Release Asuswrt-Merlin 386.7 is now available for all models
Updated from 386.7_Beta2 to 386.7
All apparently running OK but every few minutes I'm getting the following message in syslog that I've never seen before, not even in 386.7_Beta2.
kernel: CFG80211-ERROR) wl_cfg80211_sta_info : GET STA INFO failed, -21
Indeed got the same messages and these ones were not present in the beta2
I just completed a dirty upgrade on my RT-AC88U from 386.5_2 to 386.7_0. All went smoothly (thankyou!) but when I checked the WiFi channels after the upgrade, the professional 'Region' setting had changed from 'Australia' to blank. I changed the Region to Australia, saved the settings and the router rebooted as normal. However, after reboot with the Region now showing as Australia I now have only 5GHz channels 36-48 and 149-165 available for selection, whereas previously I had all of the Australian regulatory approved channels available, ie. 32-48, 50-68 (DFS), 96-116 (DFS), 132-144 (DFS) and 149-165.
I'm seeing the correct list of 2.4GHz channels being available for selection, ie. 1-13, so the problem appears to be confined to the 5GHz channel selection.
Is doing a full reset likely to fix the issue? Or is this a bug in 386.7_0?
Thanks for all your excellent work on the Merlin project - very much appreciated!
Interesting!
My AX88U has always had region = “Asia (Default)”.
There was never (till now) an “Australia“ option.
I queried Asus back in the day after buying the router, & was assured that “Asia” was correct.
Ive just configured the “Australia” setting & gained channels 12 & 13 on 2.4 band: lost channels 100, 104, 108 & 112 on the 5ghz band. (No loss, I’m not using DFS or 160 bandwidth anyhow. :)
I just noticed that these messages are only showing up in my syslog server.
But not in the syslog on the router UI.
Ax56U stuck on Please wait, Applying settings upgrade from 386_5.2 to 386_7.
Running AC68 in AP mode, reset to factory from last release. Once I set the system to login over https only, I lose access to the UI. 'refused to connect'.
My bad, its fine. Sorry for the false report.
Wondering if this version has the WireGuard UI for AX86U?
Possibly, I see WireGuard menu's under the main menu but not elsewhere, maybe something wrong with scMerlin?
@RMerlin - is there something wrong with the menus for WireGuard?
Using scMerlin, hovering over 'VPN' I see two menus for WireGuard - server and client.
But they don't appear as tabs or options on the VPN page.
Downloaded, awaiting a suitable time to install around the family, we're all at home with covid (4 out of 5). Don't worry I'm wearing a mask.
Off to watch the latest strange new worlds. Perk of being sick.
Hi Merlin, thanks for the latest release 386.7. After upgrading from 386.5_2 directly, I saw in the log:
Jun 23 17:49:09 RT-AX86U-1F70 kernel: <unknown>: hw csum failure
Jun 23 17:49:09 RT-AX86U-1F70 kernel: CPU: 1 PID: 5116 Comm: dnsmasq Tainted: P           O    4.1.52 #2
Jun 23 17:49:09 RT-AX86U-1F70 kernel: Hardware name: Broadcom-v8A (DT)
Jun 23 17:49:09 RT-AX86U-1F70 kernel: Call trace:
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc000087398>] dump_backtrace+0x0/0x150
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc0000874fc>] show_stack+0x14/0x20
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc0005589d0>] dump_stack+0x90/0xb0
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc0003fe05c>] netdev_rx_csum_fault+0x3c/0x50
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc0003f22d0>] skb_copy_and_csum_datagram_msg+0xe8/0xf8
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc0004f8468>] udpv6_recvmsg+0x2a0/0x7d8
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc0004a616c>] inet_recvmsg+0xa4/0xc8
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc0003df4d4>] sock_recvmsg+0x14/0x20
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc0003e10e4>] ___sys_recvmsg+0xac/0x1a8
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc0003e3b18>] __sys_recvmsg+0x40/0x80
Jun 23 17:49:09 RT-AX86U-1F70 kernel: [<ffffffc000423410>] compat_SyS_recvmsg+0x10/0x18
Jun 23 17:49:10 RT-AX86U-1F70 kernel: <unknown>: hw csum failure
Jun 23 17:49:10 RT-AX86U-1F70 kernel: CPU: 2 PID: 5116 Comm: dnsmasq Tainted: P           O    4.1.52 #2
Jun 23 17:49:10 RT-AX86U-1F70 kernel: Hardware name: Broadcom-v8A (DT)
Jun 23 17:49:10 RT-AX86U-1F70 kernel: Call trace:
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc000087398>] dump_backtrace+0x0/0x150
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc0000874fc>] show_stack+0x14/0x20
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc0005589d0>] dump_stack+0x90/0xb0
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc0003fe05c>] netdev_rx_csum_fault+0x3c/0x50
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc0003f22d0>] skb_copy_and_csum_datagram_msg+0xe8/0xf8
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc0004f8468>] udpv6_recvmsg+0x2a0/0x7d8
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc0004a616c>] inet_recvmsg+0xa4/0xc8
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc0003df4d4>] sock_recvmsg+0x14/0x20
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc0003e10e4>] ___sys_recvmsg+0xac/0x1a8
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc0003e3b18>] __sys_recvmsg+0x40/0x80
Jun 23 17:49:10 RT-AX86U-1F70 kernel: [<ffffffc000423410>] compat_SyS_recvmsg+0x10/0x18
Jun 23 17:49:31 RT-AX86U-1F70 kernel: <unknown>: hw csum failure
Jun 23 17:49:31 RT-AX86U-1F70 kernel: CPU: 2 PID: 5116 Comm: dnsmasq Tainted: P           O    4.1.52 #2
Jun 23 17:49:31 RT-AX86U-1F70 kernel: Hardware name: Broadcom-v8A (DT)
Jun 23 17:49:31 RT-AX86U-1F70 kernel: Call trace:
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc000087398>] dump_backtrace+0x0/0x150
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc0000874fc>] show_stack+0x14/0x20
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc0005589d0>] dump_stack+0x90/0xb0
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc0003fe05c>] netdev_rx_csum_fault+0x3c/0x50
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc0003f22d0>] skb_copy_and_csum_datagram_msg+0xe8/0xf8
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc0004f8468>] udpv6_recvmsg+0x2a0/0x7d8
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc0004a616c>] inet_recvmsg+0xa4/0xc8
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc0003df4d4>] sock_recvmsg+0x14/0x20
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc0003e10e4>] ___sys_recvmsg+0xac/0x1a8
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc0003e3b18>] __sys_recvmsg+0x40/0x80
Jun 23 17:49:31 RT-AX86U-1F70 kernel: [<ffffffc000423410>] compat_SyS_recvmsg+0x10/0x18
Is this any cause for concern? It happened 4 times after the upgrade reboot, and it didn't show again (for now)
Asuswrt-Merlin 386.7 is now available for all supported models. The focus of this release is to upgrade the GPL base code, as well as introduce a few minor improvements.
