This code is entered via telnet ? And I assume it will survive reboots ?
Yes to both questions.
Well, I haven't tried building it myself yet, I've just been using the inspector. It does seem that nvram_get("wan1_upnp_enable") either isn't getting set to 0 when I save the UPnP Settings on the WAN page. I'm not using dual WAN btw.I thought I had tried every possible scenarios without having any issue.
I might just revert it back to Asus's code and forget about trying to handle dual wan properly. That page's code is a mess as you have seen.
if(wan0_unpn_enable == 0 && wan1_upnp_enable == 0){
regarding the policy routing for openvpn client.
I've tested using 0.0.0.0 for the client IP to catch all clients and this leaves no clients using the VPN instead of all going through the tunnel. This is opposite behavior from the documentation.
I can confirm that 0.0.0.0 for destination IP DOES work for all IP that I've tested.
Don't use policy-based routing if you want to redirect all traffic to all destinations - use the "All traffic" mode instead. I suspect the kernel "optimizes" something when you create a rule "all to all", because "all to something" and "something to all" cases both work correctly.
Can somebody please help me.
When I was on 378.51, I was able to telnet to the router without any problem but after upgrading to 378.53, why am I seeing all these strange text when I use PuTTY to telnet to the router? Thanks.
you have SSH enabled in the router but you're using telnet in putty. you should make sure telnet is disabled in the router and use the SSH setting for putty.
thanks. what is the difference now between "no" and "all traffic" ?
Any chance of updating the AC66 Binaries when you have time
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC66U/GPL_RT_AC66U_30043784850.zip
Is there a command to verify the code was accepted or just wait and see if the log does not log any overflow errors ?
I tried the Ad Blocker a month or two ago using a self compiled firmware, I had issues with pages never finish loading. Merlin's recommendation to use an adblock extension is the best way unless for some reason you can't use such extension.
yes, I tested at ipleak.net and dnsleaktest.com
perhaps you should specify something else instead of using ISP DNS. not only for the openvpn DNS switching to work properly but because ISP DNS are usually bad anyway.
I did reinstall but this time I erase nvram before upgrade then I clear browser cookies and now works. Maybe it was nvram or cookies problem. Thank youThere's been no change to the DNS handling code.
bwdpi wrs_url
Welcome To SNBForums
