Asuswrt-Merlin 378.56_2 is now available
I am running John's 14E1 version, and i've attempted to flash this version. The router reboots and come back like nothing happened. Still 14E1 and all my settings are in tact, anything i need to look at to see why the firmware wont take? I tried from a wifi laptop and also a wired laptop. I also tried restoring factory defaults and that doesn't work either?
Try flashing with 378.55 first , Factory reboot after.Reconfig just a bit and then flash with 378.56_2
If its not work, flash with 376.3626 (official ) from Asus and after with 378.56_2
P.S; we dont know your router model,so im not sure if its 376.3626 for you.If flashing not working , try the first one series 376.XXXX from asus .(376.3626 is for Rt.Ac68)
I don't see anything in the release notes that would address the issue i'm having. I went from .55 to .56 and fixed all issues I was having on 5ghz but now I have issues on 2.4. anything that connects on 2.4 works for a short period of time then just stops responding. if I reset the stack or switch to 5ghz all is fine. when I upgraded I did reset to factory. anybody have any suggestions? not a deal breaker but definitely and inconvenience.
BTW, massive props to Merlin for all his work!
Have you tried 'forgetting' the network credentials for all the 2.4GHz clients and re-associating each one again manually? Or easier, simply use new ssids?
I used new ssids on the reset. sorry I didn't mention that before.
For some reason connecting to a modem bridge gets random drop outs from Wireless. Then the the LAN, needing a reboot and reconnect. Setup in DHCP mode works fine, wireless stable and lan. Shame I cant completly remove the modem but hey.....
Hi everybody! Asus RT-AC68U, installed 378.56_2, everything running very well!
Nothing on USB ports - only 4 ethernet connections and wireless clients on both 2,4 and 5 Ghz - pure routing.
No drops, no interraptions, scheduling switching on and off WiFi radio for night time. Excellent work!
I am happy, thanks to Mr. Merlin!
One thing would like to investigate - after 8 days of uplink RAM usage icreased from 19-20% to 35%, which looks strange for me. After reboot - again 19%.
What could be a reason for this "filling" RAM and how to avoid this?
That's normal operation.
Nothing can be done for this, most of the wireless code is now closed source and locked down due to the FCC's new rules. The corresponding options were removed from the web interface for the same reason, they are now hardcoded inside the closed source components of the firmware.
Would it be possible to do anything at the client end? For example, is there a configuration on Windows that I could set to force it follow a certain region setting?
Thanks for your help.
Discussed it in another thread, but this build is being flaky with UPnP and multiple Xbox Ones. Not showing requests for ports 3074 and 3075 from both consoles in the log, so one gets stuck with moderate/strict NAT. Tried factory reset and various combinations of settings, with no luck. Rolled back to 378.55 and all is well again. Minor concern, but figured I'd throw it out there.
Could you describe your desired behavior (what UPnP does under .55 for example) that this isn't doing? To which device do you want each port forwarded to?
Hmm, I wonder if this is what is happening to me as well.
A lot of my wireless devices are constantly losing connection and I have noticed that my ISP's modem (2wire 3800) has been giving my AC68U a LAN IP instead of a WAN IP, so instead of seeing my public IP on the Network Map it gives a 192.168 address.
RT-AC87U with this fw, operating as an AP, Samba share disabled. My router randomly restarts x times a day, after some samba failure (if I enable smb, it also produces these restarts). I do not use smb, and there aren't any USB devices connected to the router.