The highlights:
  • Merged with GPL 386_49335 (for the RT-AC5300) and 386_48966 (for all other models).
  • DNSFilter can now also intercept and redirect IPv6 DNS queries on HND models. You can also specify IPv6 DNS servers for the three custom settings.
  • Component updates: openssl 1.1.1o, haveged 1.9.18, openvpn 2.5.7 and tor 0.4.7.8.
  • Fixed CVE-2022-0934 and CVE-2022-26376.
  • And a few other fixes
Also this includes the following changes from 386.6 (which was previously only available for the XT12 and GT-AX6000):
  • Added new IPv6 options to OpenVPN servers, allowing to disable/enable IPv6 support, and also to enable NAT (allowing remote clients to also redirect their IPv6 Internet traffic through their router's OpenVPN server
  • Updated components: wget (1.21.3), dropbear (2022.82)
  • Allow requesting bigger IPv6 subnets from your ISP
  • Fixed Traditional QoS download traffic limited by upstream bandwidth
Note: while openssl 1.1.1p just came out, I decided not to put the firmware through another beta cycle just for it as the security issue it addresses does not affect Asuswrt-Merlin.
Please keep the discussion on this particular release. Off-topic posts will be moved, deleted or ignored depending on my mood at the time.
This thread will be closed down once the initial release feedback has quieted town.
Downloads are here.
Changelog is here.
Performed dirty upgrade on my RT-AC5300 from 386.7 B2 and everything is running OK. The OpenVPN configuration issue I reported for the B2 release has also been fixed. Many thanks Merlin.
Have you tried a total reset and manual rebuild, including a JFFS reset? A fresh build of new firmware is always prefered to establish problems/bugs.
Thanks for this new update.
But I will wait for the 386.7_2 because I saw on this post that there were some bugs with the AX88U.
For the moment I stay on the 386.5_2 version which is perfectly stable !
:cool:
What bugs? Everything works fine on my two AX88U.
:cool:
What bugs? Are you sure they are bugs and or configuration/setup issues?
I could, but I would not do it for now as it doesn’t impact anything and everything works normally that I notice. Just the error message came up after the reboot. It’s not repeating yet other than the one I posted above.
Where do you see it? I just upgraded but can't see WireGuard anywhere :(
If you run the 'scMerlin' extension, you see all the sub-menu entries if you 'hover' over the l/h side menu. They are there, but they don't appear on the actual 'VPN' tab.
I think there's something wrong with the menu.
Oh ok, with extensions I could just use the WireGuard manager I wanted to see if its available without scripts/extensions, looks like it hasn't been made available for AX86U yet @RMerlin ?
Hi All, I have downloaded RT-AC5300_386.7_0.zip a couple of times, extracted the .trx file but every time I try and upload the firmware the router errors telling me it is an invalid file?
Currently running 386.5_2
Adrian.
I suspect Asus is not quite ready to expose the WireGuard service yet. The wireguard modules (kernel driver and wg helper app) and Web UI page source might be in the release, but not yet exposed.
@Jack Yaz scmerlin addon inadvertently exposes them since it walks the entire WebUI tree and adds a feature that opens a submenu when you click on the main menu item (i.e. click Game on the far right and it shows “Game Boost”. Its a quicker way to get to sub menu items (sub tabs) from the main menu.
Personally I would not recommend doing anything on the Asus WireGuard menus (server/client) if you do have/install scmerlin. If their not ready - their not ready. Asus will release when they ARE ready.
There is always the @Martineau WireGuard Manager (wg_manager) addon if you want to try WireGuard now.
For now, it is all command line based. He is working on a Web page now.
Going to be an interesting race to see who releases a full WireGuard Web based feature - Asus or @Martineau ;-)
is it 100% certain that you dare to update my sister's router which is an rt-ax86u?
want to be sure it does not stop working
want to be 100 % sure before I do anything with her router
