Release Asuswrt-Merlin 386.1 is now available
Think I will update at the weekend, is the general consensus that this is stable firmware?
I have an AC86U, been on 384.18 for a long time, skipped 384.19 due to reading a lot of issues.
Concerning higher temperature on RT-AC86U:
version 386_41994 (RC2 atm) states: RT-AC86U (solves the problem of high CPU usage)
so the solution maybe is here to come
I upgraded from .18 to 386.1 on an AC86U. I've had no issues other than having to re-install some scripts as they were non functional after the upgrade (spdMerlin and Diversion). A simple re-install fixed that.
You will need to do a reset of the router after flashing 386.1 as the router credentials are encrypted as of 384.19. Also don't forget to format the jffs after your install.
Hi, my RT-AX88U in Site Survey - WiFi Insight only shows my SSID for 2.4Ghz and 5Ghz!
+Wireless: Disable WPS + Disable WDS + Disable MAC Filter!
+ReFlash firmware (checksum ok)
+JFFS partition formated
+hard reboot (pull the power plug)
Wireless Log
SSID: "xxx"
noise: -87 dBm Channel: 4
BSSID: xx:xx:xx:xx:xx:B8 Capability: ESS ShortSlot RRM
Supported Rates: [ 1(b) 2(b) 5.5(b) 6 9 11(b) 12 18 24 36 48 54 ]
HE Capable:
Chanspec: 2.4GHz channel 4 20MHz (0x1004)
Primary channel: 4
HT Capabilities: 40Mhz SGI20 SGI40
Supported HT MCS : 0-31
Supported VHT MCS:
NSS1 Tx: 0-11 Rx: 0-11
NSS2 Tx: 0-11 Rx: 0-11
NSS3 Tx: 0-11 Rx: 0-11
NSS4 Tx: 0-11 Rx: 0-11
Supported HE MCS:
80 Mhz:
Interference Level: Acceptable
Mode : AP Only
Stations List
idx MAC Associated Authorized RSSI PHY PSM SGI STBC MUBF NSS BW Tx rate Rx rate Connect Time
xx:xx:xx:xx:96:D3 Yes Yes -52dBm ac Yes Yes Yes Yes 1 20MHz 78M 1M 00:29:39
SSID: "xxx_5G"
noise: -88 dBm Channel: 52/80
BSSID: xx:xx:xx:xx:xx:BC Capability: ESS RRM
Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
HE Capable:
Chanspec: 5GHz channel 58 80MHz (0xe03a)
Primary channel: 52
Supported VHT MCS:
Supported HE MCS:
80 Mhz:
160 Mhz:
Mode : AP Only
DFS status: state In-Service Monitoring (ISM) time elapsed 1739550ms radar channel cleared by DFS channel 52/80 (0xE03A)
Channel Information
Channel 36 A Band
Channel 40 A Band
Channel 44 A Band
Channel 48 A Band
Channel 52 A Band, RADAR Sensitive
Channel 56 A Band, RADAR Sensitive
Channel 60 A Band, RADAR Sensitive
Channel 64 A Band, RADAR Sensitive
Channel 100 A Band, RADAR Sensitive, Passive
Channel 104 A Band, RADAR Sensitive, Passive
Channel 108 A Band, RADAR Sensitive, Passive
Channel 112 A Band, RADAR Sensitive, Passive
Channel 116 A Band, RADAR Sensitive, Passive
Channel 120 A Band, RADAR Sensitive, Passive
Channel 124 A Band, RADAR Sensitive, Passive
Channel 128 A Band, RADAR Sensitive, Passive
Channel 132 A Band, RADAR Sensitive, Passive
Channel 136 A Band, RADAR Sensitive, Passive
Channel 140 A Band, RADAR Sensitive, Passive
Stations List
Any sugestion?
Every thing else so far is great, will install Division and Skynet as usual
#####3Solved! Start Collection need to be activated!
I have a media server HDD mounted on my mesh node is there a way to enter HDD spin down commands via SSH. If so, could someone let me know what these commands are.
If I can do the above is there a way to see node log entries to verify disk is actually spinning up/down. TKS
@XIII
NVRAM Save/Restore Utility has a script named mynvram-save.sh that will allow you to save specific nvram variables.
See post above
That requires having an external USB device attached.
Just set WinSCP to SCP connection type. You do not need to use any extra packages
Note that at least for me, WinSCP kept trying to use SFTP, despite me selecting SCP, unless I actually saved the site in the site list and accessed it from there. Just typing in the Host Name and port number and selecting "SCP" didn't work.
Did you go to Advanced Settings | Wireless | Wi-Fi Radar | Wi-Fi Site Survey, which on my computer opens a seperate Tab in Chrome call Wifi Insight, and then go under "Configure" and "Start Data Collection", along with check marking the "Start collecting data every" checkbox, and then days and times you require?
I am a newbie...what is the command to SSH to my node's IP (I do know the IP address)? Could somebody explain this process with a little detail please? We all have to start somewhere. Thanks in advance for your help!
Use the link below and the pertinent commands (only) to get into your router.
For a node, I would guess to use the IP address of the node and everything else (password, etc.) the same as the main router.
amtm Step-by-Step https://www.snbforums.com/threads/amtm-step-by-step-install-guide-l-ld.56237/#post-483421
my rt-ac5300 in bulit spedtest in router is 320download /308upload Mbbps my FTTH is 1000/300 in internet browser results is 955/310 ??? Asus fw is 386.1 .Whats is wrong???
Welcome to the forums @ToXic_DST.
Please read the changelogs and the first post of this thread for the answers.
Yes forget that