With another 87U, also operating as an AP with an older Merlin fw with enabled samba (but not used) works as expected. What should be the problem? The log:
Aug  1 02:00:11 kernel: klogd started: BusyBox v1.20.2 (2015-11-02 10:00:04 EST)
Aug  1 02:00:11 kernel: Linux version 2.6.36.4brcmarm (merlin@mint-dev) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Mon Nov 2 10:09:15 EST 2015
Aug  1 02:00:11 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Aug  1 02:00:11 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug  1 02:00:11 kernel: Machine: Northstar Prototype
Aug  1 02:00:11 kernel: Ignoring unrecognised tag 0x00000000
Aug  1 02:00:11 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug  1 02:00:11 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60416
Aug  1 02:00:11 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug  1 02:00:11 kernel: Memory: 255508k/255508k available, 6636k reserved, 0K highmem
Aug  1 02:00:11 kernel: Virtual kernel memory layout:
Aug  1 02:00:11 kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Aug  1 02:00:11 kernel:     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Aug  1 02:00:11 kernel:     DMA     : 0xf7e00000 - 0xffe00000   ( 128 MB)
Aug  1 02:00:11 kernel:     vmalloc : 0xd0800000 - 0xf0000000   ( 504 MB)
Aug  1 02:00:11 kernel:     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
Aug  1 02:00:11 kernel:     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Aug  1 02:00:11 kernel:       .init : 0xc0008000 - 0xc003d000   ( 212 kB)
Aug  1 02:00:11 kernel:       .text : 0xc003d000 - 0xc03a4000   (3484 kB)
Aug  1 02:00:11 kernel:       .data : 0xc03bc000 - 0xc03df000   ( 140 kB)
Aug  1 02:00:11 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
Aug  1 02:00:11 kernel: Mount-cache hash table entries: 512
Aug  1 02:00:11 kernel: CPU1: Booted secondary processor
Aug  1 02:00:11 kernel: Found a AMD NAND flash:
Aug  1 02:00:11 kernel: Total size:  128MB
Aug  1 02:00:11 kernel: Block size:  128KB
Aug  1 02:00:11 kernel: Page Size:   2048B
Aug  1 02:00:11 kernel: OOB Size:    64B
Aug  1 02:00:11 kernel: Sector size: 512B
Aug  1 02:00:11 kernel: Spare size:  16B
Aug  1 02:00:11 kernel: ECC level:   8 (8-bit)
Aug  1 02:00:11 kernel: Device ID: 0x 1 0xf1 0x80 0x1d 0x 1 0xf1
Aug  1 02:00:11 kernel: bio: create slab <bio-0> at 0
Aug  1 02:00:11 kernel: PCI: no core
Aug  1 02:00:11 qcsapi: write qcsapi conf ok
Aug  1 02:00:11 kernel: PCI: Fixing up bus 0
Aug  1 02:00:12 kernel: PCI: Fixing up bus 0
Aug  1 02:00:12 kernel: PCI: Fixing up bus 1
Aug  1 02:00:12 kernel: VFS: Disk quotas dquot_6.5.2
Aug  1 02:00:12 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug  1 02:00:12 kernel: pflash: found no supported devices
Aug  1 02:00:12 kernel: bcmsflash: found no supported devices
Aug  1 02:00:12 kernel: Boot partition size = 524288(0x80000)
Aug  1 02:00:12 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Aug  1 02:00:12 kernel: nflash: squash filesystem with lzma found at block 28
Aug  1 02:00:12 kernel: Creating 4 MTD partitions on "nflash":
Aug  1 02:00:12 kernel: 0x000000000000-0x000000080000 : "boot"
Aug  1 02:00:12 kernel: 0x000000080000-0x000000200000 : "nvram"
Aug  1 02:00:12 kernel: 0x000000200000-0x000004000000 : "linux"
Aug  1 02:00:12 kernel: 0x00000039a9ec-0x000004000000 : "rootfs"
Aug  1 02:00:12 rc_service: udhcpc_lan 420:notify_rc start_dnsmasq
Aug  1 02:00:12 ntp: start NTP update
Aug  1 02:00:12 kernel: Registering the dns_resolver key type
Aug  1 02:00:12 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Aug  1 02:00:12 kernel:  2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Aug  1 02:00:12 kernel: Available 7 bytes at (off,len):
Aug  1 02:00:12 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Aug  1 02:00:12 kernel: Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
Aug  1 02:00:12 kernel: Creating 2 MTD partitions on "brcmnand":
Aug  1 02:00:12 kernel: 0x000004000000-0x000007ec0000 : "brcmnand"
Aug  1 02:00:12 kernel: 0x000007ec0000-0x000008000000 : "asus"
Nov 13 13:11:50 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Nov 13 13:11:50 kernel: ctf: module license 'Proprietary' taints kernel.
