joegreat
Only the obvious ones: Remove USB devices and reboot before firmware update, plus a factory reset and manual re-config after the update (as you jump so far from past to actual version).Other than the cpu usage reporting issue, are there any known problems or precautions to upgrade an RT-N66U from 378.51 to 380.57?
