See Post #221Can anyone confirm TimeMachine is fixed with 386.5. Thank you.
Ask the app developers.Should I be re-installing the other apps as well?
Well almost 48 hours later and only 1 line in the logYour post seemed to go over everyone's head. Good thing it was just a warning shot !
Mar 11 18:58:20 dnsmasq-dhcp[27064]: DHCPREQUEST(br0) 192.168.50.212 d8:9c:67:2e:f0:da
Mar 11 18:58:20 dnsmasq-dhcp[27064]: DHCPACK(br0) 192.168.50.212 d8:9c:67:2e:f0:da BRWD89C672EF0DA
Mar 11 19:03:03 hostapd: eth7: STA 64:6d:2f:61:b8:cd WPA: group key handshake completed (RSN)
Mar 11 19:03:03 hostapd: eth7: STA 4c:17:44:08:2b:ab WPA: group key handshake completed (RSN)
Mar 11 19:03:03 hostapd: eth7: STA 2c:db:07:57:8e:15 WPA: group key handshake completed (RSN)
Mar 11 19:03:03 hostapd: eth6: STA d8:9c:67:2e:f0:da WPA: group key handshake completed (RSN)
Mar 11 19:03:03 hostapd: wl0.2: STA 50:02:91:b2:81:26 WPA: group key handshake completed (RSN)
Mar 11 19:03:04 hostapd: wl0.2: STA 68:57:2d:d5:2d:49 WPA: group key handshake completed (RSN)
Mar 11 19:03:04 hostapd: wl0.2: STA 68:57:2d:d4:79:d9 WPA: group key handshake completed (RSN)
Mar 11 19:03:04 hostapd: wl0.2: STA 68:57:2d:d4:7b:d5 WPA: group key handshake completed (RSN)
Mar 11 19:03:04 hostapd: wl0.2: STA 9a:1c:76:52:0b:84 WPA: group key handshake completed (RSN)
Mar 11 20:01:50 kernel: httpd (1545): drop_caches: 1
The following are the System Log entries at the time I get dropouts on my Echo Studio I mentioned above. Is there anything anyone sees that might reveal a problem with my configuration? The Echo Studio is a 5Ghz device (the BRWD89C672EF0DA device is my Brother printer 2.4Ghz).
Thanks,
Anton
I'm using this DNS setttings, and second time within last week I got no DNS response to clients, had to restart the router to make it work. Only after router reboot got DNS resolution again.
When I select those DoT preset servers on Asuswrt, there are no TLS Port entries. I wonder why the difference.
OE
I entered those manually
If you leave the TLS port blank it defaults to whatever that service uses. Mouse over the TLS port word and it will say what port it defaults to when trying to add a new DOT.I entered those manually![]()
I've tried completely resetting the device (it's an IP camera by the way), but that didn't work.Try reconfiguring that Guest in case for some reason the passphrase might be corrupted, or some of the low-level Guest settings were corrupted.
Welcome To SNBForums
