Upgraded my system to 386_7.
AX88U*2.
Sadly, it has few bugs from Alpha/Beta that still not recovered.
Once I just upgraded the FW, Fetching WAN IP takes it a lot if time.
It even caused some kind of reboot or something.
So IPv4 became harder to fetch, Ipv6 is not fetched at all here.
Yesterday, during issues with my ISP it made me reboot my router 4 times in a row, usually would not have to do it once at all because it would fetch IPv4 by itself.
For now, impossible to use, will downgrade currently to  386_5.
Hopefully 386_7.2 will arrive fast with changes to WAN IPv4/IPv6 fetch.
Something with the ASUS sdk changes is made it harded to actually use.
Edit: Rewined to 386_5.2, IPv4 fetched like usual- IPv6 probably did not release address prior to the rewind.
I did notice that the ring uses IPv6 only communication, so if I fail to communicate IPv6 it would not work.
For now I stay 386_5.2 for the stabillity, hopefull 386_7.2 will fix these issues with AX88U.
Thank you for your hard work.
You are giving very little information, e.g., from which version are you coming from? Was a reset completed, what type of reset? Manual rebuild completed, load of a backup/configuration file, reset of the JFFS partition? Wan/LAN, Professional settings, etc., that you are using and or tried? What have you completed from a trouble shooting perspective? Are you running an AiMesh setup? Nobody here has a crystal ball, a more informative answer can only be obtained from this forum, giving people the right information to work with, to formulate and answer/help with your issue/s. Where is the backup/proof, of your complaints? Supply a snippet of your router log for review by the many guru's that are here within this forum. The output and help provided to you will/maybe, help others within this forum, for I am sure a possible solution and or maybe, identify a genuine bug within the firmware.
Is it me, or just, do some people forget/not understand, how lucky we are to have the ability/use, a Merlin provided, alternative ASUS router firmware, an individual, generously sharing his own time, to provide us, a better ASUS router fit/experience, to proper our requirements/wish list/development/features. Which, may I remind people, we can all contribute, in its (firmware), development from Merlin.
My apologies to the forum, rant finished.
