Asuswrt-Merlin 384.8 is now available
Hello,
I have a issue with my RC5300.
It's a translate issue with french language.
All data is not visible, this is capture compare french-english
Best regards.
Hi, I just updated for my AC86U. Everything works well.
There is just a small problem with the VPN client, the select client instance does not work. We can not choose client 1, 2, 3, 4, or 5.
Don't know if this is a problem? router.asus.com fails on RT-AC86U. 192.168.50.1 works and system log shows these lines...
Dec 3 10:47:24 kernel: pgd = ffffffc0152dd000
Dec 3 10:47:24 kernel: [004b30f4] *pgd=00000000152e1003, *pud=00000000152e1003, *pmd=0000000014807003, *pte=0000000000000000
Dec 3 10:47:24 kernel: CPU: 0 PID: 791 Comm: httpd Tainted: P O 4.1.27 #2
Dec 3 10:47:24 kernel: Hardware name: Broadcom-v8A (DT)
Dec 3 10:47:24 kernel: task: ffffffc01e022b80 ti: ffffffc0153d0000 task.ti: ffffffc0153d0000
Dec 3 10:47:24 kernel: PC is at 0xf6f40aa0
Dec 3 10:47:24 kernel: LR is at 0x26cc4
Dec 3 10:47:24 kernel: pc : [<00000000f6f40aa0>] lr : [<0000000000026cc4>] pstate: 20000010
Dec 3 10:47:24 kernel: sp : 00000000ff86b408
Dec 3 10:47:24 kernel: x12: 000000000008c71c
Dec 3 10:47:24 kernel: x11: 00000000000791e0 x10: 0000000000000001
Dec 3 10:47:24 kernel: x9 : 000000000049f530 x8 : 0000000000000000
Dec 3 10:47:24 kernel: x7 : 00000000004b30e8 x6 : 000000000048d380
Dec 3 10:47:24 kernel: x5 : 00000000004b3260 x4 : 00000000004b30e8
Dec 3 10:47:24 kernel: x3 : 00000000f6dec7a8 x2 : 00000000f6dec7a8
Dec 3 10:47:24 kernel: x1 : 0000000000000000 x0 : 00000000004b30e8
Dec 3 10:47:42 watchdog: restart httpd
Dec 3 10:47:42 rc_service: watchdog 802:notify_rc stop_httpd
Dec 3 10:47:42 rc_service: watchdog 802:notify_rc start_httpd
Dec 3 10:47:42 RT-AC86U: start https:8443
Dec 3 10:47:42 RT-AC86U: start httpd:80
Router seems to be working like it should though.
Have you cleared your browser cache? Give that a try.
Updated to 384.8 from 384.8 beta 2 with dirty upgrade 7 hours ago and everything is running well.
I have a small issue with QOS not picking gaming up properly but I’ll reload FreshJR’s script later. OpenVPN is up and running to with no problems.
Thanks Eric :)
Thank you for your reply. I emptied the cache of my browser but the problem continues.
Have you tried a different browser? I have had issues on one browser that are not there with another.
Same problem with Edge, Chrome and Firefox
In which case I would be looking at doing a factory reset followed by unplugging the router for a few minutes.
I’m not sure what else to suggest if you’ve tried multiple browsers.
Another translate issue with french language:
I believe that RMerlin has said before that the languages are nothing to do with him and there are issues with them, you need to email ASUS and complain
IPv6 is not working as expected. LAN traffic okay, but no WAN connection. This is not completely new to me - have it since a couple of versions, but it did work - but not fixed in current release. Is this an asuswrt (Merlin) issue, or is it my provider (Vodafone cable Germany, static IPv4/IPv6 dual stack).
I have "Native with DHCP-PD" enabled and receive everything correctly but there is no "IPv6 WAN Gateway". Any ideas?
Screen Shot 2018-12-03 at 7.54.32 PM.png Screen Shot 2018-12-03 at 7.51.14 PM.png
Updated AC66U_B1 from 384.7_2 to 384.8. Getting new firmware update notification. Tried enabling then disabling "New firmware version check". It won't go away.
Hello, same issue for me, and I guess like me you have french language turned on, if you change to english (option at the top of the page) the client vpn form will be correctly rendered.
I 've spotted the origin of problem, it's a word in french dictionary that makes general.js to go wrong at line 344
general.js line 344  is  :  var default_hostname_label = '<a class="hintstyle" href="javascript:void(0);" onClick="openHint(5,13);"><#1912#></a>';
in fr.dict, entry 1912 is Nom d'hôte , which actually contains a single quote, this quote is not escaped with a backslash so that's an issue for line 344 because it is already using single quotes to enclose a part of the javascript code, this incorrect javascript line breaks the browser's processing of general.js and in particular it breaks function gen_switch_menu which is in charge of displaying the open vpn client selection list.
To avoid such issues, the set of *.dict files should be revieved to escape all the single and double quotes.
Hope this helps.
Just updated AC86U from 384.7_2. No problem so far.
Windows 10 Build 17763.134
Firefox 63.0.3
Hope this helps.
That was the problem. Now it works very well. Thank you.