Nov 13 13:11:50 kernel: Disabling lock debugging due to kernel taint
Nov 13 13:11:50 kernel: et_module_init: passivemode set to 0x0
Nov 13 13:11:50 kernel: et_module_init: txworkq set to 0x0
Nov 13 13:11:50 kernel: et_module_init: et_txq_thresh set to 0x400
Nov 13 13:11:50 rc_service: ntp 421:notify_rc restart_diskmon
Nov 13 13:11:50 rc_service: waitting "start_dnsmasq" via  ...
Nov 13 13:11:50 kernel: =================
Nov 13 13:11:50 kernel: robo chk regs:
Nov 13 13:11:50 kernel: ===================
Nov 13 13:11:50 kernel: (0x00,0x5d)Port 5 States Override: 0xfb
Nov 13 13:11:50 kernel: (0x00,0x5f)Port 7 States Override: 0xfb
Nov 13 13:11:50 kernel: (0x00,0x0e)Port 8 States Override: 0x0a
Nov 13 13:11:50 kernel: (0x00,0x08)Port 8 IMP Control Register: 0x00
Nov 13 13:11:50 kernel: (0x02,0x00) Global Management Config: 0x00
Nov 13 13:11:50 kernel: (0x02,0x00) 802.1Q VLAN Control 5: 0x00
Nov 13 13:11:50 kernel: (0x02,0x03) BRCM HDR Control Register: 0x00
Nov 13 13:11:50 kernel: (0x00,0x0b) Switch Mode Register: 0x06
Nov 13 13:11:50 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.105 (r485445)
Nov 13 13:11:50 kernel: wl_module_init: passivemode set to 0x0
Nov 13 13:11:50 kernel: wl_module_init: igs set to 0x0
Nov 13 13:11:50 kernel: wl_module_init: txworkq set to 0x0
Nov 13 13:11:50 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.105 (r485445)
Nov 13 13:12:19 rc_service: skip the event: restart_diskmon.
Nov 13 13:12:33 httpd: start httpd
Nov 13 13:12:33 disk monitor: be idle
Nov 13 13:12:33 kernel: gro enabled with interval 2
Nov 13 13:12:34 Samba Server: daemon is started
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.951189,  0] lib/util_sock.c:667(open_socket_in)
Nov 13 13:12:34 smbd[506]:   bind failed on port 445 socket_addr = 192.168.1.93.
Nov 13 13:12:34 smbd[506]:   Error = Cannot assign requested address
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.951823,  0] smbd/server.c:628(smbd_open_one_socket)
Nov 13 13:12:34 smbd[506]:   smbd_open_once_socket: open_socket_in: Cannot assign requested address
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.952121,  0] lib/util_sock.c:667(open_socket_in)
Nov 13 13:12:34 smbd[506]:   bind failed on port 139 socket_addr = 192.168.1.93.
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.952458,  0] smbd/server.c:628(smbd_open_one_socket)
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.952690,  0] smbd/server.c:796(open_sockets_smbd)
Nov 13 13:12:34 smbd[506]:   open_sockets_smbd: No sockets available to bind to.
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.953129,  0] smbd/server_exit.c:184(exit_server_common)
Nov 13 13:12:34 smbd[506]:   ===============================================================
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.953394,  0] smbd/server_exit.c:186(exit_server_common)
Nov 13 13:12:34 smbd[506]:   Abnormal server exit: open_sockets_smbd() failed
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.953600,  0] smbd/server_exit.c:187(exit_server_common)
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.953795,  0] lib/util.c:1271(log_stack_trace)
Nov 13 13:12:34 smbd[506]:   unable to produce a stack trace on this platform
Nov 13 13:12:34 smbd[506]: [2015/11/13 13:12:34.954047,  0] lib/fault.c:372(dump_core)
Nov 13 13:12:34 smbd[506]:   dumping core in /var/cores/smbd
Nov 13 13:12:35 qtn: bootcfg.tgz exists
Nov 13 13:12:35 kernel: SCSI subsystem initialized
Nov 13 13:12:35 kernel: csw_retry 100
Nov 13 13:12:36 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Nov 13 13:12:36 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Nov 13 13:12:36 kernel: usb usb1: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
Nov 13 13:12:54 rc_service: udhcpc_lan 647:notify_rc start_dnsmasq
If I disable samba on the web interface, I wouldn't like to see this service starting, however in the log, there is it: Nov 13 13:12:34 Samba Server: daemon is started
The WINS server and/or Master Browser options will also start Samba if enabled.
