Beta Asuswrt-Merlin 386.7 Beta is now available
Just fine on GT-AX6000...flashed and then factory default reset. Working well.
That would suggest that DDNS isn't enabled. Check with nvram get ddns_enable_x over SSH. Or look for errors in the browser console using the F12 key.
It does work as I can connect to my cameras & I see no errors.
My RT-AX88U shows "Go" as described but only when set to DNS-O-Matic as the provider. The "Go" button then links to the DNS-O-Matic website. It shows the current ddns hostname when set to other providers (e.g.No-IP). Looks like might be intended behaviour unless the OP isn't using DNS-O-Matic.
Do you use DNS-o-Matic?
Node disappeared tonight at 21:37 due to
Jun 13 21:37:17 rc_service: cfg_server 1448:notify_rc update_sta_binding
Then it spent several minutes connecting and disconnecting due to "station leaving"
Then
Jun 13 21:41:38 rc_service: cfg_server 9310:notify_rc update_sta_binding
Jun 13 21:41:40 roamast: eth2: sta-ap-band-bind deauth
I thought this had been fixed as it didn't happen on the two Alphas.
Going to try a reboot of system see if it goes away. Anyone explain?
Dirty upgrade from 386.5_2 worked great on an AX88U. No issues with any of my past settings including DNSSec using cloudfare, Yazfi, Diversion, Skynet. Running like a champ with a hard reboot after the flash.
Thank you for the update Merlin.
Reboot of system under AIMESH/System settings slightly broken. Counter gets 6% roughly then disappears and webpage becomes non responsive until reboot has been performed.
For an unknown reason, for the first time- IPv6 on AX88U is not gettitng V6.
Im configured for Native because that is how my ISP used to fetch it, and since upgrade to this FW not getting any IPv6.
Edit: after a lot of time, changing IPv6 from Disable to Native and vice-versa- finally fetched.
Something to look into, I think
Hopefull for your check @RMerlin
Have the same IPV6 problem with same ISP.
After disable-enable switch routine, like 5-6-7 times, I managed to fetch IPv6.
Works.
I guess some kind of a bug in Merlin's Beta.
To be checked
Works.
To be checked
Yes, but this is required after every boot
Or even after GUI change which restart the wan.
On 386.7 B1 since Saturday: My GT-AXE11000 locked up yesterday at 12:15pm, no WiFi or LAN capability the first symptom, Web Gui & SSH no response, lights on unit solid, not the usual blinking from WAN/WiFi. Had to power off/on the unit to recover. Looking at the Syslog, a kernel fatal error message, about an hour before the crash/halt.
Are you running pixelserv- tls with diversion?
Thus is normal as router reboots.
What is your personal preference with regards to running pixelserv-tls?
This subject comes up and I'm wondering if it's not as effective or causes other undesired side effects in 2022.
I've used it for a long time but with so many other changes in the past year, I'm wondering if it is still recommended.
The last time I asked, the author said it was still relevant. ( I'm not trying to diminish his good work by asking. )
I was using the Standard block list but since early this year I switched to the Large list.
Also, what other scripts conflict with it, that you know of? EDIT: bad pairings?
Trendmicro and pixelserv tls don't play nice. That's all I know.
All works well on mu AX88, no IPV6 problems (using IPV6 (native) from KPN fiber - Holland)
