7 sec 9.00 MBytes 3.65 Mbits/sec
[ 3] local 192.168.9.191 port 41810 connected with 192.168.9.35 port 5001
[ 3] 0.0- 1.0 sec 32.9 MBytes 276 Mbits/sec
[ 3] 1.0- 2.0 sec 40.8 MBytes 342 Mbits/sec
[ 3] 2.0- 3.0 sec 39.1 MBytes 328 Mbits/sec
[ 3] 3.0- 4.0 sec 39.2 MBytes 329 Mbits/sec
[ 3] 4.0- 5.0 sec 39.2 MBytes 329 Mbits/sec
[ 3] 5.0- 6.0 sec 41.0 MBytes 344 Mbits/sec
[ 3] 6.0- 7.0 sec 43.1 MBytes 362 Mbits/sec
[ 3] 7.0- 8.0 sec 43.0 MBytes 361 Mbits/sec
[ 3] 8.0- 9.0 sec 43.1 MBytes 362 Mbits/sec
[ 3] 9.0-10.0 sec 43.4 MBytes 364 Mbits/sec
[ 3] 10.0-11.0 sec 41.9 MBytes 351 Mbits/sec
[ 3] 11.0-12.0 sec 43.8 MBytes 367 Mbits/sec
[ 3] 12.0-13.0 sec 44.2 MBytes 371 Mbits/sec
[ 3] 13.0-14.0 sec 43.2 MBytes 363 Mbits/sec
[ 3] 14.0-15.0 sec 43.9 MBytes 368 Mbits/sec
[ 3] 15.0-16.0 sec 43.4 MBytes 364 Mbits/sec
[ 3] 16.0-17.0 sec 42.0 MBytes 352 Mbits/sec
[ 3] 17.0-18.0 sec 43.8 MBytes 367 Mbits/sec
[ 3] 18.0-19.0 sec 44.4 MBytes 372 Mbits/sec
[ 3] 19.0-20.0 sec 43.5 MBytes 365 Mbits/sec
[ 3] 0.0-20.0 sec 839 MBytes 352 Mbits/sec
Welcome To SNBForums
