You say potato and I say potahto
You say tomato and I say tomahto
Potato, potahto, tomato, tomahto.
2nd test same as the first...AX86U had been cruising along on beta1 for a couple of days. Flashed beta 2 and lost Internet. Router said connected, though. Dumped DoT and custom DNS Servers and still no connection. Wife needed to do some banking so went back to Asus firmware. Sorry but I did not save any logs.
Edit. Not too sure but my problems could be related to the AWS issues in Northern Virginia. Unless others report issues I will give beta 2 another chance later tonight.
Any chance this might be related to your own post in the stock factory firmware section regarding difficulties doing a proper reset on this model?2nd test same as the first...
Over flashed Asus 386_45934 with beta 2. Gui Factory Default + initialize all settings. Manually config SSID + passphrase and User + password. When GUI came up I tried to connect with google.com as well as several other web sites. No luck. Did hard factory reset and manually configured again. Same results as before even with trying Cloudflare DNS servers. Router did get IP address from ISP
Flashed back to Asus... working now...
Link for syslog.. https://drive.google.com/file/d/14e3qxeLNMoqodFuAM26lOs1tCiNyutxu/view?usp=sharing
No. Proof is that beta 1 ran like a champ. And first I had upgraded from beta 1 to beta 2.Any chance this might be related to your own post in the stock factory firmware section regarding difficulties doing a proper reset on this model?
RT-AX86U Hard Factory Reset not fully working
Hard Factory Reset, AKA WPS reset, as documented in https://www.asus.com/support/FAQ/1039074/ Method 2 sometimes does not fully reset the router and clear all old data. This has been observed before when resetting Merlin firmware as well as Asus factory firmware. I experienced this problem...www.snbforums.com
I had strict NAT on my Xbox Series X tonight, after updating to beta 2. Had to change to full cone NAT to sort it.I flashed BETA 2 on my AX58U everything on my PC and phone are fine.
My XBOX shows NAT as strict now and games wont connect.
I only have Unbound - Ad Trackers / DNS Firewall - Youtube
Never used Xbox on BETA 1 so not sure on that.
Anyone have any ideas ??
Oh I will try to change that and see if it helps.I had strict NAT on my Xbox Series X tonight, after updating to beta 2. Had to change to full cone NAT to sort it.
I'm on AX86U
@RMerlin@RMerlin
Thanks for the new Beta. Just like to report a Small OpenVPN Connection Status issue.
VPN -> VPN Status Tab -> OpenVPN Server 1
All is well and good, showing both Clients and Routes correctly.
However,
VPN - VPN Server Tab - > VPN Server - OpenVPN -> Connection Status
Is shown as Disconnected for the same Client
PS:
- I have IPV6 (Native) setup and running correctly based on https://ipv6-test.com on my MacBookPro.
- However, On my MacBookPro with Tunnelblick 3.8.8beta02 (build 5780), the OpenVPN connection over my iPhone Cellular Hotspot, https://ipv6-test.com ... shows there is no IPv6, only IPv4
- What else can I test on OpenVPN and IPv6? if you can give me specific instructions. I can do the tests. Thanks.
it is probably going to be like that until asus configures it better. I don't think @RMerlin configured how this is handled, He has just been throwing whatever patches they are trying to see if it resolves any issues.On beta 2, same ddns problem occurs.
And the ddns doesn't update... I have to manually call it
No one else is reporting such connectivity issues, so something but be wrong with your setup. When you say you can't connect, does it fail to resolve the name, or to route?2nd test same as the first...
What is wg-quick?I noticed that for HND routers, wireguard and the user tools are mentioned.
On my AX88U, I see /usr/sbin/wg, the kernel module (wireguard) loaded but no wg-quick. This was on both beta 1 and 2.
Please send me a more detailed log. I can't test IPv6 connectivity. Also make sure that IPv6 is properly working.On beta 2, same ddns problem occurs.
I've had "Disable 11b" checkbox enabled since Alpha with Auto wireless mode, no issues.Have someone have courage to test: Disable 11b button ? Is it working now?
BTW, that message in itself does not denote a fatal error. With the beta 2 patches from Asus, it's just a notification that at the time start_ddns() was called your IPv6 wasn't valid yet. It will instruct the watchdog to check again a few minutes later, so your DDNS should eventually get updated.On beta 2, same ddns problem occurs.
What is wg-quick?
bash
scripts for different environments to be used to configure the WireGuard interfaces:Welcome To SNBForums
