Similar problem with a N66U. Wireless is up and my mobile connects but it gives an error of limited connectivity. This occurs with this and previous firmware versions.Had to reset to factory defaults after upgrading. Wireless didn't come back up and when I tried the wired connection it wouldn't get a DHCP address coming from 378.54_2.
Yeah, I had power cycled it multiple times before I decided to do a factory reset. Not sure if this is a similar issue to what happened with the first build of 378.54?You probably just needed to do a power cycle - same thing happened here when I tested the build.
I have some strange readings in my Traffic Monitor. I did also see this on the 378.55 Beta 2, same problem on AC68U and AC87U
I have the exact same problem on my 87U, which I reported in the 55 beta 2 thread. Merlin says he reported the issue to Asus a while back, but they haven't fixed it.
First major problem with Merlin build and my router crash !
RT-AC3200, install the 378.55 and can't connect to Wifi and to 192.168.1.1 with ethernet cable.
I try the recovery tool... nothing work's !!!! HELP !
what is the default address is 192.168.1.1 ?
I guess something is wrong with this new firmware.
I have RT-AC56U, flashed from previous merlin fw, it updated OK, but I cannot login anymore using latest firefox (39.0), after entering login/pass it shows same login page again. Impossible to log in
This new firmware login works with latest IceDragon 38.0.5 (it is browser based on firefox) and on Maxthon Browser 3.1.2, but sadly not on latest firefox, which is my main browser. I tried to clear cache, same thing. Impossible to log in.
Other highly annoying thing is that login/pass cannot be remembered anymore (I know, security bla bla bla), but I cannot even copy password into password field anymore. It allows only manual input by typing it by hand., which to me feels like wasting X amount of my daily life when I want to log in as I dont want to use trivial password(s) as its also used for SSH access to my router from internet.
p.s. And woow, just noticed Traffic monitor shows total nonsense with this new fw - WAN traffic sky rocketing - incrases by few GB every few seconds, which even theoreticly cannot be true. My connection is idling.
"This build merges with Asus's GPL 378_6117". 7117?![]()
Clear your browser's cache!Small issue. Mine still says Beta2 in the GUI.
Thanks, for the update!
Welcome To SNBForums
