punchsuckr
Long time lurker here, upgraded from stock build 3754 two days back, reset all, and everything is working very well and perfectly stable with OpenVPN enabled (with the network drive at long last accessible over vpn) and minidlna is working better than stock with my sony TV-with stock I had infrequent disconnects on my TV and the loading bars would never stop inside folders; not so with this one.
Furthermore, like previous stock builds, selecting folders for the dlna server will result in scanning for media being hung (on a reboot or it will never start scanning) and the media server won't work, selecting the whole drive scanning option is the only way I found it works and isn't a problem for me since this is how it has been working since at least build 3754.
The new login (major reason I upgraded seeing the vulnerabilities being fixed in stock builds) works fine with lastpass and so is no trouble at all like in the past.
Presently supporting 2xwired, 3x2.4Ghz and 3x5Ghz clients without issues. No weird error messages in the log. Hoping it stays this way.
Just a minor note-second channel (40Mhz) is incorrectly reported as 1+3 instead of 5 on the wireless icon in the top right.
PS-A couple of beers on me
Cheers!
Edit:Thought I forgot something, its on an n66u.
