Asuswrt-Merlin 378.52 is now available for all supported models.
UPDATE: 378.52_2 is now available, resolving the following issues:
A factory default reset is strongly recommended for the RT-AC87U, due to the changes in the Quantenna firmware.
For RT-AC3200 users, go to the Smart Connect page, and click on the button to revert it to its default settings if you are using Smart Connect, to switch to the latest rules from Asus.
For RT-AC56U users coming from a non-DPI enabled build, a factory default reset is also recommended.
For the others, the recommendations written in the documentation apply.
The highlights of this release:
Downloads are here.
Changelog is here.
- CHANGED: Updated AiCloud prebuilt binaries for MIPS models
- CHANGED: Applied kernel patch for MIPS kernel ported from 376_3861, related to CTF support
- FIXED: AiCloud would fail to start unless you had HTTPS enabled for the webui (causing the key/cert to be missing)
- FIXED: DDNS hostname would become corrupted after backing up your router configuration (Asus bug)
- Merged with Asus's GPL 378_4608. The Quantenna firmware from 378_4950 was also merged, incorporating stability fixes.
- Security improvements to the HTTPS webui: RC4 support was removed, and ECDHE support was added. The preferred cipher will now be ECDHE-RSA-AES128-SHA (if supported by your browser).
- The DPI engine is now part of the regular RT-AC56U firmware.
- Improvements to the DHCP server: you can now supply a second DNS server to your client, and you can also disable the advertisement of the router's own IP as a DNS server.
- EXPERIMENTAL: Tor support has been added, based on Asus's own code. You can find it in the VPN section of the webui.
- Openssl (1.0.0r) and miniupnpd (1.9.20150309) were updated.
- Various performance optimisations were applied to the firmware, more specifically to the webui server, dropbear (SSHD) and various rc services.
- Numerous tweaks and bug fixes related to the JFFS2 partition. Formatting should now work more reliably and not require a second reboot. You can also no longer disable the JFFS2 partition if you have Traffic Analyzer enabled (as it requires this partition to store its database). Finally, the firmware version report should now be more consistant with our numbering scheme (this is also reflected on the firmware filename now).
- Other webui tweaks: removed obsolete support for the Turbo button, the Wireless Client refresh rate is now stored in a browser cookie, RT-AC3200-related fixes to the Sysinfo page, missing/extra pages were corrected while in AP or Repeater mode.
- WAN startup failures at boot time on the RT-AC87U should now be resolved (note: my original fix in alpha3 has been replaced by a more appropriate fix provided by Asus)
- Uniform version number reference throughout the webui (the firmware filename now also uses the correct, shorter version string)
- A lot of other miscellaneous fixes, see the changelog for the complete list
Downloads are here.
Changelog is here.