What type of client is 192.168.1.93 (the one that was being complained about in the previous syslog). Also, could you post up another syslog.
What do you mean on "type"? That client is the 87U router in AP mode. This is its (out of the DHCP range) IP from the main router (68U).
I cleared the log and restarted the 87U. After the whole process, I saved the log (http://pastebin.com/G3GDrtkg - it shows the samba errors several times, with two different IPs: .93 and .102 - It is interesting, because 68U binds the .93 IP to 87U's mac address).
Anyway, after a while another "restart" occured, and here is the diff of the log:
Aug  1 02:00:12 qcsapi: write qcsapi conf ok
Nov 13 14:59:44 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Nov 13 14:59:44 kernel: ctf: module license 'Proprietary' taints kernel.
Nov 13 14:59:44 kernel: Disabling lock debugging due to kernel taint
Nov 13 14:59:44 kernel: et_module_init: passivemode set to 0x0
Nov 13 14:59:44 kernel: et_module_init: txworkq set to 0x0
Nov 13 14:59:44 kernel: et_module_init: et_txq_thresh set to 0x400
Nov 13 14:59:44 rc_service: ntp 421:notify_rc restart_diskmon
Nov 13 14:59:44 rc_service: waitting "start_dnsmasq" via  ...
Nov 13 14:59:44 kernel: =================
Nov 13 14:59:44 kernel: robo chk regs:
Nov 13 14:59:44 kernel: ===================
Nov 13 14:59:44 kernel: (0x00,0x5d)Port 5 States Override: 0xfb
Nov 13 14:59:44 kernel: (0x00,0x5f)Port 7 States Override: 0xfb
Nov 13 14:59:44 kernel: (0x00,0x0e)Port 8 States Override: 0x0a
Nov 13 14:59:44 kernel: (0x00,0x08)Port 8 IMP Control Register: 0x00
Nov 13 14:59:44 kernel: (0x02,0x00) Global Management Config: 0x00
Nov 13 14:59:44 kernel: (0x02,0x00) 802.1Q VLAN Control 5: 0x00
Nov 13 14:59:44 kernel: (0x02,0x03) BRCM HDR Control Register: 0x00
Nov 13 14:59:44 kernel: (0x00,0x0b) Switch Mode Register: 0x06
Nov 13 14:59:44 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.105 (r485445)
Nov 13 14:59:44 kernel: wl_module_init: passivemode set to 0x0
Nov 13 14:59:44 kernel: wl_module_init: igs set to 0x0
Nov 13 14:59:44 kernel: wl_module_init: txworkq set to 0x0
Nov 13 14:59:44 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.105 (r485445)
Nov 13 15:00:13 rc_service: skip the event: restart_diskmon.
Nov 13 15:00:27 httpd: start httpd
Nov 13 15:00:27 disk monitor: be idle
Nov 13 15:00:28 kernel: SCSI subsystem initialized
Nov 13 15:00:28 qtn: bootcfg.tgz exists
Nov 13 15:00:28 kernel: csw_retry 100
Nov 13 15:00:29 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Nov 13 15:00:29 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Nov 13 15:00:29 kernel: usb usb1: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
Nov 13 15:00:48 rc_service: udhcpc_lan 627:notify_rc start_dnsmasq
There are no samba errors, so this can be a failed identification of the problem. My other 87U runs as another AP on 378.55_0 fw without any problem/restart/whatever with almost the same settings (guest wifi disabled and there isn't any fix IP address resolved for it on the 68U). :-/
